Question about Optoma (BL-FU180A) Projector Lamp for EzPro 716, EzPro 719
Optoma 716 Computer sees it, powers on, no picture. 10 hours on bulb.
  • 115 Answers
On the projector, restart your laptop/computer, this will detect automatically. if not then try display settings to 800x600.
Posted on Dec 13, 2008
Why would my projector refuse to start with a seemingly intact light bulb?
If you only have 300 hours on it it should still be under warranty. Before doing something to void that I would check with Optoma techs.
Jul 23, 2014 | Optoma HD20 DLP Projector
Optoma hd72
It sounds like you bulb is ready to die. First clue is picture quality. That happen to me and a new bulb remedy the problem. Bulbs are expensive though.
Jan 28, 2014 | Optoma HD72 Multimedia Projector
My Optoma TX780 projector is not working and all the indicators ie, Temp, Power and Lamp are on. I have changed the lamp though and it worked for a while then the lights came on and would not come on.
you need to reset the Bulb Hours in the on screen menu. it turns off because the bulb contains mercury and after a certain amount of hours the bulb will burst, spreading mercury every where. reset the bulb hours and it should stay on.
Jul 03, 2011 | Optoma TX780 DLP Projector
Hello. I have optoma ep716 with problem: 1. When I power it on the green blinking for 20-30 seconds and after this stays green. Due to manual it's meaning that projector on however lamp does not provide...
hi,
Do one one thing. check the lamp of your projector. For removing the lamp see the bellow picture.
also check the lamp colling fan. If it is faulty this fault can occur.
1. Use a screwdriver to remove the screw from the cover.(1)
2.Push up and remove the cover.(2)
3. Remove the 2 screws from the lamp module.(3)
4.Pull out the lamp module. (4)
ok
Feb 16, 2011 | Optoma (BL-FU180A) Projector Lamp for...
My Optoma HD72 projector operates for about 1 minute and then shuts off. I kept my old bulb around "just in case", I've replaced the bulb with the old one and have the same problem.
The problem is not over-heating. The Optoma HD72 has a known problem that Optoma won't advertise. The lamp driver is faulty. They simply have to replace the lamp driver. I purchased a spare lamp with my original purchase. I had the exact same experience as you at around 1200 hours on the lamp in ECO mode. I used the spare lamp. Same thing happened at about 1200 hours. I had a friend at Optoma. he confided to me the problem. I sent it in and they replaced the lamp driver at no charge. I got another 800 hours out of the first lamp and am now using my second lamp and have about 600 hours on it. The pic quality is so good with this projector (used Digital Video Essentials to calibrate) that I'll just order a bare lamp or two and use the existing lamp housings when I need a new bulb.
Apr 12, 2010 | Optoma H30 Multimedia Projector
Optoma H70 picture flashes on and off
This is how my problem with the power not going on started. I cleaned mine and it was running much better. I decided to give it a good cleaning, but now the power won't turn on. Try at your own risk as this could happen to you as well. Just a note, I have had mine for 4 yrs with the same bulb, just over 6000 hrs. I was lucky until now.
Mar 30, 2010 | Optoma HD70 DLP Projector
Optoma DV10 loud vibration and odd colours
check the colour glass wheel is shattered with a piece of glass still stack to the wheel. it not even thats why it vibrates
Aug 17, 2009 | Optoma MovieTime DV10 DLP Projector
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
Power for optoma ep 716
TAKE TO THE AUTHORIZED SERVICE CENTER OF OPTOMA
WANT ADDRESS goTHROUGH WWW.OPTOMA.COM
Nov 11, 2008 | Optoma EP716 Multimedia Projector
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Optoma (BL-FU180A) Projector Lamp for EzPro 716, EzPro 719 Logo
152 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
