Question about HP LaserJet 4350 Printer
I'm wondering where the serial numbers for an HP 4350 are located
Kind of an odd question, but hopefully someone here can help. I am wondering where all of the serial numbers are on an HP LJ4350.
Long story short, I needed to talk to tech support at HP. I was at work, and the printer at home. They will not speak to you unless you can provide them a serial number. All I was requesting was a part (see other threads) - they said it was part of the chassis, and weren't sure I could order it. Well, they escalated it to second level support - and yesteday I received a new printer on my doorstep. It's a newer P4015 instead of the 4350.
Well, now I'm kind of stuck in a situation that I need to send them a printer, but mine is not the serial number they are looking for.
I know the serial is on the lid, on the rear EIO cover, and on the chassis behind the formatter board. Anyone know of anywhere else?
I know... I know... probably not the most ethical question, but I'm not sure that I can just send the printer back at this point can I? I never asked for it, but I am worried because I am HP certified, and with my tech ID, they have all of my outlet information as well. I guess I'm looking to take care of this the best way possible while 1) getting my printer fixed, and 2) not jeapordizing my job/status as an HP authorized service outlet and 3) having my boss get on me about working on personal stuff and using my tech ID.
Sorry so long - anyone have any ideas or suggestions?
  • 231 Answers
Source: =>
Hewlett Packard printers can have their serial numbers reprogrammed in the field, from the front panel of the printer, with very little special knowledge and no special tools. Any electronic page showing its serial number afterward would be divergent from the actual serial number for the machine. It can be changed back again, too - an unlimited number of times.
Yeah, I know - you'll never trust the page count on a used printer again, but there you have it.
This is only true on some of the newer models, and on the larger ones - not the smaller machines like the 1200, but the larger ones like the 5Si, the 4500, etc.
Canon builds the print engines (basic mechanical arrangements of components) for Hewlett Packard, which only really engineers the firmware - which could be used to implement the hidden codes you're investigating. But I would not be surprised if Canon and HP codes look the same and are implemented at a level common to both brands of machine. It is odd to me that you did not publish any pictures of the test prints from the manufacturer which dominates the industry, though...
Since you can alter the serial number (at will) on an HP machine, that could make your decoding task that much easier, if you have access to one. Set to all 1's, all 2's, etc. and compare test prints.
On the other hand, it also makes the entire schema a joke, since I could program my printer to say it is your printer (copy your serial number), print up some phoneybux, and then set it back to innocent_serial and whistle while I watch your office get raided.
The serial number information is soft-coded to allow the formatter board to be replaced if it fails, while still supporting the configuration page's reportage of that printer's vital stats. You can even load the new formatter with the page count from the old formatter, so that the mechanical parts can be maintained on schedule as they wear out.
Now, this is not true of the Formatter Number, which is the serial number of the formatter card itself. If that is the basis of HP's system of Identity, then the workaround would involve a physical removal of the formatter and its (temporary) replacement with another formatter. For someone engaged in producing phoneybux, this is not an economic hardship.
Posted on Dec 27, 2008
Were can I find serial no on 9.9hp mariner
Your serial number is located on the lower starboard side of the engine block. A serial number is also located on the starboard side of the swivel bracket.
Here's a link to your service manual if you need it.
Hope this helps.
Boatinfo Mercury Service Manual for 9 9 15 hp
Sep 04, 2014 | Boating
My hp laptops powers up with all the lights on and even the curser works but nothing on the screen? At startup on the screen it says my serial number could not be found???
This points to a problem with the Motherboard not being recognised and will require the HP DMI tool to "write" the serial number and product Id of the laptop to the Bios. I THINK this can only be done by an HP technician, or someone who has access (and knows how to use the software).
I find it odd that this should suddenly happen, unless, you had a replacement motherboard fitted that the technical staff forgot to code to the laptop..
If this is the case i'd contact HP and explain the problem, I would think you will be asked to prove ownership as this is a common anti-theft strategy on the same lines as the Bios lock code used by Toshiba and dell
Jun 12, 2011 | HP Pavilion dv6-1030us Notebook
I bought a new machine hp laserjet 4350n but I cannot locate the power switch botton. Pls help me.
Hi, the power switch button (on/off switch) is shown as Number 5 in the diagram below, on the right hand side of the printer at the bottom:
Apr 12, 2011 | HP LaserJet 4350 Printer
I can not clear the error (49.4C18) on the 4350 printer. Is there a way to fix it?
This error can have a number of causes. Sometimes, a corrupt file, or pdl string from certain applications can cause this. It could be something on the formatter. You could try to take out any added EIO cards, hard disks, or font or memory Dimms and power on to see if it clears. If so, then try to add them again one at a time to see if any cause an issue. If it does occur; make sure to clear the offending print job from the print queue before going any further. If any Dimms or cards, etc. are the cause, then replacing them should help. If you can get it to clear, going into the CONFIGURE DEVICE / RESET MENU and resetting to factory defaults may help, or in some more extreme cases an NVRAM initialization, but it resets the page counts and serial numbers and other system settings. An NVRAM INIT is done like a cold reset except when SELECT LANGUAGE appears scroll to NVRAM INIT. It could also be an issue with the original JetDirect embedded print server.
Sep 11, 2009 | HP LaserJet 4350 Printer
59.40 error code
That's a main motor error, something could be jammed in transport, or a generic toner cart. that is too hard to turn, try powering on with toner removed...
Aug 20, 2009 | HP 4250 Monochrome LaserJet Printer
HP D530 Video card upgrade
If the HP D530 has an AGP slot, which I think it does, then yes you can install the Radeon HD 4350 card.
Make sure you have the correct driver for the video card.
Go to this site for more info:
Hope this helps.
Good Luck.
Mar 19, 2009 | HP Compaq d530 SFF PC Desktop
HP 4200/4250/4350 papertray spring
Feb 09, 2009 | HP LaserJet 4250n Printer
I can't find the serial number for my bamboo fun?
look on the back of the tablet,were the bar code is. There will be a number about the bar code which is the modle number and the will be a number below that says S/N:______(what ever number you have) The S/N is the serial number.Hope this help I'm trying to install my Wacom as well
Dec 26, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
HP Printer top cover replacement
I think your best bet is just to store the old lid away and keep the receipt that HP sent with the new lid. That way you can prove they replaced the lid and you have the old one with the sn on it to prove it.
Dec 09, 2008 | HP LaserJet 4350 Printer
HP 4350 downgraded to a HP 4250
Is this affecting performance? Try new firmware.
Mar 20, 2008 | HP LaserJet 4350 Printer
HP LaserJet 4350 Printer Logo
380 people viewed this question
Ben Johnson
