Question about Nikon Coolpix L11 Digital Camera
A red box with clock flashing?
Red clock flashing and keeps taking pictures. not the self timer
  • 423 Answers
It means you need to set the correct date and time in the setup menu. It will keep taking pictures, but it's telling you that you have not set up the correct time & date in the camera.
Posted on Feb 18, 2009
I have the coolpix s33. On the top of the view screen there is a flashing red square with a clock What is this representing and how do I remove it
The camera has a 10 second self timer. usually when you want to use it.. It only works for one image so you have to set it up for self timer again. On the back you may be able to set the camera to use the self timer. The only ICON I know of in most cameras that has a clock is the self timer.
Say camera is in Tripod and you want to take a group shot and YOU want to be in the photo. You set up and put on Self Timer. You press the shutter and it will take 10 seconds before taking the photo... Enough time for YOU to get int he shot.
Sep 30, 2016 | Nikon COOLPIX Cameras
Take self picture
Press cursor-right (marked with a one-handed clock) to cycle through the self-timer/burst settings.
For full details see the "Using the Self-timer and Burst Photography" section on page 19 of this manual.
Mar 01, 2013 | Sanyo Xacti VPCS1275 Digital Camera
I am trying to wire a timer switch in a four gang outlet box and the timer switchhas a red, black, white, and green wire. The existing switches in the box are all wired with two black wires and one copper...
Your switch has two black wires.
One of these wires goes to Load (light fan motor)
The other wire is hot. And this wire probably connects back to other switches in box making it easy to identify.
Timer-black wire goes to hot wire.
Timer-red wire goes to Load wire.
Timer green wire goes to bare ground wire.
Timer white wire runs the clock located inside timer. So timer clock is just like alarm clock, and needs its own power.
In back of 4-gang box are white wires that are twisted together and covered with wire nut.
These are neutral wires.
Timer-white wire connects to neutrals, and this completes clock circuit.
Dec 07, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Red flashing clock in screen
Do you have the self-timer turned on? You could go into the camera menu and find "reset" to return to default settings.
Jul 18, 2010 | Nikon Coolpix S51c Digital Camera
My Samsung L100 Camera doesn't know how to flash once!
Most cameras flash twice; the first one is for setting the exposure, the second one is for real. About the best you can do is warn your targets that the camera is going to flash twice.
Yes, the L100 has a self-timer. Press Right on the selector (the clock icon) until the desired mode indicator appears on the display. Your choices are 10-second delay, 2-second delay, double self-timer, and motion timer.
The self-timer is described on pages 29-30 in my copy of the manual.
Mar 11, 2010 | Samsung L100 Digital Camera
Red flashing clock in right hand side of LCD
Sounds like you have the self-timer turned on. If you press the shutter button and stand in front of the camera, it should take a picture of you.
Dec 11, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How do i set the timer on my canon powershot a560 to take a pic
There's a button with a clock next to it. Press that button and put your camera where you want it. Press the shutter release half way, to get focused. When you press it the whole way down, the timer will start and you will have 8-10 seconds. There is normally a burst of a few flashes when it takes the picture.
Oct 03, 2009 | Canon PowerShot A560 Digital Camera
Shutter sticks
Does the light flash for 10 seconds, with a series of beeps getting faster before the picture is taken so you miss the shot, or are you saying the shutter stays open for several seconds giving you a whiteout picture?
If the former, then the self-timer is on. Press the button on the back of the camera to the right of the displays just under the AV button. The display icon will change from :-
Hand sweeping round clock = self timer mode
Simple square = single shot mode
Stacked squares = multi shot (keep finger pressed to keep shooting)
Feb 13, 2009 | Canon Digital Rebel / EOS-300D Digital...
Flash is delayed
You have switched the self-timer on!
Press the button to the right of the displays just under the AV button. You need to ensure the display does not show the self-timer icon, which looks a bit like a second hand sweeping around a clock (with a dot at the 12 position).
That should do it.
Cheers
John
Feb 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Flash is delaying
The self-timer is on. Press the button on the back of the camera to the right of the displays just under the AV button. The display icon will change from :-
Jan 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Nikon Coolpix L11 Digital Camera Logo
482 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
