Question about Tomtom One Europe v2 GPS Receiver
Step by Step Instructions for replacing battery
Please advise where I can obtain a step by step instructions on replacing battery
  • 158 Answers
  1. Upen the tomtom by removing the 4 star screws holding the 2 halves of case together.
  2. Split the case with your fingers at the top by pulling the back away from the front.
  3. ease away the case halves.
  4. Once apart you will see the battery in the back half and its held in with a sticky pad . gentle widdling and pulling will bring it loose.
  5. unplug from circuitry by removing the little plug
  6. plug in new battery and secure with double sided sticky tape.
Its very unusual for a battery to go unless the tomtom has had lots and lots of use. It might be worthwhile checking the charging function whilst you have the tomtom open. You can do this with a multimeter set on DC 20v range. near to the battery plug you should see a small gold pad adgacent to the RED wire. Measure between this pad and any earth screening can whilst a charge is applied to the tomtom ( no battery connected ) and you should have a voltage of about 5v. if there is no voltage then the battery won't get charged and you have a faulty charging circuit or charger.
Good luck .
Posted on Dec 31, 2008
  • 479 Answers
*Procedure for charging the Battery from a USB Connection: Turn the unit off. Plug in the USB. (That turns the unit on). Turn the unit off before the maps load and before you get the 'computer picture'. Otherwise, you can't turn the unit off.
Maintenance Mode:
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. After some selections the unit should reboot and you check to verify unit after rebooting. Diagnostics Mode:
Pressing and holding on the Trip Computer Speedometer (above) will bring up nine diagnostic pages.
Posted on Dec 15, 2008
I would like to reset a Panasonic DTV Remote control Model N20AY8000122 to replace the lost the remote control for AWA DTV Model MHDV2445-03-D0. could you pls advise in step by step sequence the...
Unless your Panasonic remote is a programmable universal type, you will not have much luck trying to make it control your Aiwa TV. A more practical approach would be to obtain a universal remote and follow the accompanying instructions to program it.
Mar 11, 2014 | Televison & Video
I need step-by-step instructions on changing gas dryer door orientation on Fridgidaire model # FAQG7011KW0. Please advise.
Hi and welcome to FixYa, I am Kelly
It took a while to locate this manual! I had been looking for it since 12 minutes after you posted the question.
The manual is here:
or here: (best download choice below)
Click on info and guides first.
Then installation instructions and download the manual.
Door reversal step by step starts on page 18 of the manual.
Thanks for choosing FixYa,
Jul 17, 2011 | Frigidaire Dryers
I need step by step instructions on removing the starter from a 1997 flstc
Disconnect the battery, remove the negative 1st...Remove primary cover...Hold pinion gear in place and remove jackshaft bolt...
Remove rear exhaust pipe...Remove allen screw end cover... Remove starter mounting alan head bolts and washers....Disconnect positive battery lead and solenoid wire from starter....Remove starter...
Note: you might need to loosen the oil tank mounts to provide clearance for starter removal...
Install new starter in reverse order...Torque specs...
Starter mounting bolts - 13 - 30 ft-lbs
Jackshaft bolt - 7 - 9 ft-lbs
Jul 17, 2011 | Harley Davidson FLSTC - FLSTCI Heritage...
Hello please send unlock code for nokia 5230 be imei:354845045911906 thanks
You are not at the right address to obtain this; it will have to come from your provider.
Apr 08, 2011 | Cell Phones
How do I change a rear brake disc and pad on an 2005 BMW Mini
Go to this USA website and search for rear brake replacement on Mini.
The site gives good instructions on parts required and a step by step instructions on how to change and adjust the brakes.
Alan Hood
Apr 21, 2010 | 2006 BMW Mini
Step by step instr. to remove heater core
It would be best to obtain a haynes manual about $15 from local auto supply store as it has pictures as well as instructions. Not an easy job.
Jan 14, 2010 | 1988 Chevrolet Cavalier Z24
How to check and correct a bad Ear Piece
Equipments Needed
Digital and Analog Meter
Procedures to Follow
Step 1: Check and read your ear piece to see if it's good
Step 2: Check if the terminal is connected on the board interface.
Step 3: If it is not connected, clean well and make it connect.
Step 4: Read the board interface to see if it is reading continually, if it isn't, loop for sound.
Step 5: If it's a flip up phone and the phone interface is not reading, you have to replace the flex to obtain sound.
Jan 11, 2010 | Nokia e65 Cellular Phone
Update failure0-screen frozen
if you dont have the charger in while updating your battery can die and then ur psp is left with no brain.. you can unbrick it but you need to get step by step instructions from me
Jun 22, 2009 | Sony PlayStation Portable (PSP) Console
User instructions
Hey Alan,
You can download the manuals at
They will be under "customer support".
Click on "Product Manuals" and it'll give you a step by step on how to download the manual.
Hope this helps,
Mar 25, 2008 | Motorola Mobility RAZR V3
Tomtom One Europe v2 GPS Receiver Logo
134 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
