Question about Nikon Coolpix L11 Digital Camera
A red clock flashing and keeps taking pictures. how do i turn thsi off.
  • 423 Answers
You need to set the correct Time and Date in the camera menu. You'll find it in the setup menu. Let me know if you need more information.
Posted on Feb 18, 2009
A red lightning arrow keeps flashing on the screen and the camera isn't doin anything,what can the problem be?
Hi.
A red flashing lightening bolt can mean different things on different camera's. The most common are that you are too far away from the object you want to take a picture of. That the flash on the camera needs to be turned off and that the flash itself is charging up and won't allow a picture to be taken.
Try turning the flash off and see if it will let you take a picture.
Regards.
May 01, 2011 | Cameras
Red flashing clock in right hand side of LCD
Sounds like you have the self-timer turned on. If you press the shutter button and stand in front of the camera, it should take a picture of you.
Dec 11, 2009 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Remote key will not open door
hi, gareth hear
i think this mite work 4 u
get in your car and put key in ignition turn 1 turn then wait approx 15 20 secs for light in clock to go red then take key out light should stay lit, next get out of your car close door then lock it and open it, when u open car light in clock should flash 3 times, next get out of car hold lock button on your remote down and push open button 3 times (keeping lock button down and remote pointed at reciver) next lose go of both buttons and red light on key should flash 3 times at the same time as clock inside the car.
next get in your car with key! then start her up and turn off get out of car close door and push button to lock (it should lock) if not get back in start her up again and turn off, then push the door locks inside the car then open get out and your car will lock this time!!!!!!!
this will work 4 u!!!
good luck
Dec 14, 2008 | Code-Alarm Code Alarm Transponder
A red box with clock flashing?
It means you need to set the correct date and time in the setup menu. It will keep taking pictures, but it's telling you that you have not set up the correct time & date in the camera.
Dec 13, 2008 | Nikon Coolpix L11 Digital Camera
Red light keeps blinking when I try and take a picture
actually the flash ckt is having problem that is the reason the red indicater blinks. you can take photographs with flash off mode,to solve this problem you will have to contact service centre
Dec 08, 2008 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Won't Take Pictures
My nikon coolpix 4500 has the flashing red clock as well with the hands of the clock pointed to 9 oclock and a white dot on the oppostie side of the 9
Dec 28, 2007 | Cameras
After every picture I have to turn camera off to take another
the red clock means to things :
time and date are not set or the battery that keesp the time and date is drained and needs to be replaced (you can't do that yourself)
Apr 15, 2007 | Nikon Coolpix 7600 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
468 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
