Question about 2wire (1000-000005-002) 802.11g/b Wireless Adapter
My pc laptop for some reason it doesnt connect to my router it say limited access only
  • Anonymous Jan 01, 2009
    low or none strenght
  • 54 Answers
This could be caused by a couple of software issues (possibly a faulty hardware to, but lets not worry about that for now).
1. Try resetting the router by pulling the power plug out for 30 seconds and plug it back in.
2. You have a software firewall on your PC that is interfering with getting a DHCP address. Disable any firewalls and try again.
3. Your router (for whatever reason) is no longer giving out DHCP addresses to your PC. It may be hard to configure without an address too, so you may have to reset the router to factory defaults but holding the 'reset' button on the router for 10 or more seconds. It should then go back to factory defaults and the DHCP should be back on. You will have to re-enter any custom settings you used when originally setting it up.
Posted on Dec 13, 2008
Limited connectivity
Limited connectivity (this phrase occurs first inside the WIN 8 OS) means, that you have connection with your router already, but NOT to the internet. Pls. check, if you have access to internet from other computers or smartphone connected via the same router.
If so, sometimes a driver-update for your D-Link could be useful.
Check also, if other wireless adapters are working with the same frequency, this may disturb. Try to change the channel or change from 2,4 GHz to the 5 GHz Channels, if the router & your D-Link Adapter will support this.
I had the same problem with my WIN 8 - PC and I had to change the (wireless) radio-channel.
Aug 15, 2013 | D-Link D Link Dir 825 Xtreme Dual Band...
Network problem, limited access
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Feb 15, 2012 | Toshiba Satellite Computers & Internet
I have set up this device as an AP and connected it to a adsl router, which also has another pc connected to it. I can connect my laptop to the AP and can even access the router, but am unable to browse...
Search in google about how to set up a DHCP server for your router and clone the modem's MAC address, most routers have this option, the thing is some ISPs limit the use of internet to only one machine, by cloning the modem's MAC address in your router you'll make the ISP believe there's only one machine connected to the Internet. By setting up a DHCP server in your router you'll use only one IP to connect all machines using a private network, that should solve your problems. Try both alternatives, and see which one works.
Please check the legal limitations of this procedure for your country or state and have a nice day! ;)
Apr 05, 2011 | ASUS WL-330GE 802.11b/g Wireless Access...
I can't get internet access.
make sure ur pc has a dynamic ip address and that the router is configured to dynamic connection.
Jun 14, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
I show full signal on my laptop but the wireless lags or doesnt connect, and sometimes shows limited access ! What does this mean?
Other wireless devices in the home or from a neighbor can interfere with communication. try changing the channel in the router settings
May 31, 2010 | Linksys Wireless-G WRT54G Router
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default:
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
Getting limited access on my laptop
Try to re-configure your router for the wireless connection and disable WI-FI protected setup located at advanced.
Feb 17, 2009 | D-Link DIR-625 (790069292637) Wireless...
Toshiba equium A210-17i wireles problems
It doesnt sound like a problem with you laptop, rather its most likely to be the router.
People can edit the settings so that only their IP adress can connect.
If you can connect with limited connectivity, again its the router, not connecting properly.
Can you connect to any router? i take it you're not connection to your own XD
Feb 02, 2009 | Toshiba Equium 7100S PC Desktop
Limited Connectivity
connection is to the router not the desktop pc
Ignore the desktop pc
check the wireless security settings in the unnamed router and make certain that the non-connecting laptop has the same settings.
Jul 10, 2008 | Computers & Internet
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
2wire (1000-000005-002) 802.11g/b Wireless Adapter Logo
47 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
