Question about Kenmore 24032\24036 Top Load Washer
My front load kenmore elite 110.45872 shakes during spin cycle
It's shaking so much that the inner drum lining is shredding. ( the plastic between the drum and the soft rubber.) the shredded pieces are broken off and fall in the front behind the soft rubber
  • crblack97 Dec 18, 2008
    I have the same exact problem.
  • Anonymous Mar 12, 2014
    Shreds of what appear to be rubber are shaved off after running a load of wash through our machine. It seems as if the spin cycle is shredding pieces of the machine.
    Problem Solver:
  • 5 Answers
Your basket shaft is broken or the bearing are bad it probably sounds like a freight train when it goes into high spin you need your washer rebuilt but it would be cheaper to buy a new washer. to rebuild the washer it will cost aleast 800 dollars
Posted on Dec 20, 2008
My Kenmore Elite HE3 Mod 11044832 202 started making LOUD knocking noises during final spin cycle, then started to smell like something burning. Whit placis shreds in the washer.
the plastic is the drum has dropped so its eating a way the plastic on the back of the drum so no not worth fixing the mould is an easy fix just soke a cloth with neat bleach and leave over night make sure you do a rines after woulds as you don't want bleach on your cloths ok
Oct 21, 2012 | Kenmore 44832 Front Load Washer
The washer shakes uncontrollably during the spin cycle also a loud banging noise is heard during the spin cycle.....
If front load check the inner drum If it is loose at all you have a lot of problem . Very expensive.
Nov 17, 2010 | GE Washing Machines
Whirlpool cabrio loud noise during spin cycle
The inner bearing will be faulty kindly replace the inner bearings as well as water seal before that kindly check whether the drum is freely moving with out any shaking If you find any shaking means you are suppose to change the drum only
May 15, 2010 | Washing Machines
Kenmore Whasher shakes on spin cycle
unfortunetly this is common , these new frontloads spin fast even with no pedestal these things move...
make sure the locking nuts for the legs on the pedestal are screwed securely up to frame on pedestal, also could be a floor issue depending on where it is, slooping or not solid floor.
Jan 28, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite Front Loading Washer is shaking very bad when it's on the spin cycle. When i level it, it's ok for a while but slowly goes back to skaking again. Any Ideas?
there are struts on the bottom of the drum and springs on top. may try replacing these but I think if you level it well and make sure the feet are tightened down well it should stay quiet. it the feet are not tightened well they will vibrate and come out of adjustment
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
Water drains during spin cycle, but tub does not spin and appears to have dropped down. Machine does aggitate.
If you can move the tub by hand laterally - the rear main bearing has likely failed - or the drum rollers are worn.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 30, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite steam front load washer
take the shipping materail out,,remoce the 4 bolts on back of machine,,the washer should of came with a little wrench...after removing shipping bolts put the 4 white sluggs or vcaps in hole ,,pull bolts with rubber or plastic grommet..onthejob
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
Abnormal shaking during spin cycle
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite shaking during spin cycle
Moved a Kenmore Elite and when we put it back in place it vibrates loudly. We tried leveling it and that has not worked. Any ideas?
Sep 27, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore 24032\24036 Top Load Washer Logo
526 people viewed this question
Sal De
fordexpert
Robert Rankin
