Question about Roper FGP305 Gas Kitchen Range
Roper Gas Range
I have a Roper Gas Range that does not ignite in the oven, broiler, or surface burners. There are no indications of sparking coming from the spark module, so I have no sparks at any of the ignitors. There is A/C going to the unit. The spark module was just recently replaced, and was working properly, but the range stopped working after baking in the oven one time. The unit is old and I have no wiring diagrams. Could I have another bad spark module?
F1 Error
My Roper gas range is sounding an alarm call with number F1 flashing. Can anyone reveal what the code means before I call service? Thanks!!
Posted on Jul 28, 2009
Kenmore gas range when no clicking when turning the oven on
Get FREE Standard Shipping on orders of $100 or more. Details
Range: Gas burner won't spark or ignite A surface burner igniter switch and a spark module activate the spark electrode when a burner is turned to the "Lite" position on a gas range's cooktop. If the surface burner switch, spark module or wiring in that circuit fails, the spark electrode won't work, and as a result the gas burner won't light. If those components work but the electrode won't spark, the problem could be that the spark electrode is coated with spilled food of is bent or broken. In addition, the electrode won't spark or ignite the burner properly if the ceramic insulation sleeve below the tip of the electrode is cracked or broken. If the gas burner isn't lighting, these repairs may help.
Range 101
See all articles These repairs may help solve your problem:
Replace the spark igniter electrode
1396454293470.jpg The spark igniter electrode-also called the surface burner igniter-is an insulated electrode that provides an ignition spark to light a surface gas burner. It sparks and makes a ticking sound when the burner switch is turned to the Lite position. Replace the spark ignition electrode if it fails to spark or if the ceramic insulation sleeve is cracked or chipped. How to Replace a Spark Igniter Electrode in a Gas Range Find This Part
Replace the surface spark module
1377098014986.jpg The surface spark module is in the ignition circuit for the gas surface burners. When a surface burner control knob is turned to the "Lite" position, it provides voltage to the spark electrodes on the gas surface burners. If the surface spark module fails to provide the electrodes with voltage, then it should be replaced. Find This Part
Replace the spark igniter switch
1396454315355.jpg The igniter switch is an electrical switch on the stem of the gas surface burner control valve. This switch completes a circuit to the surface burner spark module, causing the burner igniters to spark when the burner switch is turned to the Lite position. Replace the burner igniter switch if the burners don't spark when you turn the burner control knob to the Lite position or if igniters spark constantly even when the burner knobs are in the Off position.
May 27, 2014 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchenaid kgss907sss neither the broiler nor the oven will heat with fire. the elecricburner does work however but does not heat well enough. i can hear the igniter click once after turning it on but...
For broil burner ignition an oven broiler burner spark electrode is used to ignite the gas. The electrode is a device that sits right next to the broil burner. It functions like a spark plug. As power is applied to it a spark jumps from the spark electrode tip to the to the electrode shield, igniting the gas. If the electrode is broken or worn out the spark may not occur or be intermittent. Visually inspect the electrode assembly for cracks in the porcelain housing or damage to the electrode tip itself. Be aware that a proper ground and the correct polarity of the incoming voltage to the range is necessary for the electrode control to sense the presence of a flame once the burner is ignited.
there is also a spark control module but I don't think that's it usually no spark when bad.
if you need or want parts ck here for your unit.
hope this helps a little
https://www.repairclinic.com/Shop-For-Parts/-x6b677373393037737373/Kgss907sss-Parts
Jan 05, 2018 | KitchenAid KGSS907SSS Gas Kitchen Range
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
Kenmore oven won't light
If the broiler still works and the surface burners light, you more than likely have a bad igniter on the bake manifold. The following link epxlains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
The broiler and bake manifolds have separate igniters, but share a common regulator and safety valve. So, if the broiler works, you don't have a gas problem. The surface igniters use electrodes to ignite gas which are fed from a spark module. So, some deductive reasoning can easily determine what the likely problem is.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites also include helpful exploded view diagrams to assist you in locating and properly identifying the parts you need.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Mar 05, 2010 | Hotpoint RGB745 Gas Kitchen Range
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Oven doesn't light. I have a Maytag MGR5750. The pre-heat light comes on but no ignition. Stove top burners work okay.
    First thing to do is verify if the hot surface igniter or spark igniter is working. If the oven has a bottom broiler compartment then you can check from the bottom compartment. If it has a top broiler then you may need to remove the inner bottom cover inside the oven to look at the burner and igniter. Now turn on the oven and watch for the hot surface igniter to start to glow or the spark igniter to come on. If the igniter comes on then give the gas control valve(located at the bottom broiler/storage compartment) a tap with a wrench or a screwdriver. If the burner comes on then shut the oven back off and on several times COMPLETELY. If it works then you may have fixed the problem by dislodging debris in the valve. If it does not come back on then the gas control valve may be defective or the igniter could be weak. The igniter should be tested with a ohm meter and if it tests good(500-700 ohms usually) then the gas control valve will need to be replaced otherwise the igniter is bad. On spark ignition systems there is a different procedure. Another thing to check is the "runaway valve" that is located on the gas regulator for the range. It is a little lever located where the oven gas pipe comes off the regulator and cuts the gas to the burner when closed.
    Oct 16, 2009 | Maytag Kitchen Ranges
    Why does the surface burners and broiler light but not the oven burner on my Kenmore gas range? Kenmore gas range around 14 years old the model number is 362.7352192. We were using the oven and in the...
    The oven gas valve coil has failed Need to replace. Go to repairclinic.com and put in the model and order the coil for the valve. It controls the gas valve.
    Sep 11, 2009 | Kitchen Ranges
    How do I utilize the self cleaning part? Do I just press ''clean
    1. After self cleaning the range the door won't open
    2. Amana gas range conversion from NG to propane
    3. A tip on cleaning the surface grates
    4. Checking an common oven temp sensor
    5. Checking an common oven temp sensor: What does an oven temp sensor look like?
    6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
    7. GE gas range conversion from NG to propane
    8. How to change the oven temp on some common electronic controlled ovens
    9. How to re-light a surface or oven pilot light
    10. How to change a common oven glow igniter coil
    11. How a common gas valve works - click here.
    12. How Ranges, Ovens, and Stoves Work
    13. Help for storing an appliance
    14. Important Disclaimer
    15. Installing a gas flex line connector
    16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
    17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
    18. My gas range flames die when I turn on more than one thing at a time
    19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
    20. My surface burners keep "clicking" even after the burner is light
    21. Oven door and door hinge help
    22. Oven temp sensor - how to change helps
    23. Repair tips and information on surface burner spark modules and igniters
    24. Some "how to set the self clean" on my range
    25. Stainless Steel Cleaning
    26. Surface burners wont work
    27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
    28. Test for F1 fault code
    29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
    30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
    31. Whirlpool Direct Spark Ignition (DSI)
    32. Yes, your glow bar igniter can glow red and still be bad!!
    Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
    GE Profile Gas Range oven light doesn't work even after changing
    Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    No spark to top burners, oven & broil will not light
    it sound's like the spark module you might be going in too deep
    Nov 06, 2008 | Frigidaire FGF326AS Gas Kitchen Range
    Roper FGP305 Gas Kitchen Range Logo
    1,033 people viewed this question
    Top Roper Kitchen Ranges Experts
    Justin Duby
    Justin Duby
    Dan Webster
    Dan Webster
    Craig Butler
    Craig Butler
    Are you a Roper Kitchen Range Expert? Answer questions, earn points and help others
