Question about Toshiba (K000006610) for Satellite P25 Series Motherboard
Laptop won't run on ac power and keeps shutting down
Toshiba P25 laptop won't run on ac power alone and replacement battery didn't help and replacement power cords didn't help; sometimes it will run fine and other times just shuts down out of the blue. i love my laptop but miss her
  • mikeyman14 Dec 20, 2008
    I just took my computer in for the same issue. Two weeks later it's broken again. I'm was told by Toshiba that the pin is part of the motherboard and the best "fix"is to get a new one. Well the MB is 330 bucks so does anyone know where to find a less expensive option?
    Thanks
  • blayson463 Jan 30, 2009
    I have same problem, sometimes the unit will run fine for hours then just quit. not shutdown, just stop. In a very quiet room, I can hear and slightly feel the fan nearest the AC plug come one briefly.
    Sometimes I can get the ac cord in just the right position and it will run but if anything moves it stops.
    When I am inserting the power plug, the battery light may come on or may not. If I can get the male plug positioned just right then the battery light stays on and I can operate for quite a while unless the cord moves.
    It will rarely run with just the ac and no battery.
  • Toshiba Master
  • 19,396 Answers
Check that the AC power works, go to a repair shop and test a different one or have voltages checked with a multimeter.
If the AC adapter is fine, then it is usuall because AC socket solder joints on laptop are broken. In this case , it is a delicate repair, and must be done by an expert repairman.
Posted on Dec 13, 2008
WHAT DOES BLINKING BATTERY INDICATOR LIGHT MEAN ON A TOSHIBA SATELLITE LAPTOP P25-S5093
maybe the ac adapter is burned up or outlet bad or the ac jack on computer is bad.
Jun 17, 2012 | Toshiba Satellite (p25-s5093) PC Notebook
Whenever i use my laptop's powersupply, my laptop unit hangs. instead i could only use my laptop using the battery alone and not with the power supply provided. my laptops model is toshiba satellite...
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adpater. Make sure the apdapter outputs correct voltage. It's possible that the outup voltage is not correct and the laptop shuts down to prevent the damge. Test your laptop with anohter known good power adapter.
If the problem still exists, even after replacing the adapter, most likley it's the motherboard failure. Replace the motherboard.
Reference: Toshiba Satellite A205 Power Adapter
Jan 17, 2011 | Toshiba ADP-75SB AB AC Adapter - 90 Watt...
My Toshiba P25 s526 will power on. The AC is connected. The ac and battery lights are on. The battery discharges and the unit turns off with in 2 min.
Ok take out the battery and plug the AC in and power on to see if it works. If it does then it shouldnt go off after 2 min. but if it doesnt power that means there is a problem with your AC that is why it turns off.
I hope this solution has been helpful.
Sep 26, 2010 | Toshiba P25-S526 Notebook
My toshiba P25-S676/80 will not turn on. No
May be a bad power jack or the powercord/ac adapter may not be putting out enough power.Your powerboard may need to be replaced or even the button itself may not be getting contact to the board itself.
Jul 11, 2009 | Toshiba Satellite A60 Notebook
When I power 0n it shuts down immediately
sometime some keys are pressed, check your keyboard
Jun 28, 2009 | Toshiba Satellite P25-S507 Notebook
I have a HP NC 6120 laptop.I have the batt in and the PS plugged in.All that happens is the Charge Light Blinks yellow 6 times then green 1 time,repeats.At the sametime the power light comes on for 6...
Remove the battery and then press the power button for 45 sec then refix the battery and check that the machine is turning on or not?
If the laptop is not working on AC alone then this is the issue with the converter which is there on the motherboard.
Feb 19, 2009 | Toshiba (K000006610) for Satellite P25...
P25-s609 display
When you say you turn it on, do any of the lights on the laptop light up? Does it make any beeps?
Have you done anything to your laptop or has anything happened that you think might have caused this?
Start off by simplifying your setup as much as possible to eliminate any outside influences.
Remove anything plugged into the laptop. Then unplug power and remove the battery. With battery out and power disconnected, hold down the power switch 15 seconds (this can clear out a corrupt BIOS).
Reconnect only AC power and try to power up. Verify your AC power has a power light lit up and all connections are snug.
If no go, try only with the battery and no AC.
Still no go, remove battery and any removable drive (CD, DVD, etc.). Connect AC power and retry boot.
If you feel comfortable removing the hard drive, remove it and retry boot.
If all drives are out, all external and internal devices removed and still no display, try removing the memory and putting it back in (reseating it).
Let me know if that helps or if you need further help.
Honest1abe
Dec 30, 2008 | Toshiba (K000006610) for Satellite P25...
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Shutting down
Does it cut out on battery?
How often does it cut off?
Does it just die (no lights or anything) or reboot?
Jan 14, 2008 | Toshiba (K000006610) for Satellite P25...
Computers & Internet Logo
1,100 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
