Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
Where we store the password in windows xp..?
When we give a password in xp,the password suerly store in a particular place...Do U know which is that place..?
  • Microsoft Master
  • 4,806 Answers
Mantelo is right and it is the .SAM file you need to locate, if you plug the hard drive up to pc as a slave device you will be able to locate this file within the windows folder, use notepad to open it
Posted on Dec 13, 2008
  • 81 Answers
The password is store in the SAM, which is encrypted. If you want to recover a password, you need a password cracker like this
Good luck
Forgot administrator password for xp
Start a windows xp system up in safe mode
then click on control panel ten user accounts then the specified user which is password protected and it allows you to change the password without knowing the original one.
Restart the computer.
Repeatedly press the F8 key until the Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys
then press the ENTER key.
Choose "Windows XP Home/Professional" depending on the version of the operating system. Press ENTER.
Shortly, the welcome screen should show.
Log in as "Administrator"
Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control userpasswords" (without the quotes). Click OK
Select the "Administrator" user.
Click Change my password.
Enter a new password in the corresponding text boxes.
Click OK. Write this password down and store it in a secure place. I do not recommend that a password hint be used.
Close the User Accounts window and restart Windows.
hope this helps
Oct 29, 2012 | Dell Inspiron 9300 Notebook
Tip
Create Windows XP Password Reset Disk
Did you forget your Windows XP User password? You can click the "?" button to see your password hint.Or you can use your password reset disk. This article describes how to create a password reset disk for a computer that is not a member of a domain in Microsoft Windows XP.(that is part of a workgroup, or that is not connected to a network.)
What is the Windows XP Password Reset Disk?Do you need to enter a password when booting into Windows XP Pro? Afraid you might forget this password down the road and not be able to run your PC? Make a password reset disk to protect against a lost password.
Note: You may want to know how to create a user login password to protect xp.
To protect user accounts in the event that the user forgets the password, every local user should make a password reset disk and keep it in a safe place. Then, if the user forgets his or her password, the password can be reset using the password reset disk and the user is able to access the local user account again.
The Forgotten Password Wizard lets you create a XP password reset disk that you can use to recover your user account and personalized computer settings if you forget your password.
How to create a XP password reset diskTo create a password reset disk for your local user account, use the following method.
RequirementsThe following methods require a floppy disk drive and a blank floppy disk. As we all know, the floppy disk is easily damagedand it is out of date. In this demonstration, I will use a blank USB Fash Disk instead of floppy disk. Firstly make sure it is connected with your computer.
1. Click Start, and then click Control Panel.
2. In Control Panel, click User Accounts.
Note: If you're viewing the Classic View of Control Panel, double-click on the User Accounts icon.
3. In the User Accounts pane, click the account that you want to work with. Here I will click my account name "Andy".
4. Under the Related Tasks left side options, click Prevent a forgotten password to start the Forgotten Password Wizard, and then click Next.
5. In the drop-down menu, there are 2 options for us to choose. One is Floppy A, another is WPKEY (It is the name of my USB Flash Drive). Select the WPKEY and then click Next.
6. In the Current User Account Password box, type Andy's password , and then click Next. The Forgotten Password Wizard will start creating the disk.
Note: If the user account does not have a password, just leave it blank in the Current user account password box.
7. When the progress indicator shows 100% complete, click Next and then click Finish in the next window.
The password reset disk contains only one file called userkey.psw, which is an encrypted version of your password.
Finally Label the disk "Windows XP Password Reset" and store it in a safe place. You can use the password reset disk to gain access to your Windows XP-based computer if you forget your password.
Tips:
1.
You only need to create a password reset disk for your Windows XP logon password once. No matter how many times you change your password, this disk will always allow you to create a new one.
2. Keep in mind that anyone who possesses this disk will be able to access your account at any time, even if you change your password.You'd better store it in a safe place.
3. Not a Windows XP user? See the guides for other Windows versions.
How to Create a Windows 7 Password Reset Disk?
How to Create a Vista Password Reset Disk?
4. Unfortunately, if you've forgotten your Windows XP password and can no longer acceses Windows, you won't be able to create a password reset disk. Luckily there is a Windows password recovery program which can help you to find lost password. It is popular way of getting your password back, even you don't have a password reset disk. You can download the free tried Demo on clicking below link.
Windows XP Password Recovery Program [Safe Download]
on Mar 25, 2011 | Computers & Internet
Did a fresh install of Windows XP with new media disk, but after the installation, I can't get past the admin password and log in
Restart the computer. Repeatedly press the F8 key until the Advanced Boot Options screen appears. Select the Safe Mode option using the up and down arrow keys
then press the ENTER key. Choose "Windows XP Home/Professional" depending on the version of the operating system. Press ENTER. Shortly, the welcome screen should show.
Click Change my password. Enter a new password in the corresponding text boxes.
hope this helps
Sep 10, 2012 | Dell OptiPlex GX280 PC Desktop
Problems with Acer laptop running XP, can only get wirless access if there is no wireless password
Chances are that it is still remembering an old password somewhere in the properties... dig through the options an properties to see if there is a place to enter a password that may be overriding the one you are entering when you try to connect.
I know it sounds wrong, but I've run into this before on Windows 7 laptops and have found a previous password embedded in the properties that (once the correct password is entered there) solves the problem.
Nov 01, 2017 | D-Link Wireless N 150 Home Router
I seem to not be able to get logged in..
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer Advanced Boot Options screen appears.
Select the Safe Mode option using the up and down arrow keys, then press the ENTER key. Choose "Windows XP Home/Professional", depending on the version of the operating system.
Log in as "Administrator". Click Yes to not use System Restore Mode.
Click the Start button. Choose Run and type in "control user passwords" (without the quotes). Click OK.
Select the "Administrator" user. Click Change my password. Enter a new password in the corresponding text boxes. Click OK. Write this password down and store it in a secure place Close the User Accounts window and restart Windows.
hope this helps you
Nov 22, 2011 | Microsoft Windows XP Professional for PC
Help me.. i have forgotton my bloody password :) PLEASE HELP ME :L :L :L just give me words and stuffff :D
Reboot, at startup press F8 to access the safe mode menu. As long as you've never set a password for the administrator you should be able to log into safe mode as the administrator without a password. From here, go into User Accounts and select your user name and reset the password from there. In there future, you will want to place a password on your administrator account to keep someone from changing your password or having unauthorized access to your system.
Feb 13, 2010 | Microsoft Windows XP Home Edition
Running a wireless network at home DLink DI-524
Hi there securing your wireless is not that much tough.I will guide you with some simple methods.
Windows XP
1.open the control panel and go to network connections and right click the connection that is active and select properties and select tcp/ip and click properties and change the ip settings to automatic.
2.Now connect the pc/Laptop to your wireless router through wired port.
3.open your internet explorer and type 192.168.0.1 in the address bar.The login page of the router will open.In this page give the username as "admin" and password as "admin" in some router the password will be "password" ( this passwords are default.if you have changed the password login with that password)
4.Now you will be logged into the router's page and you can see the settings of the router.In that go to the wireless security and enable it.
5.You can have two type of securities one is WEP and other is WPA.Select anyone and give the password for this security.
6.Then save the settings and restart the router.Now your wireless network is secured.If you are connecting through wireless you need to give the password that you gave for WEP/WPA.
Hope your problem might be solved.Feel free to get my assistance.
May 16, 2009 | D-Link AirPlus DI-524 Wireless Router
HDD password
Open the cabinet remove the batter y leave it for 10 minutes then CMOS setting will be restored to original one.
or
Use CMOS jumber to short to wipe out CMOS memory (After shifting jumber start the system check BOIS access then turn off the system place the jumber back to its position). I jumber not placed back what ever setting is made in BOIS will not stored in memory for future use since there is no continous power supply for CMOS after system turn off.
Jun 22, 2008 | Toshiba Axiom 60GB HDD Satellite Pro 4300,...
I want to know my Administrator Password
Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD) 2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
Feb 26, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
35 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
