Question about Audiofonics ADF-242 Car Audio Amplifier
Amp fan not working
I have an audiofonics adf-242 and the fan isn't working and the amp is getting to hot...is there a way i can fix it?
  • 62 Answers
If you have any experiance with electronics remove the casing and check the fan with a external 12V power source. If the fan still does not work, it needs to be replaced, try and get a brushless fan as it will last alot longer.
Posted on Mar 26, 2007
Audio fonics amp ADF-2845
you dont have enough power for it. sell if for parts and buy a smaller amp and second battery.
Sep 20, 2013 | Audiofonics Car Audio & Video
I have a ADF-242 that is having sound output problems
If the car was running when testing sub and heard noise this could be engine noise and an inline filter would cure that problem and also have a good ground no more than 15 inches away from the amp.And good metal contact for ground.
Jun 06, 2010 | Audiofonics ADF-242 Car Audio Amplifier
Audiofonics ADF-240 Car Audio Amp
Hi There buddy.
I have on many occasions had problems with the actual LP/HP/Full Range selector switched on the amplifiers.
Remember that the input signal runs through the switches before it gets to the main amplifiers.
Check that out and let me know.
Oct 30, 2009 | Audiofonics ADF-240 Car Audio Amplifier
Will not put out sond
Hello billyelder,
If the amp is powering up but not producting any sound, there are 4 possible causes.
1) Incorrect or faulty wiring.
2) No input or input too low for the amp.
3) Defective speakers.
4) Incorrect amp or head unit settings.
Start by checking all of the wiring and onboard fuses. Especially check the speaker wiring and make sure there are no shorts or grounds and that the insulation is not nicked or frayed. Check the RCA cables by substituting a known good pair. Check the receiver (head unit) to see if there are any settings that need to be turned on for the preamp outputs to work.
Test the speakers on another output to determine that they are functional.
Check the amp settings and insure that filters, crossovers and gain controls are properly set. If your wiring and the settings all check out and the speakers work on another output, the amp itself is probably defective.
Hope this helps.
Sep 01, 2009 | Audiofonics ADF-241 Car Audio Amplifier
Looking for audiofonics adf-240 owners manual.
There may be a loose wire to the lights, or the power supply or amp may have a problem. Do you have the amp mounted to your sub box directly? You shouldn't. The vibrations from the bub will kill the amp in a short amount of time. If it is noticeably weaker, you should check out all aspects of the system. For instance, if you have a dual voice coil sub, is one coil open? Is one channel on the amp bad? Is half of the power supply on the amp bad? hence half the power, and no lights?
Jun 11, 2009 | Audiofonics ADF-240 Car Audio Amplifier
Audiofonics adf-241 no power all wires connected fuses ok.
Hello pimprascalz,
Many amps will go into protect mode if one of the speaker wires is shorted or grounded, or if the voice coil(s) are defective. Try disconnecting the speaker wires one at a time and see if the amp still goes into protect upon power up. Likewise, some amps will go into protect if one of the inputs is grounding out. Again, to troubleshoot, disconnect them one at a time and try the amp. Next, make sure that the amp itself is not grounding. Most amps need to be mounted to a nonconductive surface. If the case contacts the frame of the vehicle, it can cause a problem. If the problem is not in the speaker wires or the input cables, the amp case is not contacting the vehicle frame, and you have checked your power, ground and turn-on leads, then the amp itself is probably faulty.
Hope this helps.
May 19, 2009 | Audiofonics ADF-241 Car Audio Amplifier
BLOWN FUSES
If the fuse only blows when the amp is driven hard, the impedance of the other speakers is likely too low.
Sep 21, 2008 | Audiofonics ADF-243 Car Audio Amplifier
My amp
4 CHANNEL-1100w MAX
HIGH ENDURANCE SLIM AMPLIFIER
4 CHANNEL [2 OHM] 110W x 4
4 CHANNEL [4 OHM] 80W x 4
2 CHANNEL MONO [4 OHM] 220W x 2
2 OHM LOAD CAPACITY
VARIABLE LOW [40-250Hz] PASS FILTER
VARIABLE HIGH [40-250Hz] PASS FILTER
BASS BOOST
RCA PRE-AMP LINE OUT
SPEAKER LEVEL INPUT
http://www.bcae1.com/repairbasicsforbcae1/repairbasics.htm
This is a really good site to learn about repairing amps and anything else you want to know about car audio. Are you wanting to replace the board or looking for someone to repair your amp.?
Apr 18, 2008 | Audiofonics ADF-242 Car Audio Amplifier
Audiofonics
i would go with the 801.And ithink u meant the 4501 not 4051.Both super power amps. competition stuff.your woofers are 4ohms dual voice coils.so you can series the coil on eaach woffer and use the two channels on the amp.they play at 2ohms.I think if you drop it down to 1 ohm you really be taxing you alternator that is series power.Yioou would need a special alternator.Even with them running in 2 ohms you better hav eat least a 2 farad cap.OR two batteries.. ! more thing don 't pump it up with window s closeed .you'll pop them.serious dbl. you be pumping.I'm jealous.Rating please and enjoy.
Feb 09, 2008 | Audiofonics ADF-272 Car Speaker
Audiofonics amp
Reconnect one speaker per channel and swap the RCA cables (L > R and R > L) to see if the working channel switches sides. If not, move all switches and controls to see if any are intermittent.
Jan 10, 2008 | Audiofonics ADF-241 Car Audio Amplifier
Audiofonics ADF-242 Car Audio Amplifier Logo
125 people viewed this question
Top Audiofonics Car Audio & Video Experts
Dalynn Turner
Billy McCain
Billy McCain
Level 1 Expert
Bill Boyd
Are you an Audiofonics Car Audio and Video Expert? Answer questions, earn points and help others
