Trying to understand the rating of a blown fuse inside a cheap Onyx DVD bought at Asda a year ago.Voltage is clearly legible at 250V, but no understandable (to me) current rating.Any ideas?Thanks
  • 116 Answers
Look closly at both ends if not the rating should printed somewhere near the fuse holder.
Posted on Dec 13, 2008
NAD T760 FM stereo not working
Hello
There are three fuses with your NAD surround receiver.
Reference No Part Number Description
M751*AH 5120-0200-0 Fuse 5A 125V Time Lag 5x20 MM MITI/UL/CSA
M754*AH 5120-0052-0 Fuse 1.6A 250V Time Lag 5x20 MM UL/CSA
M752*C 5120-0024-0 Fuse 3.15A 250V Time Lag 5x20 MM SEMKO/VDE
Check them first and inform me which one has blown out. I'll give you detais after that. OK.
Oct 26, 2011 | NAD T760
Possible blown fuse in my sony BDP-S570 Blu ray player... how do i check the fuse and then , if need be, replace it?
If the fuse is indeed blown, check what type it is. Either a small glass tube with metal end caps, which clips into a holder on the board (standard), or it may be soldered in place (and look like a resistor) (fusible resistors operate in a similar way to fuses). Check the voltage and amperage rating of the fuse itself (for example, a 250V 1.6A). To determine whether the fuse is OK, or open-circuit, you would need a multimeter (set on the lowest range) to measure continuity of the wire inside. If the meter reads 000 (or similar), the fuse is fine. No reading - replace fuse.
Checking the fuse is the easiest and cheapest option; do this first. If the replacement fuse blows in the same manner, then it's a fault in the power supply which will require professional workshop attention - and could be expensive.
May 03, 2011 | Sony BDPS570 Bluray 3D Player
No indication of power. Is there a fuse
Has a 3.15A 250V fuse inside.
If it is blown, there must be a reason unless it was just a defective fuse or a surge.
I hope this helps, if so please rate our solution.
Mar 14, 2010 | HP Compaq FP 7317 17" Flat Panel LCD...
I got the ch-DVD 300 no power anymore, I opened and I saw the fuse blown out,where can I get a new one? it says T2AL-250V and measures 3/4 of inch.
This is not a good solution but it is one I have used for extreme situations.
Take a single strand from an old cheap lamp cord and solder it across the ends of the fuse. This will create a new fuse of approx. 1 amp. I made a safe cross country flight in a private plane by making a temporary fuse when a new one wasn't available.
Feb 22, 2009 | Cyberhome CH-DVD 300 DVD Player
Fuse blows when I press ''Start''
Okay, the part you're describing is the magnetron, and you'll not find one cheap.
The good news is that this is probably not your problem.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/cap_test.html
http://www.gallawa.com/microtech/xformer.html
The best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835
Nov 21, 2008 | Microwave Ovens
Fuse T1.6L250V
The fuse which you have used is of correct rating 250v/5A, the switching regulator of the SMPS primary section is faulty, so the fuse blows of continously
Dec 22, 2007 | RCA DRC200N
Panasonic CT-32HX42F Powers down by itself
it is due to plug or socket loose or sparking in that area. if it is ok then it is due to some component failure in power supply of tv. as per schematic is concern please go to. www.serviceinfo.com go in search & give model no.it is freely available.
Oct 04, 2007 | Televison & Video
No Power... need a new fuse.
While wiping off the dvd vhs player it went out. Said it did not recognize the tv anymore. My son put it on his tv and got a half screenof the movie. just took out the fuse t2al 250v. what is my problem?
Sep 11, 2007 | Cyberhome CH-DVD 300 DVD Player
Fuse blown
the fuse will always blow if there is a shorted component. the horizontal output transistor may be the most likely culprit, if you are not a technician, have it service by a qualified one.
May 15, 2007 | Samsung TXR3079 TV
Televison & Video Logo
94 people viewed this question
Top Televison & Video Experts
