Question about Epson Stylus CX4600 All-In-One InkJet Printer
Printer Problem color inks are empty, but I have a full cartridge of black. It seems as if it won't print until I replace the red, blue and yellow cartridges.
  • Epson Master
  • 691 Answers
You are correct. You must replace ANY cartridge that the machine reports as empty to be able to print.
Posted on Mar 15, 2007
How can I print when one of my ink cartige is ementy?
Hello, Keith -
You cannot. You will need to install a full ink cartridge for the ink which is currently depleted.
Even for just black print, even if the black ink cartridge is not empty, these days, most if not all color printers use a combination of the color inks, cyan (blue), magenta (red), and yellow with the black ink to print black and shades of gray. The printers are designed only to print with ink in all the cartridges.
Best wishes.
Jun 11, 2018 | Office Equipment & Supplies
Cannon Pixma MG5520 printer
Remove all cartridges, clean the ink from where the cartridges make contact with cloth,(paper towels can leave trash in there) be sure all is clean then replace the cartridges and print something. Those streaks shouldn't be there any longer.
Sep 09, 2014 | Office Equipment & Supplies
I have enough black ink to print a few pages in black, but the printer won't print. What do I do?
I had a Epson printer that would not print or even allow me to use the scanner because the colored ink was out. Even though I had full black ink, it still would not let me print until i replaced the colored ink.
Sep 25, 2012 | Lexmark 90T6005 Prospect Pro205 All-in-One...
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
AND
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Only prints in green and blue
You are more than likely out of magenta (red) ink. That printer uses a tri-color cartridge, and it has cyan (blue) magenta (red) and yellow ink. Green is blue + yellow-therefore you do have those two colors; since it will not print anything red or black you will need to replace both cartridges.
Mar 05, 2010 | Dell 810 All-In-One InkJet Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
HP C6280 with new ink cartridges shows cartridges empty
First make sure you are placing the right
color cartridge into the right slot.
Most Printers are touchy about the
installation of ink cartridges. If the
instructions say to press the cartridge
into the slot until you hear a loud click,
that's what they mean. If at first you
don't succeed, remove the cartridge and
reinsert it into the slot again and press
on it hard till it clicks.
Then your printer should work properly.
Hope this is of some help. Bud
Feb 03, 2009 | HP C6280 All-in-One Printer
Printer says ink near empty
Black electrical tape works like a charm on a Brother MFC-465CN. Thanks for the tip! :-)
Jan 16, 2008 | Brother MFC 210C All-In-One InkJet Printer
Dissapearing yellow
I run about 100+ canon printers from s800 up to the new ip4500.
I have met and solved almost every problem I find described on the web. Your problem with the disappearing yellow ink can be only one thing. The ink cartridge has not been sealed after you injected the ink. If there is even the smallest avenue for air to get into the cartridge it will allow the ink to flow very rapidly back out of the cartridge and into the waste ink pads in the bottom of the printer. You won't be able to see a puddle of ink under the printer until much later when you have done many cleanings or installed many leaky cartridges.
Dec 23, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
