Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Hello my name is veronacarrier 8000 weathermaker will not ignite
I have a carrier 8000 weathermaker with humidafier i can not get it to ignite it was just working 3 days ago now ihave did what is on the cover of the funance door as far as turning down thermastat to lowest setting turning off the power to the furnance ingluding the air conditiner the off the gas switch in side furnance let it stayoff for 5 minutes then turn on gas switch then all power to appliance i did the power off from the breaker then turned on heat put it to 70 still did not ignite my air and my fan still opporate correctly i use to hear when it woud come on i look in furnance to see if i see it ignite but it doesnot i do not even see a flame it is suppose to autimatalicly.please can anyone help freezing in maryland.thank you
    Novelist:
  • 124 Answers
Call the furnace repairman. you have a fairly easy repair but the parts are expensive
Posted on Dec 13, 2008
Heat exchanger replacement for carrier weathermaker 8000
After 18 years of service, it is not cost effective to just replace the heat exchanger. Go the complete replacement route. There may be a utility company incentive to do it.
Jun 06, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
Why wont an older model carrier gas furnace light when standing pilot light is lit at all times? Why would there be no gas at the burners
when it comes to GAS appliances , I do not recommend any self fixes . they can explode and do you serious damage even up to death .call a gas furnace repairman
Feb 28, 2016 | Carrier Weathermaker 8000 Gas Furnace 125k...
I am hearing a little bit of squealing noise when running the ventilation fan in my house.
Sounds like you have a bearing going in the blower unit or a loose belt. Get it serviced by a reputable service company.
Oct 20, 2014 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 58TUA doesn't work
The switch could be defective but more likely the furnace blower is failing.
Dec 17, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
Weathermaker 8000 not enough heat
Are the tips of the flame blue? You might need to adjust the air mixture sleeve on the burner.
Feb 05, 2013 | Carrier Weathermaker 8000 Gas Furnace 125k...
I have a Carrier Weathermaker 8000 furnace. it will not light.I tested the igniter on my upstairs furnace and it will glow and light that furnace. I can manualy light the furnace with a match. flame sensor...
If you're sure the igniter is good and the controller is sending voltage to gas valve to open, but not to the igniter then, yes, the controller is bad. The only way to know for sure is to remove the igniter's molded plug from the board and test voltage directly at the board. You should get about 100-120 vac to the igniter.
Mar 25, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
My Carrier Weathermaker 8000 a few days ago the air began to blow non stop and the burners are not igniting. I am getting Code 33. I did all the resets, unplug control board, switch to air condition...
You need to look at the wiring diagram pasted on the door panel to get a starting point where to look. I suspect a bad pressure switch, jump it out and see if it starts.
Mar 09, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Heater is on firing up- everything seems ok but there is nogas-goes thru the cycle with igniter glow orange but does not ignite- there doesnt seem to have any gas present to ignite weathermaker 8000
the igniter has to have proper omhos to open gas valve.
recommend replacing igniter. be careful not to touch new igniter with bare hands. oils in the skin of your hands will cause the igniter to get too hot and burn out quick
Dec 09, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
457 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
