Question about Dell Dimension 3000 PC Desktop
Memory Issue Hi there, I'm having a RAM problem. I recently bought 2 GB (2 x 1 GB) of RAM. When I install it, I just get a buzzing sound, it sounds kind of like a low-pitch version of a truck backing up sound. The power light lights up, but the monitor shows nothing. The monitor button also changes from green to orange. It might be the new RAM, because when I plug in the old ones it still works. Please get back to me asap. Thanks
    Problem Solver:
  • 7 Answers
Hi there..... check to see if your machine supports the type of ram you bought.....ie, ECC or non ECC and if it is the same speed like PC2100....some speed families will clock up or down to allow slight differences but not always.....and in some cases you may just have defective RAM! Hope this helps.
Jay
Posted on Jul 30, 2008
  • 23 Answers
Hi, your problem is caused by a defefective dimm, I recommend you to claim warranty
Posted on Jan 21, 2008
  • 944 Answers
Have a look at this thread http://www.fixya.com/support/t136790-dell_e510_memory and see if any of that helps you - are you sure that you have exactly the right type of ram? - jut because it fits the slots doesn't mean it is supported by the platform. hope this helps:)
Posted on Mar 10, 2007
SOURCE:
Driver memory stick
Try putting the ram in another computer and see if you have the same problem. If the issue goes away one of the sticks of ram might not have been fully seated. If you get the same result you have a bad stick of ram. Go to the manufactures website and download ram checker and install it (free software). This will help diagnose your problem. If you get an error code write it down so you can give it to the manufacturer which indicates which error problem you have... If it turns out that you have a bad stick of ram contact the manufacturer and they may send you another stick of ram. Some manufacturers have a lifetime warranty on their ram. Hope this helps.
May 11, 2017 | Kingston 4GB Secure Digital High Capacity...
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
hello
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/specs.htm
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
(non-ECC)
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
RAM capacity & Soundcard Driver can not be installed
this is the ram specs.
Max Supported RAM2 GB
Memory TypeDDR2 SDRAM Supported RAM Speeds400 MHz · 533 MHz what sound card do you have ?
Apr 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Acer Aspire 9410 Won't work with two memory slots filled
As you mentioned that you want to use Maximum memory that is supported by 9410, I would like to tell you that you have 32 bit processor in your notebook as its not always advisable to use 4 GB RAM with 32 bit processor as we have seen lots of compatibility issues.Infact in 32 bit processor windows will typically report only 3.2 GB due to a limitation of windows itself.
Mar 25, 2009 | Acer Aspire 9410-4317 Notebook
4 GB at the begining, now 2 GB???
Hi
where did you see that the computer had 4 GB of ram? ram can only be removed by removing ram memory modules from inside the computer.
Dec 28, 2008 | Acer Aspire 5580 Notebook
RAM NOT DETECTING
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Toshiba a105-s101 memory install boot issue
Check your owners manual to see if the laptop will support 2GB of ram. If not you will need to use 2 512mb sticks to get to 1 GB
BPCS
Dec 27, 2007 | Toshiba Satellite A105 Notebook
Dell Dimension 3000 PC Desktop Logo
135 people viewed this question
Clive
Clive
Alun Cox
