Question about EliteGroup L7VMM2 Motherboard
Cant get any picture through the moniter tryed agp vidieo card and pci vidieo card still nothing the motherboard is out of emachines c2280 L7VMM2
    President:
  • 2,992 Answers
Sounds like you have a bad power supply or motherboard. The power supplies in eMachines are not known for reliability, so try testing the system with another one. If you still have no video, you should replace the motherboard.
Posted on Dec 13, 2008
What type of graphic card are compatable with emachines T3624 Pc's
Hello here are the homepage:
http://support.gateway.com/us/en/emac/product/default.aspx?modelId=1581
This mainboard has the PCI-e graphic card socket, and a AGP graphic card will not fit and run on it.
A PCI-E graphic card, can be bought in a computer store or online.
Does the pc boot at all ???
If not try to renew the power supply.
Good luck
Mar 31, 2013 | E-Machines EMA IMPERIAL GV (845GV) TG3...
Installing Graphics cd in AGP slot...
Usually you need to disable the on-board video/activate the AGP slot in the BIOS before adding the video card. (Check your manual for entering the BIOS - often hit F1 or F2 (or enter when prompted) as you start the computer before the OS starts loading.)
I have no idea how you see the BIOS information without a working video to start.
Jun 07, 2010 | EliteGroup L7VMM2 (L7VMM2 NO CARD READER)...
Does emachines t3990 have an AGP port?? From what i've heard it has 3 PCI ports and im not sure whether it supports an AGP port as well.
your computer has the following motherboard
Intel 865GV
this uses AGP graphic cards (old type)
Rate me yeah?
Jul 29, 2009 | E-Machines T3990 (RBT3990) PC Desktop
My m7viw has an agp slot however i get no video when i put my avg card in i've set the bios to use agp rather than pci slot, but still nothing, pci video cards work great, but i cant get the damn agp to...
With the card installed, boot using the PCI card. Right click "My Computer" and then Properties. Under Hardware, click Device Manager. Are there any notifications? Make sure drivers are installed for card, if any.
Apr 16, 2009 | Biostar M7VIW - Motherboard
Trying to install a video card for my nephew. Nothing fancy. He has an emachines w3650 and has an EVGA geforce9600gt card. The card is pci-e 2.0 512ddr3. When we put the card in his case and start up...
The reason may be the card is not in the correct slot. PCI-E means PCI Express which is the fastest card availble. Its the smallest white slot on the motherboard. If it is not working or there is no "2 inch long slot" then the motherboard is not setup to handle that type of card architecture. The next brand you would look for is one that says only PCI or AGP.
Please rate this solution.
Mar 31, 2009 | E-Machines eMachines Desktop PC
Ok i have a emachine c2280 we put a new power supply changed the ram and i have no video, there is also a red light next to the ram what isit..
Anytime. Just in case you there is any way you can get video to display. There is a setting in bios to change what controls the display adaptor. You might want to try to reset your bios and see if you can change this setting. Figure there is nothing you can hurt at this point.
Just remove the "watch battery" that is on the motherboard for a couple minutes and try to start the computer. Also you might want to look for some pins on the board that say something about bios reset jumpers. Normally you short the two pins then remove and boot. Sometimes you short-boot-shutdown-unshort-boot again.
I'm thinking though if you can get in there you can set your display to pci or agp or whatever kind of video card you have.
Jan 29, 2009 | E-Machines eMachines Desktop PC
Emachines w3609
Hey iluvyakatu
Does your emachine has inbuild video card or AGP or PCI card? if one it has AGP or PCI card try to reseat it. If it is inbuild try to use AGP card or PCI card and see what happen. Also try to check whether you have an inbuild video and AGP or PCI both installed, if you have both try to use one of them.
good luck
zinja
Sep 17, 2008 | E-Machines eMachines Desktop PC
No moniter output
if you mean there is no vga lead connector, there is no onboard graphics, you will need to purchase an agp graphics card
Aug 24, 2008 | EliteGroup L7VMM2 Motherboard
Power Supply for L7VMM2
well,if you are sure that the new power supply is new and ok,than more than sure,if you dont have any response from the mainboard,that it is damaged by the high tension who allready burned your initial power supply.
I suggest you to visit a specialised service because for now its nothing you can do more.but first be sure you have a quite functional new power supply.
bye
Feb 05, 2008 | EliteGroup L7VMM2 Motherboard
EliteGroup L7VMM2 Motherboard Logo
105 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
