Question about Sony CDP-CE345 5-Disc CD Changer
Carousel won't stop rotating
Will not stop on disc 1 position. Turns clockwise then counter then stops. Then shows "error"
catriver
  • 878 Answers
SOURCE: washer make a clicking noise
Zoobs, you could have something stuck under the agitator. The agitator will pull straight off. Grip it on each side and pull up hard, but don't hit yourself in the face. If that don't work, try slipping a belt under it and pull. Check for something caught under it. Another possibility could be the nylon suspension rod socket supports in the back. They will make a noise during agitation if they are dry. Put a little 3 in 1 oil to quite them down. Take the front panel off and check the pulley and belt, see if anything is out of whack. I also often find the motor support hitting the bottom panel during agitation making noise. Take the front panel off and observe during agitation. See if the support is striking the bottom. If so, just bend the bottom panel down. Catriver..post back.
Posted on Dec 01, 2006
welcomejee
  • 10594 Answers
SOURCE: Rotary table on Sony CDP-CX225 200 disc changer will not rotate
I think CD Mechanism needs service and might required belts replacement.
You need to get service manual of your CDX-C225 model to do this job as manual contains all technical info about mechanism etc.
Posted on Nov 07, 2008
cdj repairs
  • 68 Answers
SOURCE: Sony CDP-CX53 rotates the carousel and inserts the CD into the playing position, but it won't play the CD
It sounds like there is a cd tray alignment problem, there is no quick fix, all i could suggest is to send it to us or take it to your nearest dealer.
Regards.
http://www.audiovisualservices.info/
Posted on Jan 02, 2009
  • 9 Answers
SOURCE: plug wire firing order on distributor cap on 1979 dodge 318
V8s are 18436572 going clockwise number 1 should be marked on cap or closest tower facing you standing at the rad
Posted on Jan 09, 2009
  • 130 Answers
SOURCE: Sony DVP CX860 300 disc just keeps rotating the carousel
I just got one of these and i notice mine does the same thing. WHat i found that helped mine is tip the unit back a little. The loader uses a little but of gravity to get the disks to roll back into the loader. If its level the wheel sometimes cant spin the disk up into the loader fully. If its tipping back a little the disk will roll back easy into the loader and load it properly.
Also, dont forget if your playing a disk and you want to stop the unit, DONT POWER IT OFF AT THE UNIT. Power the unit off by the remote power this way it will finish its cycle and put the disk back into the proper slot.
Posted on Apr 15, 2009
Tip
Adjusting the temperature setting on a Delta single handle faucet 13/14 series.
Delta single handle Tub & Shower faucet temperature control adjustment.
Step 1 - Remove handle to gain access to rotational limit stop. Once handle is off there ia a plastic limit stop disc. Remember where it is to start with. Metal handles require a 1/8" allen wrench to remove handle. Plastic handles require removal of cap to access screw to remove with phillip's head screw driver.
Step-2- To adjust the temperature of the water coming out of the valve, pull the disc back to a position where it is possible to remove the Rotational Limit Stop and readjust the teeth to desired position to acheive temperature. Once moved reinsert it into place to test water
Step-3- Clock wise will decrease the temperature and counter clockwise will increase the outlet temperature to a hotter setting. Temperature setting per tooth (notch) could result in 4 to 16 degree's based on inlet water conditions.
Check water temperatures to make sure it is at a safe temperature to avoid scalding. Safe operating temperatures range around 120 degree's. Some may have to be adjusted based on season's.
Winter season's when it is cold outside you may have to turn temperature up due to water coming into house will be colder than it would be in the summer.
on Jun 23, 2010 | Plumbing
How to adjust carburator on a mac 130 chain saw
turn till it stops clockwise, then turn back counter clock about 1 1/2 turns. If you hear the motor sounding bogged down, turn it a bit more counter clockwise, (leans out the gas) till it stops sputtering .
Jun 21, 2014 | McCulloch Garden
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
How do I set and turn on/off the alarm function?
Hugo Boss Watches have a MOVADO watch movement the PDF Manual accessed via the URL below contains information on how to set the alarm.
URL http://www.movado.com/media/manuals/pdfs/hugo-boss/MDE_internet_EN_120514en.pdf
Nov 24, 2012 | Hugo Boss 1512657 Watch
LG TROMM Direct Drive WM0642HW when filled and started LE light comes on and machine stops, why. how do I reste or fix
LE is for a overload error. Do the following:
1) Unplug machine
2) Drain machine
3) Open machine and rotate barrel clockwise 4 times and counter-clockwise 4 times
4) Plug in, power on, and run regular cycle
Feb 27, 2011 | LG Washing Machines
How to remove chainsaw clutch
hi
remove statrer cover assy
remove plug, rotate engine until piston @ bdc - insert a thick 6 mm nylon starter rope through plug hole and rotate piston so that it pushes rope in between piston and cylinder top this locks the crankshaft
its called a soft stop
take a punch and hammer and give the clutch 1 or 2 hits in and clockwise direction clutch should loosen
to refit clutch , remove soft stop and rotate engine counter clockwise fit the stop and jamb it again between piston and cyl head then spin on the clutch ( threads are left hand ) use punch and give 1 or 2 hits to tighten again - remove soft stop and refit plug and starter cover assy
clutch should tighten further when engine runs
cheers paul
hope it helps
Aug 02, 2010 | Garden
Hi, I have a Wurlitzer 3600 Superstar that I am working on. I am having trouble figuring out why the carousel won't stop spinning. It is looking for it's "Home" position, but won't stop. If I select a...
Look at the switch and solenoid assembly at 1 oclock on the carousel. That is what activates to set it going and it then clocks off a ratchet wheel to do two full cycles looking for a selection then stops. If it gets stuck the carousel wont stop.
Oct 07, 2009 | Wurlitzer Jukebox 1015 One More Time...
Jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
May 01, 2009 | Sony CDP-C265 CD Player
Sony CDP-CE345 5-Disc CD Changer Logo
57 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
