Question about Carrier 38CKC042 Air Conditioner
Air cond drain line
The line is clear and water runs freely from the disconnect to the out side no problem even blew line out but when float switch is placed back in PVC overflow connection it draws water and shuts system down
  • 71 Answers
Did you check that it is level
Posted on Dec 13, 2008
My ac won't turn on have thermostats set to 80 and inside temperature 94 no cool air coming out of vents
Check the drain line or emergency pan for backed up water and a tripped float switch. Never leave float switch out, must vacuum or clean drain line clear.
Jun 14, 2017 | Thermostats Heating & Cooling
I have a 2001 Suzuki Maurader 250 - we bought it used and cannot get it to start - we have had it running but the next day it will not start. |We have changed the oil, plugs, cleaned the carb and now it...
Drain the carb with the gas valve on the tank turned off. Now turn the valve back on and see if gas again begins to flow out of the float bowl. If no gas drains with the valve open then remove the fuel line at the carb and check to see that fuel flows freely through the fuel line. If gas flows freely out of the fuel line then the float needle is stuck closed or trash is plugging up the needle jet assembly. If so, remove the float bowl and free up the needle. Use spray carb cleaner and the little "straw" that comes with the can to direct the spray into the float needle fitting. Fuel should flow when the float is down and stop flowing when the float is lifted. Pull a spark plug and ground the metal against the cylinder. Check for spark. If there is no spark then check the operation of the kill switch on the side stand and the handlebar. Use a multimeter to check the switches. Get fresh gas and install an in-line fuel filter to keep any trash out of the carb. Clean the air filter. Please rate my answer. Thanks.
Apr 03, 2011 | 2001 Suzuki GZ 250 Marauder
Ice build-up in bottom of freezer section.
your defrost drain on the freezer side is stopped up causing the drain to freeze over then eventually running out on the floor during the defrost cycle. Locate the drain at the back of the freezer and thaw it out using hot water. Using a screw driver or other object gently push down into the defrost hole and dislodge whatever is stuck there.
An air hose with good air pressure may also work well. When the drain line is clear you should be able to pour water through it freely.
Jun 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Thermostat show cool on but not running
Is fan running.? Is outside unit running? Check to see if you have float switch on Air Handler inside. This is located in the drain line or drains into a container with a switch in it. If this is tripped or water in pan the drain is stopped up. You can clear the line with a shop vac by sucking from outside. There may be otherproblems but I would start withe easiest. Drain switch , check breakers, theen if that does not work calla service tech for free estimate. Russ
Aug 25, 2009 | Honeywell Programmable Thermostat Heater
KitchenAid KUDR24SE dishwasher doesn't drain.
check the drain tube at the disposer
Jul 02, 2009 | Dishwashers
Bosch SHX46A02UC-21
float switch is in the flood position and the drain pump is running.. there is water under the dishwasher or that switch is stuck up..
Aug 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Air handler will not run clogged up drain?
the air handler is in the attic or in a closet right? most likely the drain switch mentioned is in a pan located underneath the air handler, the switch is actuated when the condensation drain tube is clogged, ( when it cannot drain the water out of the pan), the float switch is actuated and the unit shuts off to prevent any more condensation, thus preventing overflow into your house/apt. the drain line can be sucked out by using a simple wet/dry vacuum of any kind from the end of the drain line ( usually a 3/4 inch PVC pipe located somewhere outside ).
Aug 14, 2008 | Heating & Cooling
A/c unit won't come on
if unit uses a manual switch to turn on suspect it faulty if a circuit board is used the main fuse blew out.
May 17, 2008 | Intertherm Heating & Cooling
Water problem
Many dishwashers will drain at the beginning of any cycle.
If the water does not fill after the pump-out cycle, then the problem is either the fill valve or the float switch. You should be able to hear the float switch click as you raise or lower it. The fill valve usually hums whenever it has power.
If the fill valve has power but doesn't open, (use a voltmeter) replace the fill valve. If there is no power at the float switch, nor at the fill valve after pumping out, then the clock / timer is at fault.
Mar 10, 2008 | Dishwashers
Carrier 38CKC042 Air Conditioner Logo
80 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
