Question about Dell UltraSharp 1905FP 19" LCD Monitor
How do i open the cover to a Dell 1905FP Monitor
The front bezel snaps off. Power supply access requires dissassembly of screen from electronics cage.
Posted on Dec 28, 2008
Look to go through the front side after removing 4 screws from back.
Posted on May 31, 2009
    Sergeant:
  • 320 Answers
First off thanks for using fixya.com
Second if the monitor is under warranty it can be repaired for free. However, if the warranty has expired, or you do not wish to use it for some reason.(I often hate dealing with warranties). On the back of the monitor there are usually a few screws, these may be hidden under stickers which can be found by rubbing your finger over them with some pressure.
Other monitors "snap" together and can be separated by sliding a thick guitar (plastic) pick along the edge where the two halves meet.
You may also need to first remove the base on some models before you can access the screws.
I hope this helps in some way and feel free to ask futher questions if needed.
Jei
Posted on Dec 13, 2008
  • 3 Answers
Go to this site for installation instructions:
http://www.lcdrepair.us/Installation.html
Posted on Dec 01, 2009
  • Dell Master
  • 1,684 Answers
Here is a link to a full repair guide with videos showing how to open the unit, remove the power supply and what capacitors need to be replaced to repair the Dell 1905FP and 1907FP units that will not power up.
http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Here is a picture of the power supply board with the capacitors circled.
How do i open the cover to a Dell 1905FP Monitor - 9_24_2012_10_40_35_pm.jpg
Posted on Sep 24, 2012
  • 3 Answers
SOURCE: Dell 1905FP Monitor - power supply
Can also be the lamp of the monitor that is slowly dying
Posted on Jun 06, 2009
NetSalem
  • 55 Answers
SOURCE: My Dell 1905FP 19 monitor went black & green power light flickers
It sound like a short circuit. I had this problem with 1907FP model. It had an USB port on the monitor which got damaged and it was shortening to the groung. In your case it might be a bad internal power supply board.
Posted on Nov 20, 2009
micromend
  • 748 Answers
SOURCE: How can I disassemble to get to electronics
This is the way I each all my techs to open and repair a monitor. First things first. You’ll need a Phillips screwdriver, rubber gloves, a fiberglass diddle stick(Radio Shack)aluminum tape, small cups and colored markers. Do this operation on a large flat surface. I suggest using an anti-static mat or large piece of wood underneath so as not to scratch the table or counter surface. First take your diddle stick and sharpen one end to look like a flat blade screwdriver. DON NOT USE a metal screw driver (metal causes scratches.) Now turn off the monitor, unplug all the cables and remove all the accessories i.e. stand, speakers. Take out all the screws from the back (these are different sizes so put them in different cups and mark their locations using a colored marker). Once all the screws are removed take your diddle stick. Insert the stick under the front edge of the screen. Sometimes you can use a finger to start lifting the plastic bezel. Under the plastic bezel you’ll see the metal frame of the screen. The diddle stick needs to ride on top of that metal and under the plastic. Once there you can move the stick up and down on each side. This will release the internal plastic catches and soon the bezel will pop off. The control panel my be screwed into this so be careful. At this point you can lift out the screen. There will be metal shield(s) covering the two circuit boards. A number of screws will release the boards. You’ll need to remove the nut screws from the video connector also. The power supply board is probably soldered on to the frame but that should be easy. That’s it. Do your thing and be careful putting it back together. The Golden Rule of service work – NO EXTRA PARTS. Good luck.
Posted on Mar 01, 2010
budmrtn
  • 11361 Answers
SOURCE: UltraSharp 1905FP 19" LCD Monitor: I have a Dell 1905FP and it will not turn on. The ...
You may have bad caps (leaking/bulging tops) in the power supply or blown fuse. This is what the board looks like.
http://lcdrepair.us/1704fptt-1905fp-inverter-power.html
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 18, 2010
budmrtn
  • 11361 Answers
SOURCE: installed Dell 1905fp monitor -- message showing
The native resolution of this monitor is 1280x1,024 2 60Hz, your PC video card resolution is set too high for it to display. Bootup in safe mode (hit F8 while booting up), then select VGA support, set the resolution to 1280x1,024 2 60Hz, then reboot.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
Posted on Jun 09, 2010
The screen flashes on my Dell 1905FP Monitor, Is there a fix?
This is a common indication of bad filter capacitors on the power supply board. Below is a picture of the power supply board with the problem capacitors circled in yellow. The repair is easy, you just need to replace those capacitors and the unit should be as good as new. Below the picture is also a link to a full repair guide showing how to dis-assemble the monitor and what parts need to be replaced. the repair guide has a full parts list for the job.
The repair guide can be found here:http://www.ccl-la.com/blog/index.php/repairing-a-dell-1905fp-1907fp-lcd-monitor/
Mar 26, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Nov 20, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
How do you replace a power supply unit in a 1905fp Dell Moniter?
Here is a link to a full repair guide that shows how to open the unit remove the power supply and what components to replace to repair the board. Repairing the board is much cheaper than getting a new board. Below is also a picture of the board with the problem capacitors circled in yellow, these parts are the most common problem with the board.
Jun 26, 2009 | Dell UltraSharp 1905FP LCD Monitor
I have a dell moniter 1905fp and it is flash the main screen. any suggestions
Had the same problem on my Dell E178FP and I made a video on how I fixed it.
Jun 20, 2009 | Dell UltraSharp 1905FP LCD Monitor
Cannot raise vertical height after pushing button on back of monitor (button stuck in)
With the monitor in the lowest position, push down slightly on the monitor and push the button in. While holding the button in you should be able to raise the monitor with your other hand. This worked on the one I have.
May 01, 2009 | Dell UltraSharp 1905FP 19" LCD Monitor
My dell 1905FP power button flashes green and will not turn off, the screen is black.
This is a common indication of a failure in the power supply. There are parts called capacitors that are used in the filter section of the power supply, when they go out the power supply can't properly turn on so you get no picture and a flashing power light. Here is a picture of the power supply board with the problem filter capacitors circled in yellow and below the picture in a link to a repair guide with details dis-assemble and repair instruction along with parts list for the Dell 1905FP and 1907FP models.
Mar 25, 2009 | Dell UltraSharp 1905FP LCD Monitor
Dog Hair under protective coating on monitor
get your Dell manual out and look in the index for lcd cover. It should tell you how to take it off and maintain it. If things get behind it it should be removable. Also www.dell.com is very informative with their support group.
Sep 13, 2006 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell UltraSharp 1905FP 19" LCD Monitor Logo
4,270 people viewed this question
Alun Cox
