Question about Carrier 38CKC042 Air Conditioner
Okay I have a 14 sear two zone carrier ac since it was cool in florida the last month the system was off we turned it on earler in the week and the condenstate line was cloged no big deal i blew them both out. but one zone will not clear. even though i can run water thru the drain line to the outside no problem solid stream. when i put the float switch back in the pvc it flood and shuts down?
  • 82 Answers
Sounds like a stuck float switch
Posted on Jan 10, 2009
2001 monte carlo ls 3.4 overheats!! replaced everything
You have to bleed the air out of the system. There are 1 maybe 2 bleeders on the front of the engine on the cooling system bypass pipe one near the upper hose the the othe on the drivers side of the pipe. They are brass with a small bleeder valve in the middle. Get the car up to temperature and take your time to allow all the air out. Refill cooling system after it cools. Hope you didn't do any damage running it hot.
Dec 27, 2013 | 2001 Chevrolet Monte Carlo
I had Ruud heating and cooling installed five years ago. Last summer my electric bill doubled when I began running my air conditioner. It did not do that the first few years that we were in this house. ...
Hello In a way you are stuck with what is called a S.E.E.R. rating which is a statement of efficiency from the manufacturer.Ex: a 10seer is less electricity to run than a 14 seer.The model # would have told me the seer rating.A 4 ton `1 zone is a large unit but even a 10 seer 4 ton is never cost prohibitive to operate and Never doubles the electric bill in 5 days out of thirty.Is the home unoccupied all month and you use it on weekends?Did the neighbor run a strange wire to your property?There might be stray or lost voltage in rare cases if there is poor grounding issues.Has the unit been serviced? A low freon charge will cause a unit to run excessively long and not cool.Do you run the indoor blower all the time.Has there been any other major purchases made (at all) that you plug in?I would look at everything because there is some cause for DOUBLE bill amount not just the cooling bill.Good luck
Jun 18, 2011 | Ruud Heating & Cooling
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
Need air cindition recharge, don't have cash to take it someplace, can you help with instructions to do this
YOU NEED A R-134 GAUGE SET TO CHECK LOW PRESSURE SIDE AND HIGH PRESSURE SIDE.YOU ALSO CAN BUY A LITTLE CHEAPER GAUGE TO CHECK YOUR AC LOW BLUE SIDE AND HIGH RED SIDE AT ANY AUTO ZONE OR ADVANCE AUTO PARTS.WHAT YOU DO WHEN YOU GET YOUR GAUGE SET HOOK GAUGE TO LOW PRESSURE SIDE BLUE CAP PORT AND GAUGE TO HIGH SIDE PRESSURE RED CAP PORT.YOU CRANK CAR UP GET IT OPERATING TEMPERATURE.THEN TURN AC ON HIGH COOL LET RUN 3 TO 4 MINUTES.CHECK LOW SIDE GAUGE READING SHOULD BE 28 - 32 PSI. HIGH PRESSURE SIDE GAUGE SHOULD 199 - 228 PSI. THATS NORMAL CHARGE. SEE YOU CANT JUST RECHARGE AC SYSTEM UNTIL YOU CHECK IT FIRST YOU WILL DAMAGE SYSTEM .NOW YOU CAN GO TO AUTO ZONE PARTS BUY A CHARGE CAN WITH GAUGE AND HOSE.ATTACH TO IT.YOU NEED MORE THAN ONE CAN.WARNING MAKE COMPRESSOR IS RUNNING WHEN YOU TURN ON AC .BECAUSE IF COMPRESSOR NOT RUNNING CHECK FUSE AND AC COMPRESSOR RELAY.IF BOTH OKAY.YOU COULD HAVE OPEN CLUTCH COIL A FAULTY LOW PRESSURE SWITCH WILL CAUSE AC NOT TO WORK. IF LOW PRESSURE GAUGE BLUE SIDE PRESSURE IS 28 OR 30 YOU DONT NEED A CHARGE.PROBLEM SOME WHERE ELSE.BE SURE TO WEAR SAFETY GLASSES WHEN WORKING ON AC SYSTEM.
Jun 26, 2010 | 2004 Hyundai Elantra
Zone is set to deliver AC but nothing comes out of the vents
Your duct system has dampers that separate the four zones. Even though all four sensors are working and call for a/c, you may not be getting voltage to the damper motors, which open when there is a call for a/c, and close when the call is satisfied. In certain parts of your duct system, you will find small orange or gray boxes with wires going into them. Those are the motors for the dampers. When there is a call for a/c in all four zones, check to see if you have power going to those boxes. If power is present, the motors are bad or the damper itself is stuck. If power is not present, check the master zone control.
Aug 11, 2009 | Carrier 38CKC060 Air Conditioner
Blank readings on Carrier Comfort 3 zone thermostat
The stat that works is called the main and the other two are called slave stats. The stats must be set to heat or cool the same as the main. If you want one room to cool and one to heat , sorry. Need to upgrade to auto changeover. Is this AC actally a Heat pump?
Jul 01, 2009 | Carrier 38CKC042 Air Conditioner
Zoned system one zone not working
I hit the reset button on the main unit and that reset all the sensors. It was so easy but when I called Carrier's customer service line they told me there was nothing they could recommend. Not very good customer service. Avoid Carrier brand if possible.
Jan 22, 2009 | Carrier XHB123D X/Y Series Heat/Cool Air...
A/C Problems
SOUNDS LIKE THERMOSTAT IS NOT SET UP CORRECTLY THE HAVE TO BE PROGRAMED TO YOU UNIT
Aug 28, 2008 | Honeywell Electronic Programmable...
Carrier 38CKC042 Air Conditioner Logo
75 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
