Question about Brother SE-270D Computerized Sewing Machine
Brother SE-2700 Disney Machine - Safety Device keeps coming on!!
In the middle of sewing today my machine went nuts! The safety device comes on when the needle goes up or down - I have cleaned it, looked over everything I can think of - it seems like the wheel is too tight - it was fine and then all of a sudden it wasn't. Help!!!
  • danenebates Mar 07, 2009
    The safty device is activated warning comes on and locks up the machine. I have changed the needle, thread (both upper and lower) checked for nicks scratches or anything out of the ordinary and can find no cause for this. I had used it a few months ago and everything was fine then stored it and when I brought it back out I had this problem. Any solution would be great.
    Danene
  • kstucker123 May 24, 2009
    I have a Brother PE700 and it is doing the same thing. It will embroider along fine then all of a sudden it locks up, the safety device has been activated warning comes on and then the wheel is very tight. A couple of months will go by and then it works again. I think that I move the machine around and somehow it miraculously heals itself. But I can't make it through a whole design. I have searched the web for this same problem and not having any luck. Not sure what it is and can't afford to have it fixed. Suggestions anyone?
bargainbox
  • 1388 Answers
SOURCE: mock safety stitch
Sounds like the timing is a little out.
If you remove the needle plate and turn the handwheel manually watch for the lower looper as it swings behind the Left needle....the needles ought to rise by only about 2mm before the looper passes......the looper must pass the needle above the eye to catch the thread, and be so close as to be barely touching the rear of the needles......if the left needle thread is not picked up, it may be the timing, or the distance between needle and looper.
For the uninitiated, there are a myriad of variables in correctly timing an overlocker (serger), and without the manual to refer to the correct parameters, you will rapidly descend down a road of despair....if you move a looper to advance or ****** the timing, you risk looper collision and a broken looper is almost as much as a service, so my advice is do the test to see if the timing is the likely culprit, and if so, take the opportunity to give the old girl a treat.
If you need to save for a while to do it, just use the 3 thread option for the time being.
www.bargainbox.com.au
Posted on May 10, 2008
  • 399 Answers
SOURCE: I have a Brother SE-270D
its the problem of the timing belt in your machine its extra loosen or extra tightned or is slightly came out of its position or finally broken.
as the machine is proper just missing the proper speed as it should be .
it is running continuosly as you stated.
check the timing belt and make it proper if its worn out and needs replacement this is how its done
There is an adjusting screw on the right side of the machine head. Follow the motor bracket to the machine head and loosen that big old screw or bolt which will raise or lower the motor giving you slack to remove or replace the belt.
feel free for further queries
thanks
Posted on Sep 19, 2008
SOURCE: My Disney Brother SE-27OD Embroidery Sewing Machine/trouble
Can you buy embroider memory cards with out down loading on your PC?
Posted on Jan 15, 2009
SOURCE: I am trying to start
Hello
Make sure the bobbying is lettinng out the string first and also make sure the dial on the left side of machine is on 6 .when you turn the maching around , looking at the back make sure switch in too your right. Also just unplug the maching could help, my wife just had the same problem...
Posted on Jan 26, 2009
  • 52 Answers
SOURCE: Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Posted on Jun 25, 2009
The safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
Mar 03, 2010 | Brother SE-270D Computerized Sewing...
Brother SE-350 "The safety device has been activated"
Return the bobbin winding shaft on the top right of the machine to the Left Position. It may be stuck in the middle.
I had this same problem. After an hour or two of fiddling, this fixed my problem.
Dec 22, 2009 | Brother Sewing Machines
Error message on Brother SE-270D sewing machine
The safety device will activate if the machine has a bind or is unable to run at correct speed. If you turn the handwheel is it tight/hard to turn? if it is than thats it. Now what is binding the machine has to be diagnosed.
Jul 22, 2009 | Brother SE-270D Computerized Sewing...
Jun 24, 2009 | Brother SE-270D Computerized Sewing...
I am trying to start sewing using the brother SE-2700 machine and it keeps giving me The safety device has been activated error message. I have done everything in the manual that it says to do to fix this...
Hello
Jan 21, 2009 | Brother SE-270D Computerized Sewing...
It will not sew safety device keeps coming on
i had that problem also...you have to make sure it is snapped all the way back are it will keep coming on.
Jul 21, 2008 | Brother SE-270D Computerized Sewing...
Brother 2003D jammed
i am not familiar with the brother safety device myself. however things i would check might be to first check the manual for the machine. if not available try to turn the machine off if it is electronic in hope that it would reset itself. i would also totally unthread the machine and change the needle. embroidery machines need to have needles changed more often due to their high speeds.What type of fabric were you sewing on? Some of the newer machines are just not made to sew on very heavy fabrics and this might be causing something in side to spring. Try to stitch on a lighter fabric with a stabilizer under it
Apr 30, 2008 | Brother SE-270D Computerized Sewing...
Brother ult disney machine
Marty, it happened to me! I figured it out, if you need help, feel free to email me, it is the bobbin carriage was not put it--not the bobbin spool, but the whole carriage. feel free to email me and I can walk you through it! I just saved myself a trip to the repair! :)
pyles_brandi@yahoo.com
Dec 17, 2007 | Brother SE-270D Computerized Sewing...
Brother SE-270D Computerized Sewing Machine Logo
256 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
