Question about HP LaserJet 2430 Printer
Hp 2430 printer copies are faint
Installed a new printer toner cartridge, copies are still
very faint.
  • 81 Answers
Try going to the printer properties and change the quality of the output.
Good luck
Posted on Dec 13, 2008
There is no toner when there is in the toner cartridge
replace the image unit for that color and replace the toner cartridge with oem cartridge
Jan 30, 2014 | Konica Minolta magicolor 2430 DL Laser...
Have a Konica Minolta 2430 DL and it ask me to install blk toner after install toner it has error line 2408. can you help me?
2408 means that the toner cartridge you are trying to rotate to is already in the top position or you need to install another toner cartridge before you can rotate to the color you want to replace.
To fix the toner not installed message clean the three contacts on green chip on the right side of the toner cartridge. You may see black lines on them. Use an eraser or rubbing alcohol.
Nov 11, 2010 | Konica Minolta magicolor 2430 DL Laser...
Konica-Minolta 2400W is printing very faint. All 4 toner cartridges were recently replaced, and then the drum was replaced. About 50 pages have been printed and it is still very faint. The glass has been...
That could be a problem with either the fusor wire or just need to reset the darkness setting or you didn't gently shake the cartridge (or the toner was exposed to high humidity).
The fusor wire may not be getting hot enough to get all of the toner to stick to the paper and you get the faint page. The fusor assembly is wirth about $240 so you want to make sure if it might be covered by warranty and check the replacement price for the printer. The replacement price might be close to that and you would end up with a new printer with warranty.
Oct 24, 2009 | Konica Minolta magicolor 2430 DL Laser...
Konica minolta 2430
Most likely you received this message after a toner was replaced. Reseat the cartridge and restart the printer. If that doesn't work remove all of the toner cartridges manually and reinstall.
Turn off the printer and open the top cover. Follow the toner cartridge all the way to the right side of the printer (on the white part). You should see a hole that looks like a cross. Take a pen or key and push down on the black button in that hole. While you are holding it down rotate the toner cartridge towards you. You want to get the colored roller on the cartridge about 1/2in away from the metal bar that says "consumable reorder". You should be in a position to take out the toner. Let go of the hole and remove the cartridge. Repeat the steps until all of the cartridges have been removed.
Turn the printer back on at this point. You are going to get toner not installed messages on the printer. Open the top cover and the cyan tray will be in place. Shake the toner and install. Close the cover and let it cycle to the next color (black). Repeat the process until all cartridges are installed.
If you are still getting the error you either have a bad cartridge or the carousel that the toners sit in is damaged.
Jul 16, 2008 | Konica Minolta magicolor 2430 DL Laser...
Toner Cartage
Really Magicolor 2430DL is a very worst printer in this world.
within 2 months drum cartridge finish - no other printer like this type of option - like black, color & durm cartridge.
I will recommend - not to go for the thirdclass cartridge. go for only HP.
thanks
anil - dubai
Feb 20, 2008 | Konica Minolta magicolor 2430 DL Laser...
Hp Lj 2430TN Printer
We ran into this problem a lot when this series first came out. There is a simple sensor on the left hand side of the toner cartridge area inside the printer that physically detects that a toner is installed (or not). With the left cover off, there is a plastic bracket that holds a lever; unless it is not, then it tells you that you have no toner installed. Lame.
Jan 16, 2008 | HP LaserJet 2430dtn Printer
Test Page blachy, text faint, supplies staus page bar vertically spotted
Have you tried the toner cartridge?? IF not please do so. Failing this clean out the middle of the machine with a dry cloth as you may have loose toner in there. Try this if it doesn't work then the laser unit may have a fault.
Hope the first one helps
Thanks J
Jan 15, 2008 | HP LaserJet 2430n Printer
LJ 2430 Printing Blank Pages
HI there have you tried the toner cartridge as this could also cause this problem? Also change the transfer roller and are the bands going from left to right or from up to down. If the bands are left to right change both if up to down more likely to be the toner cartridge.
Hope this helps you
Thanks J
Jan 11, 2008 | HP LaserJet 2420 Printer
Laser cartridges with chips
you need to replace the chips so it will read the amount of pages printed by the toner cartridge.This chip is only for measuring how many pages printed.
Mar 30, 2007 | HP Q2613A OEM Genuine Black Laser Toner...
HP LaserJet 2430 Printer Logo
225 people viewed this question
Seeker5211
Seeker5211
