Home | Nikon | D200 Body Only Digital Camera | Nikon D200 battery doo...
Nikon D200 Body Only Digital Camera
Problem for Nikon D200 Body Only Digital Camera
Nikon D200 battery door - is it broken?
By afurst on Dec 13, 2008
I have a D200 and the battery compartment door came off. I'm not sure if the little plastic hinge piece broke. It seems to be asymmetric: a rod sticks out on one side and forms a pivoting hinge. On the other side there is no rod, and I can't tell from looking at the plastic whether it is broken or simply a rather rough finish. Are there meant to be two rods sticking out of this piece? Can I buy a replacement door?
Same Problem
Mar 08, 2009
-   It wasn't the door that broke, it was the little "keeper" on the body itself that broke. Nikon wants $140 to repair. I told them to ship it back unrepaired and I would continue to use my MD200 battery pack.
Does anyone have a suggestion as to the replacement of that part. What is involved in removing what is left inside?
-   rserpan
Solution #1
posted on Jan 12, 2009
Not Rated)
paula5555
Rank: Apprentice
Rating: 100%, 1 votes
The battery door is meant to come off so the MB-D200 battery pack can be inserted, but it sounds as if yours has broken. There should be equally-sized rods that form the pivoting hinge, on on top and one on the bottom. Yes, you can buy a replacement part, probably through a local dealer or online. I believe online they cost around $20-$25. To remove the door, you are supposed to open the door to a 60-degree angle to the camera body and gently pull the door off. To replace the door, again, hold the door at a 60-degree angle to the body and gently press it into place. Or you could pay a repair shop an arm and leg to do this for you ($50 or more + shipping if you use a mail order repair shop).
I remember the 'good old days' when film SLR's were made to take a beating. Sadlly, we're in the era of plastic and I always have to remember to treat every piece of equipment as if it were made of glass!
Hope this helps?
Was this helpful?
Yes
No
Popular Solutions for Nikon D200 Body Only Digital
Questions and Unsolved Problems for Nikon D200 Body Only Digital
Do you recommend Nikon D200 Body Only Digital Camera?
Answer
Answer
how do I find out how many pictures my Nikon D200 has taken
Answer
Hi my Nikon D200 shutters every time I turn the camera and some time before you press the shuttre... (More)
Answer
The "S, CL, CH.." spindle of my Nikon D200 seems to have slipped about 90 degrees to the... (More)
Answer
"Off" is flashing in lcd display. Why?
Answer
If there is grid in D200 how to get it on menu?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Nikon D200 Body Only Digital...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 632
Experience: im jack of all trades but a master of none! and being an old f*rt you get to learn a fair old bit
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
