Question about GE JSP69 Electric Kitchen Range
GE model JKP13GOP2BG control panel faulty ( F1 code)
I' ve found someone to repair my range control ( WB27K5040 ) but I need to remove it so I can send it in. How do I remove the control?
  • 114 Answers
Often times when someone makes an attempt to "repair" a control, it does not hold up. Replace the entire control. Don't waste your time. You will also get a year warranty on a replacement control.
Posted on Dec 13, 2008
Is replacing an electronic oven control on a Frigidaire ES330 this easy?
Yup...It's that easy. You can get the parts from a local appliance parts store or from any of the many sources online... Sit down when you ask how much the panel costs.
Nov 20, 2014 | Frigidaire Kitchen Ranges
How to stop WB27K5040 from beeping F1 error code
Unfortunately, the F1 error means that either the touch pad has a short or the "clock" (electronic control unit) has failed. Sometimes the wire between the touch pad and the clock fails. To test for the exact problem, you would need to unplug the range and access the clock from the back of the range. Unplug the touch pad from the clock. Then plug in the range again. If the error does not recur, the touch pad is bad. If the F1 error and beeping repeat, the clock is bad.
GE sold the clock and touch pad as a single unit for the WB27K5040. Since this is an older model range, the replacement is not in stock. There are some places that offer to repair the clock. You'll need to remove the part (or get a service person to do it) and send it in. Your range will be unavailable for some weeks while this is attempted. Otherwise, you should replace the range when the issue becomes too frustrating.
I hope this helps.
Aug 28, 2014 | Ovens
Need to replace touch pad, need directions
After spending 230 bucks for a new control panel, which fixed the flashing fault code 7 issue, I decided to take the old one apart to see what had happened. I had found instructions from someone who had done this, but could not understand them; here is the short, sweet version. Understand you can easily destroy the fragile plastic panel, and that these instructions assume you have shut off your range breaker at the house panel, and removed the entire Control Panel (includes the rangetop controls). If you are having difficulty doing either of these tasks, call the repairman now! You can destroy the unit or hurt yourself...
Use an X-acto knife at the edges of the plastic touch panel to separate the touch panel from the backing all the way araound. This requires a steady hand and a good deal of patience. Once there are a few millimeters cut from under the edges, the edges can be gently pried up to remove the entire panel, which is just glued on.
Now find the damage on the circuit board, which is likely a damaged trace or two near an edge of the panel. Make a bridge with wire and solder to repair the break. Use the old glue marks to place modest amounts of quick-drying epoxy on the back of the panel, and press it back in its original position.
Once again, let me stress that this a repair for someone with at least modest skills with a soldering iron and X-Acto knife. A wire-bridge repair of the traces is a must; a simple solder bridge will break almost immediately, due to the same stresses that broke the original board.
Sep 20, 2013 | Jenn-Air JES9860 Electric Kitchen Range
Error codeE6 F2
Remove the power from the oven. Open the control panel and unplug the key pad ribbon from the control board. Assemble the control panel back and turn the power on. Wait a few hours.
If the error code came back on, replace the control board.
If the error code did not show up, replace the control panel (the key pad comes as a control panel assembly).
- The part number for the new control board AP3595759
- The part number for the black/stainless control panel AP3131755
Good luck.
Gene. __________________Hi I did some research for your oven and this is what i found , someone with the same problem , control board needs to be replaced , if you click on the web page below it will explain it to you , good luck Frank
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/1094-whirlpool-fault-code-e6-f2.html#ixzz1gYuqvZnV
Dec 14, 2011 | Whirlpool RBD275PR Electric Double Oven
I have an old propane stove/ range in the house we are renting and we cant read the dials to see what temp the oven is or evan if it is on bake we need to know the only number we found was 35-300243-05-0...
I found the following numbers on my Whirlpool Range:
Quality Control Reference: 35-300243-05-0 (Back of range)
Warning Sticker: 35-302251-05-0
Model: SF380PEWQ0 (Under removable burner lid)
Serial: FFE0204680 (Under removable burner lid)
MFG No.: P1141260N Q (Under removable burner lid)
Whirlpool has the manual here: http://www.whirlpool.com/digitalassets/MLPDF/Use%20and%20Care%20Guide%20-%204363409.pdf
Whirlpool has the parts list here: http://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%204363637.pdf
Dec 18, 2010 | Kitchen Ranges
Gas Oven will not heat up, instead it beeps annoyingly at you and flashes a code: F2 I think that the range is what is listed below. It was the only gas range listed.
This is your electronic range control clock that is out. This is an easy repair and you can make it yourself and you will save a lot of $$$$$$$$ by doing it on your own.
When you get your parts from us, we will send parts removal/installation instructions to you whe we send the part.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service and we will get the correct part out right away.
We answer our customers calls from 7 AM until 9 PM CST so call when you are ready to repair this.
We hope to get you cooking again soon. Thanks, Ella
Nov 11, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven display and oven are not working AT ALL
Most electric range ovens are controlled by the electronic oven control (EOC). If your oven is not working and there is no display on the clock, more than likely you have a bad EOC. The board is not serviceable and has to be replaced. I hope this helps.
Jul 24, 2007 | Whirlpool RF3020 Electric Kitchen Range
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
GE JSP69 Electric Kitchen Range Logo
806 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
