Question about Audiovox VOD715 Car Video Player
Vod715 car dvd player
I just bought a ford explorer with a vod715. Any time I put a disc in, it clicks while reading disc loading and after 10 seconds the clicking stops and a disc error reads. Will it be inexpensive?
  • 15 Answers
SOURCE: Bad Disc Error
TAKE A LOOK ON YOUR LENS MAYBE IT WAS NEED A CLEANING CLEAN IT W/A COTTON BUDS CAREFULLY OR OBSERVE CENTER MOTOR IF ONCE YOU ON YOUR VE700 IF IT SPIN ALITTLE BIT IT REQUIRED YOU TO CONCENTRATE ON LENS AND MAYBE YOU TO REPLACE IT
Posted on Aug 27, 2007
SOURCE: Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Posted on Jan 16, 2009
SOURCE: Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Posted on Feb 16, 2009
Masseyfer
  • 5 Answers
SOURCE: Auidovox VOD715 disc error.
Some models do not play with copied cds, depend the year of manufactured.. read the date and maybe need replace..
Posted on Mar 03, 2009
  • 814 Answers
SOURCE: Audiovox D1210 DVD won't load to play. When we put
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
Posted on May 30, 2009
When i put in a dvd, it makes clicking noises, after that a notice
follow this steps and fix it. God bless you
Does not play disc
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
Nov 14, 2012 | Sony Televison & Video
Just bought a 2002 exlorer. can't load cd's into cd player. reads cd error
I have found that any "burned" discs will not be read on older cd/radio combinations. The newer sets will tell you on the box what formats can be read...I also found this to be true on dvd players
Jul 29, 2012 | 2002 Ford Explorer
HOW DO I TYPE NAMES OF CD OR DVD ?
You can't add a title to a disc from a player (such as this). You can only add a title on a disc writer before finishing the disc. (The only exception is RW (rewritable) disc which can be unfinished.) If a title (disc, chapter or track) is on the disc you can display it. Press Title on the remote. If you want to read all of the information on any disc, insert the disc and press Load on the player (when in Stop mode) or press the TV/DiscExplorer/DVD button to set the unit in Disc Explorer mode. It takes about 30 seconds to load the data. Press Stop to cancel the data search. Then use the folder buttons (ALL,DVD,CD,A,B,C,D) on the remote or the player to read the various items. Press Return to leave the folders. If you enter the Disc Explorer while playing a disc, the playback will stop and you will have to press Play to restart (Resume is not an available option).
Once loaded the player will store the data even after you remove the disc. It will clear when a new disc is inserted or you press Load.
The manual for this unit is available at: http://esupport.sony.com/US/perl/model-documents.pl?mdl=DVPCX850D .
I hope this helps.
Oct 12, 2010 | Sony DVP-CX850D DVD Player
Trutech portable DVD player says 'no disc' all the time
You have problem with lease assembly. It may work if you clean it. You may use laser cleaner disk or take it apart and clean the lens with alcohol.
Jul 16, 2009 | TruTech LMD-5702RT Portable DVD Player
DVD player will not play disc.
If you are loading a store bought DVD and that it what it say's. The transport needs to be replaced. roughly 150-200. If you are loading "burned" DVD's the format may be wrong and the unit cannot read it. Best suggestion I can give you is to first buy a "Laser Lens Cleaner" on that uses fluid. Any electronics store sells them for 15-20. Run it thru the unit a couple of times then try a clean, store bought DVD. If it plays, problem solved. With your DVD's, if you have any liquid car polish like mother's or meguiars, put a couple drops on the disc and spread around with your finger, let it set a couple then buff off with a microfiber towel. This works wonders for old scratched cd's and dvd's and helps protect new ones from getting scratched. As for the Lens cleaner, run it thru every product you have that uses discs 3 or 4 times a year, it's the best preventative maintance and only maintanance you can do on a CD player DVD or PC. Hope this helps
Jun 24, 2009 | Delphi 10.2" FLIP DOWN MNTR/DVD...
Mar 03, 2009 | Audiovox VOD715 Car Video Player
Jensen VM9312 not loading DVD.
If it reaeds the cleaner... then try another disc. 20-30 seconds is a long time to looad a disc...
If the new disc does not work either , I would suggest resting the deck .
If reseting does not help , it is still under warrantee. so have it serviced.
Dec 11, 2008 | Jensen VM9020TS Car DVD Player
" unknown disc, check disc" message
3 out of 10 will record 30-40 min and say DISK FULL..
2+ out of 10 I'll record 2- 1 hour shows then I'll
get a " disc unknown " error...
www.govideo.com site NOR customerservice@govideio.com works..
did they go out of business ?
who bought them ? where's the support ?
joe_wht@msn.com
Dec 14, 2006 | GoVideo VR3840 DVD Recorder/VCR
EMERSON DVD PLAYER CLICKING NOISE..DISC ERROR MESSAGE..HELP!!!
Had a similar problem. Called for support, but was told needed new reader. I took off the cover and manually slid the reader mechanism back and forth a few times. After doing this, tried another dvd and it worked. Apparently it was stuck and not able to move to read the dvd. Give this a try.
Jul 24, 2006 | Emerson EWD2203 DVD Player/VCR
Audiovox VOD715 Car Video Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
