Question about XO Vision XO-2703 7 in. Car Monitor
How to hook up xo-2703 7 in. car moniter
Need help in hooking up to a 1999 chevy suburvan and ps2
Noggin
  • 944 Answers
SOURCE: XO-2703 WIRING
Try these guys - although they only allow installation by licensed installers, so they may not supply parts. http://xovision.com/contact.htm Wiring harnesses for this type of application will differ considerably from vehicle to vehicle depending on the location of the monitor and player and the route through which cabling has to be threaded, so they are usually constucted in situ. The connectors on these units should be standard, so any auto electric shop should be able to wire it up, but be careful not to void any warranty on the monitors. Hope this helps :)
Posted on Mar 19, 2007
I need help on hooking up a JVC cd player in my 1997 mazda protege. Mostly just figuring out the wiring of the car.
well you should buy your cars wiring harness,then you can hook up the wires from it to your deck,get everything ready and then just pull factory deck and plug it in,unless some **** has chopped all the wires in your car then you will need a tester light
Jan 07, 2010 | Car Audio & Video
The wire from my 7 inch screen Model XO-2708 is destroyed, where can I find a replacement.
i have one, if your still intrested ill give it to you with the moniter for 59 bucks email me to send you a pix. tukal22@hotmail.com
Dec 31, 2009 | XO Vision Car Audio & Video
Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
Dec 27, 2009 | XO Vision GX2022 Car Monitor
I have a 2001 Chevy Silverado and both the ABS and Traction Off warning lights came on at the same time.....brake fluid looks good, no other mechanical issues that I see.... Any ideas?
u will need to have the dealer hook up a ABS/Traction control scan tool this is not a mechanical problem it is an electronic failure, there will be a trouble codes.
Jul 19, 2009 | Car Audio & Video
Need to hook up a clarion TVX6541N lcd panel and associated stack
yes but you need to know what your doing you asked the question so i recamend you take it to an auto election
Jul 08, 2009 | Car Audio & Video
Help asap
hook blue wire to ur radio to amp remote
Feb 12, 2009 | Sony Car Audio & Video
CANT HOOK UP MY TVIEW T56UN/HR 5.6 LCD MONITOR
THE S-VIDEO LOOK ALIKE IS ACTUALLY A PIN ADAPTER FOR AV JACKS. THE DVD MAKERS USE SPECIAL CONNECTIONS TO COMPLICATE ADDING TO MIXED SYSTEMS. (THEY WANT YOU TO BUY ONLY THEIR PRODUCTS!) REPLACEMENT ADAPTERS ARE AVAILABLE ONLINE @ http://www.tview.us/
Jan 18, 2009 | T-View TView (T606HR) 6" TFT/LCD Monitor...
Xo vision XO1943BT
CHECK YOUR WIRES AT THE HARNESS WITH A TEST LIGHT TO BE SURE YOUR GETTING POWER TO THE HARNESS.AND A GROUND AS WELL. ANOTHER WAY TO CHECK IS TAKE THE UNIT OUT AND CONNECT DIRECT TO THE BATTERY UNDER THE HOOD
Aug 25, 2008 | XO Vision MD068 6.8 in. Car Monitor
XO Vision XO-2703 7 in. Car Monitor Logo
82 people viewed this question
Top XO Vision Car Audio & Video Experts
Pablo Gonzalez
Jose Velazquez
Jose Velazquez
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
