Question about iiyama Pro Lite AS4636D (Black) 18.1 in. Flat Panel LCD Monitor
DEAD IIYAMA AS4636D
SCREEN DEAD ,POWE LED IS ON STANDBY (ORANGE) ,SOMETIMES POWE LED GOES GREEN FOR FEW SECOND ,AN SCREEN LIT UP ,AND GOES DEAD , i HAVE NO MANUAL
  • SAMMY7 Dec 31, 2008
    Thank you for your help , I tried your solution ,and seems is working .thank you.
    sammy
    have a happy new year
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Posted on Dec 30, 2008
Panasonic PTL500 LCD HIDEF projector - Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
The bulb is a discharge type - it needs a very high tension to work. The role of the ballast board is to convert the low voltage DC current coming from the power source in a high tension DC current for the bulb. Unfortunately you were truly unlucky : when the ballast board died it sent a high tension surge thru the power source and from there at the other components on the mainboard - the processor couldn't handle it and got fried. So now when you try to start the projector this is what happens: the power source starts normally - the status light goes to green as it should; it functions normally so it powers the ballast board and the rest of the mainboard - the ballast works so the bulb lights up; the mainboard on the other hand remains dead because the processor is dead so no sustain signal is sent to the power source; without the sustain signal the power source goes, as it should , in an very normal stand-by - the status light goes to red.
The entire mainboard will have to be replaced - you can't replace just the processor, it's glued in there. This is going to be expensive so ask a quote before doing it.
Dec 23, 2010 | Televison & Video
Panasonic PTL500U LCD HiDef projector. Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
If you take the back off you might find a couple of bulged electrolytic caps on the power supply board that need change, or just buy a new power supply at www.partstore.com
Dec 22, 2010 | Televison & Video
Hello. My Nec LT35 projector will not turn on. From standby mode, I hit the power button, the power LED turns green, the fan starts, but after two seconds it switches back to standby. The...
i have the exact same error with same projector. did you manage to solve this?
my status led blinked red 6 times indicating a "lamp error" which wasn't helpful. i also tried removing and replacing lamp but didn't work.
Dec 01, 2010 | NEC LT35 Multimedia Projector
My htc wont open and when i connect charger, led light goes red what happen?
Maybe your battery is dead and will not charge. Normally when you connect the charger the led must become orange after a few seconds and green when the battery is fully charged. If it stays red the battery is not charging.
Jan 24, 2010 | HTC Touch Dual Slider Smartphone
What does it mean when that blinking green light turns to orange one in lp 350?
Hi
This would be "Standby"
When you press standby, the display and audio turn off and a blank screen is displayed for 15 minutes.
You can change the amount of time the projector stays in standby mode; see “Standby Time” on page 27 for details.
The LED lights orange while the projector is in standby.
• If you press standby again within 15 minutes, the projector returns to normal operations immediately. The LED changes from orange to green.
• If you press standby again after 15 minutes, there is about a 60 second delay before the lamp turns back on. The LED flashes green while the lamp is re-lighting.
• If you don’t press standby again, the lamp turns off after 15 minutes. The LED lights orange while the projector is in standby.
The full manual can be found here:
Infocus customer support
Infocus LP350 Manual
I hope these help
Mike
Sep 18, 2009 | InFocus LP350 Multimedia Projector
Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Jul 01, 2008 | Gateway 400SD4 Notebook
Sony green power/standby led blinks picture goes out
I had this same problem and after doing some research, I removed the lamp, cleaned it and plugged it back in. It fixed my problem completely.
Mar 22, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
GE 31GT740 clicks off and on
Dead, led flashing red/green at first, then going to red standby
Replace C604 (1000uF, 16v) elec. cap. It is in the decoupling circuit for the 5 volt supply
Reverts to standby from switch on via TV or Video
No 5v rail because FET MTP3055 o/c. (BUZ71 will do nicely)
Goes straight to standby, after a quick burst of power
Replaced R952 (39K), had gone slightly high
Nov 23, 2007 | GE 31GT740 31" TV
iiyama Pro Lite AS4636D (Black) 18.1 in. Flat Panel LCD Monitor Logo
539 people viewed this question
Top iiyama Computers & Internet Experts
William Miller
William Miller
Are you an iiyama Computer and Internet Expert? Answer questions, earn points and help others
