Question about EliteGroup P4M800-M7 Motherboard
I cannot boot windows xp
Hi guys i have a big problem!!
i have a brand new foxconn XE 925 motherboard and the problem is that i cannot boot my windows from the CD-ROM drive. if i make the settings (first,secondary,third boot device) and i set first boot device to CD-ROM,second boot device Hard Disk,third boot device floppy,it wont work.
i have tried to disable all the boot devices exept the first boot device...and still didn't work.
what settings i should do in BIOS to make it work
PS:the win xp CD is god so it should work.
  • 2,351 Answers
Hi praph_wicked, normal order would be, floppy drive first, CDROM second & Primary hard disk drive third.
How ever if your bios does not comply you can always press the F8 key every two seconds & that should bring up (Please select boot device). Which will look like this;
Choose the CDROM drive with the windows CD in it.
If you have just one CDROM drive, make sure the jumper on the back side of the CDROM is set to "Master". If you have two CDROM drives connected, set one as master & the other to slave.
If using an IDE cable for the two CDROM drives. The CDROM at the end of the data connector is to be set as master, the 2nd CDROM connects to the next IDE connector & Its jumper is set to slave.
Posted on Dec 13, 2008
I want to instal a windows XP SP3 on Foxconn 915 series with north bridgegrantsdale G-i915G with a IDE H.D.D (pata) and sata O.D.D,it seems that i need a floppy disk for raid driver,but i lost motherboard...
There are a couple options.
  • Check in BIOS to see if your motherboard supports IDE emulation mode. If it does turn it on and XP will install just fine.
  • Download and read about using nlite to incorporate sata drivers into an Windows XP installation disc. (You will need another working computer. Download nlite and insert the XP disc run nlite and select your CD as your windows install file location. Download generic sata drivers, intel has a bunch you can get for free. In the nlite menu to add drivers select folder option and select the folder with the drivers. Set anything else you want in nlite and burn the new XP disc. This disc will install just fine as it now has sata drivers.
Comment if you need further instruction.
Aug 18, 2011 | Foxconn 915P7AC-8KS Motherboard
Foxconn MB 66IMXPlus won't boot up
what can i do? i lost k8m800-m7a motherboard driver version RV3.01B
Jan 06, 2009 | Intel D101GGC Motherboard
Cannot boot windows xp
Test the CMOS BATTERY..TO MAKE SURE ITS GOOD IF NOT REPLACE.If it test good leave out for 5-10 minutes replace.motherboard bios should now beat default settings.reenter the bios.move cd to first changes.if you do not save changes it will not should now boot from disk.
Was this solution helpful? Show your Appreciation by rating it..RICHARDM69
Dec 14, 2008 | EliteGroup P4M800-M7 Motherboard
Repeated boot
I supposed you are using windows xp, put the Win XP cd in your cd drive and start your computer
boot on the cd drive, wait until the winxp finishes its copying
When asked if your want to install winxp or repair [R] choose repair by pressing R
wait till the command line and type: chkdsk /r
wiat until it finishes, it may take about 20 to 30 minutes..
reboot your pc
Oct 25, 2008 | Foxconn C51XEM2AA-8EKRS2H (0683562100229)...
Have to restart machine to boot Windows XP.
try upgrading/changing your switching power supply and make sure you plug in to your motherboard all the power requirement plugs it needs.
Jul 01, 2008 | Foxconn 6150BK8MC-KRSH Motherboard
Kvm800m amd2700 1 gig of 2700 shuts down at boot up
because your old motherboard and new hardware resource change over in windows xp so disble in cmos setup ACPI option
or if that have already disable so enble it .
if problem can't solve so reinstall windows xp
Mar 31, 2008 | Mercury KVM800M Motherboard
Foxconn 6100K8MA-RS Motherboard
Hi You need to make sure that your boot sequence sets to boot from hard drive first. Also, make sure that the hard drive sequence has the hard drive enabled. If this does not work, then let me know so I can give another suggestion.
May 30, 2007 | Foxconn 6100K8MA-RS Motherboard
Open Questions:
See all EliteGroup P4M800-M7 Motherboard Questions
EliteGroup P4M800-M7 Motherboard Logo
248 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
