Weather king outside gas furnace unit in not igniting
Have a lennox combo furnace that will not light but has been lit manually at times. This is an ongoing issue....worked for two weeks but is now acting up again and will not lite manually now. Had unit apart and cleaned checked all connection for tightness or issues. When manually lighting it ignites but within a sec flame goes out....any suggestions out there please help
Posted on Feb 07, 2011
If anyone has any knowledge on furnaces gas let me know mine keeps cutting the flame when the blower motor comes on idk what to try and fix but don't really want to call someone to fix it
gas and boilers if not fixed correctly generally result in explosions
Gas is not a diy item so get in a professional gas fitter to fix the fault and be safe
Oct 28, 2017 | Weather King Heating & Cooling
Weather king select furnace
At the opposite side of the burners from the igniter there is a small metal probe/rod situated where the flame would blow across it during operation. This rod is for flame verification so the gas valve will know that the gas is being ignited. Often that probe will get carbon built up on it which will cause the furnace to light but then abruptly shut off because "the probe doesn't know there is a flame there". A fine grit sandpaper works well to restore it's conductive ability. However, if the furnace runs for a while before it shuts off you could very well have an obstruction in the vent pipe or an obstructed indoor coil. If cleaning the flamerod doesn't remedy the problem, I strongly recommend a qualified serviceperson look at it! The furnace could well be turning itself off because something is getting too hot and coming back on when it cools. Good luck.
Dec 01, 2013 | Ruud Rheem Weather King Furnace Igniter...
I have RUUD furnace with build in coil for air conditioner and Weather King compressor outside of my condo. ALL EQUIPMENT IS 4 YEARS OLD I didn't have any problem with heat at winter, but in summe
When you remove the panel to the unit it turns off the power to it. The reinstalling the panel will reconnect power and allow the unit to reset. So the cheapest and easiest thing you can try is to replace the thermostat. Make sure you see how many wires you have connected to your existing tstat and buy near the same thing. It's possible that the tstat is acting up, not allowing the unit to cool when the temp demands. And turning off power is resetting the tstat as well as the unit. It will be hard to troubleshoot with the info provided so a new tstat will be worth a shot. Hope this helps!
Apr 07, 2017 | Ruud Matching Split Air Conditioner
My weatherking 90 furnace that is about 12 yrs old will not ignite the system works but will not ignite. The ignightor however glows hot. Thanks.
Hello, make sure the gas valve is opening and the burners are getting gas and verify that the gas valve is getting 24 volts.
Feb 15, 2011 | Weather King Heating & Cooling
I have a Weather King Acclaim Gas Furnace and I cannot find where to change the filter.........can you help me?
On some of these, the filters are located outside of the actual unit in the silver metal duct that attaches to the bottom half of the furnace. It has a 1" cut into it where the filter just slides vertically into place. If you need additional help, call Weather King directly at (479) 646-4311.
Douglas
Sep 11, 2010 | Heating & Cooling
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
Feb 28, 2010 | Weather King 10AJA6001AH Air Conditioner
I'm trying to figure out if our Weather King system has a heat pump... how do I tell?
Your indoor furnace is weather king? If you have a a/c unit outside, it could be a heat pump, but you have to provide the model number on it.. If you do have a unit outside, when you call for heat does the outdoor unit kick on?
Dec 03, 2008 | Heating & Cooling
Heating & Cooling Logo
111 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
