Question about Garden
Snow blower From the last tip the cylinder behind the pulley was moving, and i was trying to automatically start it, then it froze up again, do you still think i need a new engine.
    Problem Solver:
  • 7 Answers
Make sure that the ignition coil is not draging on the flywheel. Older engines had the ignition coil behind the flywheel. sometimes the magnets separate from the flywheel and jam the engine from turning over. If this checks out ok, the engine should then be totaly dissassembled for inspection. Depending on the damage found and the cost of repair, you'll need to decide which repair is the most cost efficiant way to go. Also look at the rest of the machine for its overall condition. It might just be wiser to replace the entire unit.
Posted on Dec 13, 2008
Toro 418 zr snow blower was smoking prior to last use. Doesn't start now.
Was it blue or black smoke? Did you change the oil and overfill it? Is the choke stuck on? Blue smoke is oil burning and black is too much gasoline. Did you tip it over? If you tip it it will make oil go into the valves and pistons.Pull your spark plug and see what it looks like May need replacing as well. Is your air filter clean? All these could effect how it starts and runs.
Dec 21, 2016 | Garden
Shifter stuck on peerless trans (dynamark snow thrower )
Generally one can tilt a snow blower forward and rest the unit on auger shroud to remove bottom skid plate. You will need to do this. Then follow the shifter linkage, it will move a rubber friction disc back and forth to increase/reduce speed of unit. It sounds like this shaft needs to be lubricated or is froze. try some penetrating oil and try to gently move shifter back and forth.
Mar 02, 2015 | Garden
I have a cub cadet that has seized I have tried pulling spark plugs out and put oil in cylinder and tried pull start won't start
If it won't turn over or if it is hard to turn over, it probably has a twisted crank shaft. It will have to be rebuilt or replace the motor.
Nov 29, 2014 | Cub Cadet Snow Blowers. 30 in. Two-Stage...
Auger won't stop
Open up plastic cover over belts.There is a pulley that moves against belt to engage front auger.There is a spring that hold it in the off position and when you pull the handle it moves that pulley.Sounds like spring broke or slipped off.
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Craftsman
Larry - the manual isn't really going to help you get this started. Press the primer bulb - if provided a couple of times to get gasoline into the cylinder. You may hear it squirt - or even see it drip from the carburetor. Try starting. If it didn't, remove the spark plug. Is it wet with gasoline? Is the chamber filled with gasoline fumes (you can slowly pull the starter rope to move the piston up and force the air in the cylinder out to smell for gasoline). It wet, dry it throughly. If there is no gasoline odor, give a brief spray of starting fluid or ether into the spark plug opening - and install a new plug - or the clean old one. Attempt to start again. If it tries to start and sputters, you likely have a fuel delivery issue. Make sure the shut off valve at the bottom of the tank or inline on the fuel line is open. If it is, I suspect that the float in the carburetor or needle valve needs to be cleaned / adjusted or replaced. You may want to have this done for you as there are some very small parts involved and attention to detail when re-assembling will be required. Carburetor rebuild kits are available for most of these engines.
Mar 02, 2014 | Craftsman Snow Blower 22 In. Dual-Stage...
Yardman snowblower won't self-propel
Do not start to do this but put the blower in gear like you would run to drive its self and try to turn the wheels by hand and if they turn easily then you may have a shear pin that is broken or missing in the drive pulley.
Just a thought.
Dec 12, 2013 | Yardman Yard-Man 31AH65LG701 357cc Gas...
The primer button on my snow blower won't force gas into the engine
The primer bulb may need replacing as they do crack with age and will not work. A small engine shop should fix you up .
Nov 29, 2013 | Garden
Craftsman snow blower wheels wont move. Help!
If it is a 5.5 HP dual stage, like mine, it could be that the belt has popped off the friction pulley. If you drain the gas, tip the unit on its "face" and remove the large shield on the bottom you will see a 3" pulley attached to the drive shaft. There will also be what looks like a fan belt floating around in there. That fan belt nees to go on the pullet, as it serves as the friction disk tio drive the wheels. Good luck. this happens to mine ALL the time. very frustrating. :(
Jan 19, 2010 | Sport & Outdoor - Others
Borrowed a neighbor's snowblower last night and cleared a driveway. Stored blower in unheated garage. Went to use blower today and got it started but the auger would not move. Very little wiggle in auger...
using the snow blower warmed it up ,it developed moisture in it then you put it away then it froze put a electric heater next to it but keep it away from the water[ the heater i mean].
Dec 21, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 247 88190 0 snow blower auger frozen
my auger and impeller froze too. fixed by clearing all snow, ice,stone build up behind impeller it works fine now.. hope that helps
Jan 19, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
55 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
