Question about Dell Dimension 4700C PC Desktop
Computer turns itself off alot
The screen goes black and the light goes out
  • jnkjordan Dec 13, 2008
    it goes straight back into windows? do you have any idea why?
  • 116 Answers
Is it going into stand by or actually shutting off? The only way to tell is when you turn it on does it jump straight into windows or does go through a list of things including how much memory there is?
Posted on Dec 13, 2008
  • Justin Washburn Dec 13, 2008
    Sounds to me like it is going into stand by......after sitting idle for a set amount of time it shuts drives and what not down to conserve power. So when you hit the power button after it turns off do you see a dell logo or see the scrolling wondows logo?
My computer starts normally, Once logged in the screen goes black. If I hold up a flash light I can see the screen a tiny bit... What is going on? I have tried restarting, taking the battery out
try doing a system restore on it.. more than likely you have a virus that is turning the backlight down to reduce visibility on the screen. definelty disconnect from your network while doing this... alot of times hackers will do this so you wont be able to see them navigating through your files..
Aug 25, 2010 | Acer Aspire 3610 Notebook
My screen is black, my computer has a light that shows when its on, the lights on but the screen is still black.
If your computer is older or you've used it ALOT and usually just close it and don't shut it off alot then you could need a new battery or you might have your light turned off on your screen
Mar 04, 2010 | Compaq Presario Notebook
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Screen goes black, but power light is on (not blinking)
The problem is not with your screen. Its the problem of Video Card of your system which is unable to send Video Signals to the Screen.
Apr 23, 2009 | Daewoo L700C 17" Flat Panel LCD Monitor
Screen goes black and SD-ms (memory card slot) light comes on..
Change the memory chip to another slot or swap two memory chips if you have two memory chips on both slots, see what happened and come back to me again.
Nov 17, 2008 | HP Pavilion dv1000 Notebook
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Screen will randomly change positions and sometimes turn black
Reset by holding in power slide for 10 seconds.
There are no firmware upgrades available from website. They suggest that you call the Geek Squad.
Jun 05, 2008 | Insignia Pilot MP3 Player
Monitor going black
HP's are known for bad capacitors in the power supply.
Replacing them is simple if you know how..not so simple if you don't.
Try your local TV repair centre. It should not cost alot to have the capacitors replaced.
Hope it helps =)
Apr 06, 2008 | HP Pavilion F1903 19" Flat Panel LCD...
Sony Cybershot S700 black screen when USB cable is inserted.
try going into the menu and doing a camera reset this corrects alot of connection issues. hope this helps.
Mar 02, 2008 | Sony Cybershot S650 Digital Camera
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
Dell Dimension 4700C PC Desktop Logo
55 people viewed this question
Alun Cox
