Question about Sony SCREW +PS 2X5 (BLK) (762825310)
The color on my sony model #KP-51WS510 stopped working
I unplugged the tv from the satellite and dvd boxes to move the tv. Plugged everything in again and now the color doesn't work. The picture is ok just black and white. When I plug the stuff into other holes in the back the color turns all blue and the picture is messed up.
  • 227 Answers
I would go to the setup and check the setting for returning to factory defaults
Let me know if this helps
Posted on Mar 25, 2009
Sony kp-51ws510 Rear Projection HDTV - Picture quality is fine, just doesn't have any red's in the picture. What shoud i look into?
Make sure the cable box or DVD/Blu Ray player is hooked up properly. Sometimes one of the component cables can become loose and lose the reds.
The red tube could be shot also. My old projection tv had the green go out. Believe it or not the whole thing can be replaced, but to replace a CRT on an older model can cost a lot.
May 18, 2012 | Sony KP-51WS510 51" Rear Projection...
My Sony KP-51WS510 is out of color focus. The blues and yellows are separating. I know there are three color bulbs that work together to create all the colors. Could the bulbs be out of alignment from...
Convergence ICs and CK all Pico Fuses around ICs they will look like resistors but will be Green or Yellow 5amp, 6amp, 7amp Fuses. Big Black ICs they will have the PN# on them
ICs STK392-110 use 120s Mats 1-800-628-1118
TV Repair Shop $255.00
Oct 21, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 on shows in black and white.
This DLP tv have a part call a colors wheel.Ur tv have a colors wheel,spinning couple hundred to a thousand RPMs to produre a colors picture.U hear like a loud grinding,squiling loud motor runing?This colors wheel part it dead,must be replaced.Hire a tv Tech for this job,the colors wheel,it very difucult to replaced.U have no machanicals,had never done this before.
Jun 02, 2010 | Sony KP-51WS510 51" Rear Projection...
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510 convergence problem. Replaced IC's and pico fuse
Nothing else to look for but to Replace the Convergence Ic's
Nov 06, 2009 | Sony KP-51WS510 51" Rear Projection...
Horizontal color lines..
problem can also be in VPB (video process board).But without the model name its very hard to tell you more
Jul 27, 2009 | Sony KP-51WS510 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Feb 01, 2009 | Sony KP-51WS510 51" Rear Projection...
I have the same problem. Please advise how to fix it.
my sony kp-51ws510 is out of alignment and the colors are in 3d
Dec 09, 2008 | Sony KP-51WS510 51" Rear Projection...
Color issues
This is a convergence problem that can be as simple as poor solder connections at the convergence ICs to defective ICs. Can you solder? If so, let me know and I'll provide additional instructions.
Dan
Sep 05, 2008 | Sony KP-51WS510 51" Rear Projection...
Computers & Internet Logo
144 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
