Question about LG (GCC-4522BI) CD-RW/DVD-ROM (Combo) Burner
Can read cds but not dvds
I have a combo drive that used to work, but now, it can only read cds, but not dvds, please help
    President:
  • 2,961 Answers
Try this, but if the problem persists, you need to replace the drive. Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers.
Posted on Mar 23, 2007
SOURCE:
My combo drive is not reading CDs but reading DVDs perfectly
a different laser is used to read CDs than is used to read DVDs. The laser for you CD reader has most likely gone out of alignment. It's time for a drive replacement.
Dec 09, 2010 | LG (GCC-H23NB) CD-RW/DVD-ROM Combo Drive
Does the toshiba sd 2502 , can it burn cds
It is a DVD ROM drive which stands for DVD Read Only Memory. In other words, this drive is meant to only PLAY DVDs and CDs but NOT save data to them.
To burn CDs you need a CD burner. Burners are of 3 types:
CD writer only burns and reads CDs.
Combo drive reads CDs and DVDs but only burns CDs.
Super drive burns and reads from CDs and DVDs.
As you go higher in functionality, the price also increases. Check your needs before you plan to buy one. Also compare prices of all the drives. Note: burn-able media costs are separate.
Dec 11, 2009 | Toshiba SD C2502 Internal DVD Drive
My cd drive will read cds but not dvds i try to istall somethig it wont work
Hi dkush29306,
while the other two posters have pointed out the obvious, that CDROM drives only read CDs, and that you need a DVD drive to read DVDs, i would like to add something to this.
I will asume you have a CDROM COMBO Drive, that *should* play CDRs and DVDs.
if you find it does spin CDs up and read them, but not DVDs then i might be able to offer some suggestions.
firstly, make sure there is no software conflicts (like two CD Writing softwares trying to use the CD Drive at the same time.. ). you shouldnt have to worry about drivers for the CDROM, as the default OS ones should suffice. but they may be corrupt. you could goto Device Manager if you are on Windows, and uninstall and reinstall the driver for the CDROM. it should find it automatically in the install wizard.
ok at this point i don't see how software could cause any other issue , so we should look at it being a hardware issue:
if you have the ability, try changing the IDE Ribbon Cable that connects the CDROM to the Motherboard. if that doesnt work, try changing which plug in the IDE cable the CDROM plugs into. these plugs usually have a blue plug at one end (motherboard end), and there is two plugs at the other end, or master and slave. keep the jumper pin on the CDROM set to Cable Select, so you dont need to change it to slave, when its plugged into the slave port, or master pin if set to the master port.
finally, if none of that helps (and it probably won't ) you might find that the actual fault is due to the laser in the CDROM not focusing tightly enough and therefore cannot read the data on a DVD ROM because of this. the only way to tell if this is ok or not, is to plug it into another computer and see if it can read DVDs.
you might just be better off spending 20-50$ and buying a new CDROM Combo drive from your local computer hardware store.
Jul 17, 2009 | Computers & Internet
My DVD drive in ACER Aspire 4720 not reading burnt DVDs and CDs
well look for cds that are thicker and sturdier. some low cost CDRs are too thin and/or soft that they cant handle the heat generated by the cd drive.
Jun 04, 2009 | Acer Aspire 4720 Notebook
Suddenly stopped reading cds but reads dvds
Could be a bad drive, as DVD lasers are a little different than just CD lasers. The laser may be bad for one, but the other can work. I had this issue, had to buy a new drive.
Apr 20, 2009 | NEC ND-2500A DVD±RW Burner
I can burn cd's but not dvd's
Hello Rfd832,
What I see from the description is that the drive is a combo drive. Combo drives are CD-RW and DVD-ROM drives means
CD-RW = Compact Disk-Read Write
DVD-ROM = Digital Versatile Disk - Read Only Memory
so these drives can read and write CDs but can only read DVDs (Cannot write or burn DVDs)
If you want to be able to burn DVDs then you need to have DVD RW drive (either DVD+RW or DVD-RW)
You said that you are able to burn DVDs on other computer so please check the label on the DVD drive.. it should be DVD-RW/DVD+RW drive
Hope that helps.. :)
Thanks and Regards,
Srinivas
Apr 12, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Can the lite-on combo sohc-5236v burn DVD-Rs?
A Combo drive is a type of optical drive that combines CD-R/CD-RW recording capability with the ability to read (but not write) DVD media
Lite-on SOHC-5236V is a dvd/cd-rw combo drive so it can read and write CDs and read DVDs (but cannot burn DVDs)
to check the details of this product please click here
Feb 01, 2009 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
DVD NOT READ
if you are good at opening then open the combo drive and clean the lens once by using some lens cleaner solution and then refit it it should work ...
if you still persist the problem then think that the life of the combo drive is getting down and the time to purchase new one is getting nearer ..
after some days your combo drive will fail to read the cds but it will read occasionally for some days after that it will not read anything that s because the lens is becoming weaker ...
at the cost of replacing the lens you can purchase the new dvd writer ...
but also try cleaning the lens with some lens cleaner solution after that it may work for some days ..
the only problem with the combo drive is the lens will be weaker than the normal dvd writer or cd writer so after some days of usage it fails to detect dvds followed by it fails in detecting of cds too ...
thank you
rate my solution
Sep 11, 2008 | Computers & Internet
Not reading DVD
It's common problem with combo drives in notebooks, they don't seem to last long. Try this:- Go to my computer>properties>hardware>device manager and look down the list for your cd/dvd drives and click the '+' sign then highlight your dvd drive and right click to delete. Restart the pc and windows will find the drive again automatically and install the drivers. If the problem persists the laser is faulty in the drive and the drive will need to be replaced.
Mar 07, 2007 | Sony CRX830E CD-RW/DVD-ROM (Combo) Burner
Computers & Internet Logo
190 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
