Question about Axsion AXN6070 Portable DVD Player
Dvd player I have an axion 7" portable dvd player. when the dvd is plugged in it works fine. I charge the battery and the red light flashes. I assume this means it is charging. When I try to watch the dvd player using the battery it doesn't work at all. The power light comes on but no picture or sound. What am I doing wrong?
  • mil1996 Nov 21, 2007
    my axion dvd player is working but the picture won't come on and also the dvd is not reading and keeps saying no disc. and the sound does not work. pleas give me an solution
  • Anonymous Nov 22, 2008
    I have an Axion 16-3903 portable DVD player. It can turn on, the battery is charged, I put in a region 1 DVD, but I keep on getting a "loading" sign and it won't play
3 Suggested Answers
  • 67 Answers
SOURCE: WON'T PLAY, WON'T TURN ON, WON'T CHARGE
do not throught away they just need new battery if has adapter plug in use newest cd u own first take qtip and achol dip q tip n achol blow exces fluid oped cd cadge very very gently wipe laser with wet q tip do no pres hard the use dry end to shine laser will work like new hope this helps u good luck new batt /// battery.com wont charge because a r worn out they only last about 9 12 mounths
Posted on Jul 25, 2009
caroldon
  • 17130 Answers
SOURCE: Axion AXN-6053 DVD player won't play DVD. When I
Please try to put in an ordinary audio CD track and see if this is detected. If yes the optical is working, if not there is no laser scanning and the possibility of the head being faulty is high.
It is best is to cleaning manually the laser head eye with a cotton bud using gentle pressure without pressing the lens eye.
If there is no result then it is possible that the optical head unit is faulty.
Posted on Jan 12, 2011
Dvd player doesnt play the movies
Try another DVD. If problem persists and it does not work with any type of DVD, whether recordeable burnt DVDs or original pressed DVDs then your unit is bad - either dirty lens or the laser diode is bad.
Sep 26, 2009 | Axion LMD-6708RY 7 in. Portable DVD Player...
Axion dvd player 6070A 7 inch screen stuck on loading
not good, the unit will cost more to fix than replace. The only thing that might help is if it has a removable battery, if so take it out and leave it out for an hour, & try again. You might try using the power cord instead( I dont think it will help but try it before you toss it out)
Jul 11, 2009 | Axion AXN-6070A 7 in. Portable DVD Player...
No user manual for Protron PDV-288 portable DVD player
nahh you cant over chargee silly;; when its done, its done, it just doesnt loose battery power. and im not positive about the light.. but i would most likely assume that when the green light is on, that means its charging.. thats how pretty much every electronic works.. light on-charging; light off-no charge. sometimes it varies by different color lights.
thanks ! hope i was helpful.
Feb 10, 2009 | Protron PDV-288 7" LCD Portable DVD Player
Charge indicator light on Protron PDV-288 portable DVD player
now maybe you could help me. i have the same portable dvd player and i have the plug in that goes into the actual player.. and you know how its that weird looking end that has the light that lights up.. well what is that supposed to plug into? because i dont have anything that it can plug into and im not sure if i am missing a piece..
Charge battery for zenith dvp615
michelle,
not so familiar with this model but try this:
1) Plug your power adaptor to main unit
2) locate "power on" switch and change it to "off"
after doing this steps you will see a red light which means the unit is charging.
note: for some portable player once the charging is complete this red light changes color either orange or green which means the battery already full charge. but it is adviceable to charge battery for atleast 2hrs.
cheers,
mark
Jan 29, 2009 | Zenith DVP615 Portable DVD Player
Dvd player recharger charge status lights blink
The blinking went away as I had charged it for a very long time. However, it was noted that it would not work on the DVD. The battery needs to be replaced. That solved my problem. I still have to look for a new battery for this device: US Logic 680p DVD player with recharging capabilities due to the portability option. It works fine if plugged in, but the battery just needs to be replaced if I want to use it independent of the plug. Thanks for asking how I resolved the issue.
Nov 25, 2008 | US Logic 680P Portable DVD Player with...
CHARGING
Lulu1121 and guest, red means no charge and will remain red till its fully charge. Then it will turn to green. In fact, coby battery can be charge directly without the whole unit attached. But if on charge too long and still red, battery is dead, kaput, finish. some even show evidence when the casing is swollen...gel chemicals inside is swollen. The power supply that came with it is the only way you can use it...portability is out of the question.
Good Luck
Siliconchip
Nov 20, 2007 | Coby TF-DVD7107 Portable DVD Player
Battery won't charge
clean the contacts of the battrey and the charger.if that does not work replace the charger or the battery.goodluck.
Apr 03, 2007 | kawasaki PVS-10921 Portable DVD Player
Axsion AXN6070 Portable DVD Player Logo
242 people viewed this question
Top Axsion Televison & Video Experts
Are you an Axsion Televison and Video Expert? Answer questions, earn points and help others
