FixYa.com
Tags:
FEC RKMV5 Custom Rackmount Kit for JVC RKMV5
I am facing a Squished picture, what can i do? (by 13 users)
By M0nica L - usenet poster
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
12 Other Users Have The Same Problem
Comment by ecphomstuff, posted on Jul 14, 2008
the color change to be black and wite now no color as usual
Comment by smaniack23, posted on Jun 28, 2008
this dvd player has a video role or jump. i cant see the menu long enough to change setting. ive used differ rca cables as well, how do i fix it??
Comment by Guest, posted on Jun 26, 2008
MY SCREEN IS DIVIDED INTO TWO PARTS WITH BLACK AND WHITE NO COLOUR GOOD SOUND WHAT CAN I DO
Comment by friekiefroe, posted on Jun 15, 2008
I'm looking at a with and black screen, and i know it is something about to select with PALL, but i don't get into the menu.
Comment by Guest, posted on May 31, 2008
jumping picture and no color
Best Solution
posted on Aug 08, 2005
Helpful (85)
Duke
Duke - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Check player's setup menu to make sure it's not set for a wide-screen TV if you don't have one.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on May 18, 2008
Not Rated (0)
JordonBabbex
Rating: 40%, 2 votes
Heyy My Names Jordon Carterr :) Um Why Dont U Take It Backk Or Call Someone Thats Good At These Things It Anit Harrd From Jorrdon Carterrrrr Duuudee :)
Solution #3
posted on May 17, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
एक छोटे से शहर का छोटा परिवार का सबसे छोटा लड़का । जिसकी एक ही चाहत है क‍ि वह एक दिन इस दुनिया की भीड़ मे अपनी छोटी सी ही सही मगर एक अलग पहचान बनाए। नाम है प्रेम प्रकाश मतलब प्रेम का प्रकाश फैलाने वाला इस कारण मे शायरी , कविता लिखता हूँ अब इसमें कितना सही हूँ यह तो आप ही बता सकते हो - आपका अपना "प्रेम प्रकाश"
Solution #4
posted on May 07, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I can not change the aspect from 4.3 to 4.3 wide because I can not do this because I am on AV4. How do I change this?????
Solution #5
posted on Apr 03, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
eflipo
Solution #6
posted on Mar 17, 2008
Not Rated (0)
donnsa
Rating: 0%, 0 votes
my dvd recorder wont format, any suggestions
Solution #7
posted on Sep 08, 2007
Not Rated (0)
hattonhall
Rank:Master Master
Rating: 75%, 11 votes
Monica....do you mean "Squashed" ? or are you describing a screen image that it distorted or out of shape in some way so as to be unacceptable to view properly?
If the picture is visually perfect but not filling the screen the way you prefer...then yes...Use your DVD unit remote control to "Setup" the screen display aspect ratio(how wide by how high" following the instructions in your user manual. If this fixes your problem...fine...if not, I look forward to your next posting which I encourage you to describe more fully in words that convey the problem more succinctly. Hope this helps - hattonhall
Solution #8
posted on Aug 08, 2007
Not Rated (0)
CanDo
Rank:Wiz Wiz
Rating: 76%, 111 votes
It is resolution adjustment that needs to be made. You will have to go into the settings in the controls to adjust this to normal.Follow your owner manual and it will show you the way.
Solution #9
posted on May 29, 2007
Not Rated (0)
ffarkle
Rating: 60%, 3 votes
Are you certain that you are facing a Squished picture, and not a Squashed picture? If you are facing a Squished picture you should review the setup directions of both your signal source and your TV to determine that both units are consistent in format, IE both are set for widescreen. If you are facing a Squashed picture, however, there will be little that you can do other than adjusting your eyeglasses. You may have them upside-down.
This Problem Also Relates To: Audiovox 10.2'' Portable DVD/LCD Shuttle System (DT102DOPKG) Audiovox DVDVCP01 DVD Player / VCR Combo Memorex MVD4543A Panasonic (DMR-ES45VS) Panasonic DMR-EH57 HDD Recorder Player Panasonic DMR-E55 DVD Recorder Panasonic DMR-ES10 DVD Recorder
Can you Help with these DVD Players problems?
Burned dvd won't play in dvd...
I haven't used the... Answer This...
dvd/cd-rw drive
my dvd/cd-rw drive recognize... Answer This...
DVD- RW drive
The DVD-RW drive of my PC is... Answer This...
how to put plugs in a dvd
i am having a panasonic vcr ..... Answer This...
ted
sex reletive Answer This...
12 Other Users Have The Same Problem - Continued
Comment by nascargrandp, posted on May 25, 2008
My screen is showing a split picture. I can see the bottom part of the video on top of the screen. Nothing wrong with tv on cable.
Comment by nytony10, posted on May 22, 2008
had a storm come through and then our picture went funny, looks like the wording is arched rather than horizontal and picture is fuzzy and duplicated
Comment by RED DOGG, posted on Jan 11, 2008
GOOD SOUND JUMPING PICTURE
Comment by Guest, posted on Jan 04, 2008
on the setup menu set the 4:3 choice to "normal" not "FULL" That should fix the problem.
Comment by friendm, posted on Dec 22, 2007
i have a dvd/vcr and i am recording tape for dvd, but i have a problem the vcr screen is black and white what should i do to fix it
Comment by Guest, posted on Dec 19, 2007
i have a black picture
Comment by DVD Viewer, posted on Dec 14, 2007
Same problem here. Squished picture. There doesn't appear to be a way to get out of wide screen form in either the Setup or Mode menus. I have a Colby portable DVD player which has the adjustment to go from normal to wide screen. Is there another menu that I'm missing?
Repair Service
Find DVD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
