Question about Dimplex DS5603 Heater
Remote control working with fireplace.
We have inherited a Dimplex Electric Fireplace with a remote control.
Fireplace works very well, lots of heat. However we cannot get the remote control to turn it on and off. We put a fresh battery in today - the led light on the remote comes on, as it did before we changed the battery,but no change to the 'fire'.
Where is the remote receptor button on the fireplace located? We have looked for it but cannot locate.
Also, is there a way to make the flames higher and brighter? How do we change bulbs? Can't figure out our access into the fireplace.
The previous owner is deceased, so we can't consult with HER!
The fireplace is a Dimplex 'Air Heater' 120VAC model # 6901860400.
There appears to be no such category in your list of products below.
Thank you so much.
Heather
Heather
  • Anonymous Mar 24, 2014
    Lost the remote control for fireplace heater. Think model is 26MM9067-NC72
  • Dimplex Master
  • 2,179 Answers
Try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
Dimplex optiflame remote not working
The DFI2310 uses a simple plug-in remote.
You can either order one from Dimplex, or use an aftermarket solution such as this one from Skytech: Skytech 1315G Electric Fireplace Remote.
Oct 08, 2012 | Dimplex DFI2310 23 Inch Deluxe Electric...
Dimplex 3015 purefire remote will not torn fireplace on or off. Tried to reset remote, but no results. I have 2 fireplaces of the same type, and an old and new style remote. Tried with both remotes, but...
Apparently, the receiver on one fireplace is faulty. If this a plug-in wall type receiver, unplug it from the wall, wait 5 minutes and plug it back in. That 5 minutes may have given it time to reset itself. If you see any scorch, burn marks or melted plastic on the receiver box, it will have to be replaced. Contact Dimplex USA, Technical Service Dept at 888-346-7539.
Hope this "remotely" helps to solve your problem.
Mar 10, 2011 | Heating & Cooling
Hi I have a Dimplex electric fireplace model# CS3311. I had the Remote Receiver plugged into the wall outlet and the Unit Plug was plugged into the side of the Remote Receiver, just like it says to do in...
Lisa, apparently there was an electrical overload in the receiver box. I assume this electric stove is new and still under warranty. In which case, armed with your Proof of Purchase, you need to contact Dimplex USA or the retailer you purchased it from.
Below is a link to Dimplex USA Customer Support.
http://www.dimplex.com/customer_support/contact_us
Feb 23, 2011 | Dimplex Compact Electric Flame Stove...
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a Dimplex Fireplace with remote control. I believe the model number to be BF335STP/DXP. We have had this fireplace for almost 2 years. When we have a power outage you have to follow some...
There was a recall on some of the remotes. Check to see if yours is one of them. If you take the plug put of the remote box, and just plug it directly into the wall,it should work.
Nov 30, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
Does dimplex model 6902340100 have a fuse, stopped working no fan, no light took back panel off could not find a visable fuse.
My friend just had the same problem. It turned out to be the Remote Control box,( the little box you plug the Fireplace into so you can use the Remote). He just plugged the Fireplace straight into the wall outlet, (without the Remote) and now it works fine.
Oct 19, 2010 | ACE Dimplex (r) Compact Electric Fireplace...
My electric fireplace model # HEF33WDG, the heat works, but the flames dont move. Can someone help me.
go to ebay and put in electric fireplace heater parts, the flame motor is around 20 bucks, and the heater element around 50 bucks Good luck
Oct 21, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Oct 15, 2009 | Leisure HOMEPRIDE Electric Fireplace...
Rewiring Fireplace Electrical Insert
I looked up regular electral diagram for the different elements.
Dec 15, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Dimplex DS5603 Heater Logo
1,060 people viewed this question
Top Dimplex Heating & Cooling Experts
paulcarew
Iron
Iron
Mike Cairns
Mike Cairns
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
