Question about Carrier 52CQ315 Air Conditioner
Our refrigerated window air-conditioner is really loud like
When I turn our air-conditioner on its really louds it seriously sound like a truck and the noise persists until you turn it off, is it a simple mechanical fault or does it need to be renewed? It has pretty much done it since it has been installed. How can I fix it
  • 334 Answers
The installer probably left a piece of cardboard, plastic, or styrofoam in the unit from packing that is being hit by the condensor fan blades.
Pull it out of the wall, and look for any obstructions of that nature.
Also look for any loose wires or parts that could be hitting it.
It also is not unheard of to have a fan motor with bad bearings from the factory.
Posted on Dec 13, 2008
Frigidaire fac127s1a is really loud - 70db+ - any fix available?
You might be able to find a sound insulating blanket that wraps around compressor. Check with a Carrier or York dealer. Most brands use the same compressors so you might be able to score one.
Jul 02, 2014 | Intertherm P3RC-042K Air Conditioner
How do i Turn off the beeping sound from mr slim ac unit? I've read all the manuals and searched the Mitsubishi site and the net extensively. Each time the unit is turned off or on, it emits a loud...
It requires surgery to remove the beeper :) seriously, find a local nerd to go in, not hard to do, and yank out the little piezo buzzer. I've had customer that wanted the same, factory said sorry no dice.
Sep 24, 2013 | Mitsubishi Mr. Slim MXZ30TN Air...
When the central air turns on it is very loud. I assume its the fan or whatever is in the attic. it sounds like a really loud regular window air conditioner on high coming through all of the vents. Is this...
No. This can be caused my a dirty squirrel cage on the blower motor which is found in your air handler in the attic. Probably needs to be pulled out and cleaned. This noise is caused by the blower wheel out of blanace.
Jun 25, 2010 | Heating & Cooling
Loud screeching sound coming from the unit
It sounds like the fan motor needs lubricating. Do you need help with this?
May 05, 2009 | Amcor A12000E Nanomax Portable Air...
Loud bang, sounds like the motors going to drop out when the compresser kicks on,17 years old, relpace/repair
The actual internal motor in the compressor dome is mounted on springs. Over time these get weak and hence the loud bang noise when the motor hits the sidewall of the compressor housing. It is not too serious and will probably work for ages. Just anoying. Leave it until it really packs up.
May 04, 2009 | Heating & Cooling
Way too loud
it is prob. a pipe vibration, window unit are not knowen for quiet running
May 02, 2009 | Goldstar KG6000R Window Air Conditioner
Sherp air conditioner AFR120DX running loud. Drain is open and there is no water buildup. The fan shaft seems to be straight and smooth. Any suggestions for trouble shooting?
It sounds like it could be low on refrigerant. without refrigerant it will be loud and it will not sweat. However it could be restriction in the refrigerant lines that will not allow the refrigerant to move. This will have the same symptoms. Both solutions sound like a job for a licensed technician.
Jun 16, 2008 | Sharp Heating & Cooling
Carrier 52CQ315 Air Conditioner Logo
59 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
