Question about Stoves Premier 900GRa Gas Double Oven
My igniter doesn't work
I have a 2nd hand Parkinson Cowan Sonata. When I push the igniter button nothing happens, no clicking, not a peep. Someone told me that I can replace the batterie(s). I've looked for a possible batterie compartment but can't find one - not sure where to look exactly....I've checked the back of the cooker and there isn't a plug (thought maybe it plugs into the mains). Is this easily fixable or should I just buy one of those clicky things for lighting it.....? Thanks in advance for your help.
The battery holder is located under the cooker, on the right handside. It swivels forwards and holds two AA batteries.
Posted on Jan 13, 2009
My igniter on the cooker doesn't work, it doesn't click or make any sound
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
May 17, 2011 | Ovens
Hi i cant find a parkinson cowan built in gas cooker
Used or brand new? In which country?
You won't find them new in shops as they're no longer made. But you *might* find a NOS (New, Old Stock) Alto GM60 from an online stockist, but the manufacturer's guarantee will be worthless and some spare parts will already be difficult/impossible to obtain. You'll also need to check before purchase whether it's for natural gas, lpg, butane or propane.
All late (approx. 1990 onwards) Parkinson Cowan models had appalling build quality and frequent electronic faults, so I strongly advise that you look for a current brand.
Aug 02, 2010 | Ovens
Missing instruction manual for IKEA Whirlpool oven FC SM6
After a powerbrake the IKEA Whirlpooloven doesn´t work, the display just says STOP and nothing works, not even the light inside the oven. This always happens after a powerbrake and usually I can fix it after some time pressing different buttons but not today. Suggestions?
Dec 17, 2009 | Ovens
Start button not working.
probably your button is dirty had carbon inside. do you hear a click sound when press it? if so , the IC did not received the signal, it need to be check by a technician.
Jun 30, 2009 | GE Profile JT910SASS Electric Single Oven
Electronic ignition system failed
electric ignition. Electric goes to ignition button, then to a spark generator, where upon a spark is produced. If any part of this sustem is wet, then it is shorted to earth. No spark.
Feb 11, 2009 | Bosch HBN 131560B / 131520 hot-air...
Lg lre30451sw oven the start button doesn't work
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner, but I fixed it today!!
Sep 25, 2008 | Ovens
How to light our gas cooker
Modern gas cookers use an electronic ignition switch rather than a pilot light to light the gas for cooking. This means you can light your gas cooker with the touch of one button instead of using several matches or a flint lighter. Of course, you still have the option to light the gas cooker by hand with matches or a flint lighter if the ignition switch does not work the first time.
1.Open the gas regulator valve by pushing it in and turning it to a low setting.
2.Push the ignition switch once.
3.If the gas cooker does not light on the first try, close the gas regulation valve for one minute by pushing in on it and turning it back to the "Off" position.
4.Open the gas regulation valve, set it a bit higher than you did on the first lighting attempt, and push the ignition switch again.
5.Light the gas with a match or a flint lighter if the gas cooker does not light when you push the ignition switch again.
Feb 23, 2008 | Ovens
Fisher and Paykel electric cooker (Pepper)
No, it's the first 2 buttons on the left pushed together as well as the + or - to set the right time
Jan 07, 2008 | Ovens
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Stoves Premier 900GRa Gas Double Oven Logo
1,370 people viewed this question
Top Stoves Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you a Stoves Oven Expert? Answer questions, earn points and help others
