Question about Philips FR965DHT Receiver
Well really its not a problem, its actually quiet simple really
I just want to know whats the best way to hook up my speakers to the receiver
    Problem Solver:
  • 4 Answers
I have always used Monster flat wire as it can be placed under along the carpet and the wall without leaving bumps under the carpet and it can also be painted if you need to run it exposed up a wall
Bill
Posted on Dec 13, 2008
I want to get music from iPhone 6 and 6s to Yamaha Audio Receiver RX-V661-what is the best way? Bluetooth receiver, etc? Need pls specific model numbers that are compatible with that receiver
The first paragraph mentions an optional iPod module.
http://usa.yamaha.com/products/audio-visual/hifi-components/stereo-receivers/rx-v661_black__u/
Dec 14, 2015 | Yamaha Audio Players & Recorders
Do not know how to wire my sa-w10 speakers together
For surround sound, you need an A/V receiver with 5.1 or 7.1 surround capability. Depending on what kind of receiver you have, the DVD player, satellite/cable box, etc hooks to the receiver, those signals go out to the TV, and the speakers hook to the receiver. The receiver decodes the signal from the cable/satellite box or DVD player and routes it to the appropriate speakers. If the TV program or DVD isn't HD or coded for surround sound, the best you can expect is 2.1 channel stereo sound. OR, you can hook everything (DVD, satellite/cable box) to the TV and run an optical cable from the Digital Output of the TV to the receiver, which is basically the same thing, just a different way to hook everything up. Hope this helps
Feb 23, 2014 | Audio Players & Recorders
I have a fisher ca-9335 integrated stereo amplifier thats hooked up to sanyo tp 1010 turn table and plays out of yamaha ns-70t speakers. a simple jvc cd player is also hooked up to the speakers but not to...
Something doesn't add up. You mention two connections to the speakers - CA-9335 and a "simple jvc cd player". Is that true? If so, you might want to UNconnect the CD from the speakers and run it into the receiver where it belongs. An amp isn't designed to share the load with another live device; or even have electrical contact with anything BUT speakers.
Did you actually find documentation that supports this hook-up? Or just winging it?
Feb 20, 2011 | Audio Players & Recorders
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
Quiet Noisey feedback out of speakers
The speakers are not hooked up correctly. I don't know if you still have the instructions but it is a hardware problem and not software. Try to figure out how to hook them up correctly.
Dec 27, 2008 | Dell Inspiron 1521 Laptop
I have a Philips FW- M777 Hi-Fi unit, which i was using the other day at a relatively low volume, no more than 25/40 when all of a sudden there was a burning smell which may or may not have been the hi-fi,...
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=FW-M777/22&scy=GB&slg=AEN&grp=HOME_ENTERTAINMENT_GR&cat=AUDIO_SYSTEMS_CA&sct=MINI_SYSTEMS_SU(JUST COPY & PASTE THIS INTO YOUR BROWSER)THIS WILL GIVE YOU A GOOD STARTING POINT.THANX FOR USING FIX YA,PLEASE RATE ALL REPLYS
Nov 16, 2008 | Philips Audio Players & Recorders
Speaker hook ups
It seems you are implying that your receiver itself has got an amp though small. You use another amp to boost your power, is that right?
It will definitely damage both your receiver and amp, just waiting which one to go first if you do what you are saying. In the first place how do you connect your receiver to the second amp? it has a line out i suppose? and for now your speakers are only connected to the booster amp? So it is only a matter of selecting where your speakers get connected when you wanted. DO NOT, in any case splice your speaker wire to attach your receiver speaker to the output of your booster where your speakers are connected.
What you can do is just make a switch selecting which source you will use for your speakers. You just need a simple toggle switch 2poles/double throw. 1pole for each channel (R/L) connect your center pole to speaker, the other selectable 2poles to the output of booster, the other pole to the receiver. (each channel) that is your safest. If you a a techie you can actually make a power driven relay switch to select the speakers where to get connected but maybe you can not do that on your own. it has to be someone with knowhow, simple design though. the same principle, your meccanilca 2pole/double throw switch will be replaced by the same specs but relay. elecically driven whrn you turn on/off your booster.
redrivera0314@yahoo.com
Mar 23, 2008 | Audio Players & Recorders
Only one centerback speaker
First off, I would like to say congrats on the receiver purchase - it's a nice one. To get true 7.1 surround sound, you will have to run another wire to another speaker. Any of these listening modes that you want to get are most likely using the capabilities of these 7 speakers. If you were to hook up one speaker to the two rear surround channels, you would be defeating the purposes of having that extra "speaker" and not really be gaining anything. If you really do want to access the 7.1 listening modes, you could always hook up another speaker and just hide it behind your TV, depending on your setup (essentially tuck it in a place where it wouldn't be heard, close to the receiver so that you don't need a long wire run).
In answer to your specific question, there would be ways of doing this, but just not all that advisable - you'd be posing a hazard to your speaker and/or the receiver. Like I mentioned, I'd recommend going through the trouble of running another wire and hooking up an additional speaker for the rear surround. If you're going to be using a Bluray or HD-DVD player, it'll be worth it. Hopefully this helps to somewhat answer your question.
Dec 19, 2007 | Onkyo TX-SR605 Receiver
Speaker Hook Up - Non-Technical (single) Female
bought the same amp second hand and had same problem as there are two seperate amp chips inside one for front speakers and one for the centre and rears it could be the actual amp chip that drives the front speakers has died as there is no built in speaker protection so over driving these speakers will result in the amp chip blowing . it may be something simple but it was not on mine had to buy new amp chip and solder in that sorted the problem for me !
Jun 02, 2007 | Technics SA-DX950 Receiver
Philips FR965DHT Receiver Logo
81 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
