Question about Kitchen Ranges
I NEED AN INSTRUCTION MANUAL FOR BOSCH UNIVERSAL MIXER
BEST NR 0710012101
U.T.C. 177364
  • rmgott Jan 30, 2009
    My Spur gear in my Bosch Universal 0710012101 has broken and I need an instruction manual so I can find the right parts.
    Thank you.
  • Anonymous Mar 14, 2009
    I need a manual for my Bosch universal stand mixer.
Http://www.kitchenresource.com/pdf/manuals/MUM6NxxUC.pdf
newer machine with larger bowl and dough hook but should work.
Posted on Jul 13, 2009
  • scmstr631 Jul 13, 2009
    If spur gear means the plastic gear in the middle of the bowl...
    I just repaired one.
    On the older machine you list, the vertical drive shaft, which comes up through the middle of the bowl, has a short horizontal metal cross piece extending out from both sides of the drive shaft. This horizontal piece prevent removal of the drive shaft, it will not fit through the center of the plastic gear. This is the gear which drives the whip beaters. On newer machines, and on the replacement plastic gear, there is a slot in the plastic gear which allows the drive shaft with horizontal piece to pass through. On the older machines this is not so, there is not slot in the plastic gear. So two choices, remove horizontal metal piece or make a slot in the gear for the horizontal piece. I don't know how to remove the horizontal metal piece from the drive shaft. So I drilled holes in the spur gear, which ruins it of course, and removed the vertical drive shaft. Don't drill deeper than the gear teeth go after the plastic gear ends, the bowl starts. The gear is held in place with two screws. If you hit metal, it is the screws, move were you drill a bit if that happens. You can always replace screws if necessary though. There are screws on the bottom side of the bowl to undo which must be unscrewed to removed the vertical drive shaft. Now, looking from the bottom of the bowl, into the center of the bowl where the vertical drive shaft was, you will see the two screws which hold the plastic gear in place. Remove the screws and you will have taken off the gear. Order 3 - 019929 Spur Gear, Column $23.99 athttp://www.cooksquarters.com/info/produc... I believe I have seen it for ~$10 elsewhere. You'll need to search. This part is a bit different than the original as it has the slot for the horizontal cross piece on the vertical metal driveshaft. Good luck.
Hi, can sb please help I'm looking for a user manual for my w/machine Bosch E-nr # WFM2010/08 in English. Thank you
According to Bosch (http://www.bosch-home.co.uk/customer-service/download-instruction-manuals.html) it's not yet available online. You can order most original instruction manuals through the Customer Service Replacement Spare Parts department by calling 0344 892 8979 (UK) or (01) 450 2655 (ROI).
Jan 20, 2015 | Bosch Washing Machines
How can i get a instruction manual for my Bosch E-nr TAS4511UC/01
The manual for the Tassimo Hot Beverage System, TAS4511UC, is here: http://www.bosch-home.com/us/TAS4511UC.html?source=search . Click on Additional documents. Then click on Service and Use Instructions.
I hope this helps.
Apr 11, 2011 | Bosch Kitchen Ranges
Does anyone know how I could open the base of a Bosch universal mixer MUM6N11 to expose the wires as they come into the machine.
Just take the screws off the bottom. Several need a long screwdriver to access. Then the top will lift off.
Mar 02, 2010 | Bosch MUM6610 Universal Series Stand Mixer
Need Bosch stand mixer's model number to buy replacement parts
Just some added information. The number you have may be a part number. I ahve the exact same number on my Bosch Universal Mixer. What i'm looking for is a new casing, mine is broken.
Mar 15, 2008 | Bosch Kitchen Ranges
Kitchen Ranges Logo
601 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
