Question about Garden
Ariens 1336 snowblower chute fell offf..reset it on top of ring,but it is unstable and any rotation causes it to fall over and off the track and ring. how is chute secured to ring and the mechanism/gear that turns it?
  • 76 Answers
Go to then click on parts, click where it says click here, then enter 1336 where it says model name/ number then you will be able to find the breakdown for your machine you will need model and serial handy to find out which one is your machine cause they list several different models for that number then click on your model and on the right side click on illustrated parts list then it will give you a complete list of the breakdowns for your machine.
Posted on Jan 04, 2009
Craftsman snowblower chute won t turn. the cables just spin inside the gear that rotates the chute left and right.
take chute apart where it pivots
theres a square hole that is now rounded
get some hard plastic 2 part glue from auto parts store
warm it all up build up sides flat again. or buy all new parts
my way is $7 or less and yes ive done this
Feb 03, 2014 | Craftsman 28 In 277cc* Dual-Stage...
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
Have a mtd snowblower the chute wont turn its stuck pointing to left the crank turns but will not turn the chute i tried cleaning the snow and ice from around it like its frozen
Where the crank shaft meet the chute there is a connection which is held in place bt a cotter pin or (on some models) a small screw. These can loosen and fall off causing the chute to stay in one position when the the handle is turned. Re-attach the shaft to the chute with a cotter pin or screw.
Feb 19, 2010 | Plumbing
Ariens snowblower impeller not throwing snow
Sounds like you have a broken or partially broken shear pin in the auger.Check along the auger[machine off]and see if there is what looks like a bolt anywhere along the auger shaft.If there is [and there will be] remove and inspect it and you will see why the auger is not working.Next time,never clean out a chute or auger while the engine is running,people loose limbs this way.
Feb 13, 2010 | Ariens 34 In. Zoom Series Riding Mower
I have an ariens 824 snowblower that needs shear pins. How to replace. Where to purchase them. I live in Hyannis Ma. Nick
Most times when a shear bolt/pin shears, the outer ends fall off into the snow, the inner part of the bolt stays inside the auger shaft. You must rotate the auger/ribon to find the hole in the shaft that has the bolt left in, and then with a drift punch, drive the bolt out of the shaft. Depending on the amount of rust, rotation may be difficult. Depending on the shear bolt, finding the internal broken part may also be difficult, but you should see a 'fresh metal shear' of the broken bolt. You can purchase them on eBay or your local lawn & garden dealer should be able to get them.
Dec 22, 2009 | Ariens Garden
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
Nov 15, 2009 | Ariens Garden
How do I change ariens snowblower belts
on some blowers you have to remove the front auger sya in order to change the belt. it a pain. look down from the top to see if you have room to slid the belts throw, if not remove the front auger
Oct 12, 2009 | Ariens Garden
Ariens ST 724 impeller does not move under stress?
i have a old ariens ST724 snowblower engine will only run with full choke.
Jan 29, 2009 | Farmall Cub Tractor Radiator
Ariens 926LE snowblower won't engage forward or backwards. Running fine
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Dec 21, 2008 | Garden
Garden Logo
447 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
