Question about Panasonic Televison & Video
Panasonc 32 inch TV - when you press the power switch on the front the indicator light blinks constantly - If you pull the power cord you hear a relay sound - then plug it back in and you can power it up - this worked for a while now you hear it starting to power up then it shuts down Any suggestions
    Problem Solver:
  • 4 Answers
Using the remote turn it on and off if you do not get the same results then you will be best served by taking it to a authorized service center since the power relay unit switch is one punit and not something that a customer can do himselfif nota qualified technician.
Bill
Posted on Dec 13, 2008
Sony LCD TV Red LED light constantly blinking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 06, 2015 | Sony KLV-32S550A 32 inch Multi-System LCD...
32 inch emerson lcd tv standy light is on power light flashes
How many times this standby/power light blinks at one time switch ON?Count it carefully.These blinks are fault indication, and known as blinking codes.From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV.This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Dec 11, 2013 | Televison & Video
My Samsung LCD smart tv model UN46D6000SF has no picture, and the power light just flickers constantly. I know it's not the compacitors they are in great condition not defective, even when I unplug the...
Nov 28, 2013 | Televison & Video
Sony bravia 46
Switch ON the TV, at least two times, and make sure about how many times do this front LED blinks, at one time switch ON. These blinks are fault indications. From the number of blinks occur, you can get an idea about the faulty section circuit inside the TV. If you wish to know more about the blinking codes and other details http://electronicshelponline.blogspot.com/ try this link. Pull up older posts there by its left side bar. Blinking codes to many brand TVs are given in detail.
Jun 08, 2013 | Televison & Video
My tv came on but turned itself off and now the power light just flashes now and will not come on at all
Flashing of power light are fault indications. These are called blinking codes. Count the number of blinks occur one time switch on. It will give you an idea about the faulty section circuit inside. If you wish to know more about these blinking codes, check this link.
Feb 22, 2013 | Sharp 32SC260 32 inch TV
Standby light blinks and tv wont cut on
How many times the standby light at its front panel blinks? Count it. These blinks are fault indications. Check this link for more details about Sony Blinking codes. Count the blinks that occur once, after switch the TV On by its front panel power switch. Check it.
Jan 02, 2013 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My phillips 60 inch tv 60pl9200d/37 wont turn on the power button flashes blue
Look in the manual. (Page 4)
Turn the TV on From main supply: Ensure that the main supply is turned on. A blue indicator light on the front of the TV lights up. When the TV is turned on by the main supply, the blue indicator light will blink for 45 seconds. This is the lamp's start-up period. When the light goes off, press the POWER button on the remote control or power switch. Press POWER to turn on the TV.
http://www.retrevo.com/support/Philips-60PL9200D-TVs-manual/id/633ag423/t/2/
Telephone number Philips Customer Care Center: 1-888-PHILIPS (744-5477)
Aug 14, 2011 | Philips 60PL9200D Projection Televisions
The screen blinks constantly. I have checked all connections and they are tight but continues to blink.
Hi:
You have a fault either on the power supply or inverter board.. Check all caps on the PS and inverter for swollen capacitor tops.
Nov 11, 2010 | Insignia IS-LCDTV32 32 in. Television
My TV won't turn on
Ur tv have LED front panel power indicator light blinking?Or completely dead,no LED light indicator at all?Check ur power outlet source.Yes,than ur power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 28, 2010 | Soyo DYLT032D 32 in. LCD Television
No POWER
How many times does the POWER led flash per second? (Dont worry about the OPC).
1x (steady constant blink) = Lamps or inverters
2x = Power Supply
3x = Main Unit
If i am reading it correctly, looks like the POWER led is flashing 2x, which means it is a power supply failure. Either way, your TV needs to have a board replaced, there isn't anything you can do to fix it yourself. Try locating your local sharp authorized service center to repair your TV (1-800-237-4277)
Mar 13, 2008 | Sharp AQUOS LC-32D43U 32 in. LCD...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
