Question about LG 42PX4DV 42 in. EDTV-Ready Plasma Television
Stand We i bought the tv the stand was already attached. i am in the process of mounting on the wall but have no idea how to remove the stand. the manual does not specify anything in regards to the removal of the tv stand when wall mounting....what do i have to do!!!
  • Anonymous Mar 15, 2014
    tv removed from wall bracket and I cannot work out how the base bracket should be re-attached to the tv
    President:
  • 1,284 Answers
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Posted on Mar 10, 2007
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Sep 08, 2015 | Westinghouse W4207 42 in. HD-Ready LCD TV
REMOVEABLE BASE STAND
I think this aftermarket stand will work. The reviews mention a couple of people using this with heavier lcd/plasma screens with no problems. Hope this helps!
http://www.amazon.com/Universal-Stand-Base-Wall-Mount/dp/B00DZVPFGU/ref=sr_1_5?ie=UTF8&qid=1399529274&sr=8-5&keywords=50+inch+universal+tv+stand
Apr 18, 2014 | Polaroid PLA-5048 50 in. HDTV Plasma...
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
I need to remove tv stand from my Soyo DYLT032D to mount on wall, Also what screws do you remove in back of TV? Thanks...
Remove Back plate screws and match up the holes on the wall mount device with the holes on the back of your television. Attach the television to mounting devise, Then mount both to the wall. Hope this helps you with your problem.
May 09, 2009 | Soyo DYLT032D 32 in. LCD Television
Cannot figure out how to remove stand so I can mount TV on wall
did you figure this out? I only ask because I need the stand for my TV. Could you sell me yours?
Thanks
Anthony
amsaxo@yahoo.com
Dec 02, 2008 | Sylvania 6620LDG 20 in. EDTV-Ready LCD...
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
How do i attach a Wall Mount to the TV?
I have the same TV, and I bought a mount with 4 connector holes. I was able to connect 3 of the 4 and it has been fine as the TV does not weigh too much. The TV was not designed with the current mode of either wall or stand mount. It was just intended for stand. I have had it on the wall for over 2 years.
Apr 23, 2008 | Televison & Video
TOSHIBA TELEVISION STAND
Can you post a pic of the stand showing its fasteners?
Usually they are just screwed on. (But of course manufacturers have a thing about always trying to hide the screws)
Jan 18, 2008 | Televison & Video
LG 42PX4DV 42 in. EDTV-Ready Plasma Television Logo
406 people viewed this question
Steve Allison
Steve Allison
