Question about Xerox Phaser 8500/DN Printer
8550DP even after cleaning and replacing the waste tray, I get this error message: Waste tray missing Can I solicit help please
  • vij073 Dec 13, 2008
    Thanks for the immediate response. I tried this; but could nit get this to work. Probably the sensor is bad and needs replacement.
    Is there a place where I can get instructions on how to open the printer and replace the sensor? If I take this to Xerox, they will rip me off (apart from shipping charges for this huge printer)!
    Thanks again.
  • 81 Answers
That usually is a sensor failing. You can try to locate it (in the area where the tray goes) and see if it is loose.
Good luck.
Posted on Dec 13, 2008
Xerox phaser 8560 printer is saying waste tray missing but it is not
Are you sure you are looking at the waste tray, and not the paper tray? Here is a link to the user manual for the printer. Information about the waste tray is on page 194. This should give you an idea of were it is located.
http://download.support.xerox.com/pub/docs/8510MFP/userdocs/any-os/en/user_guide_en.pdf
hope this helps
Feb 22, 2012 | Xerox Phaser 8560/YN Printer
Waste motor error
The wate motor transfers (you guess it) waste toner to the waste toner bottle. If the bottle fills up, the motor cannot transfer more waste to it. This is rare, for the printer should ask for a new waste toner bottle when the previous one fills. However,it happens frequently when users try to empty and clean the bottle instead of replacing it.
Oct 02, 2008 | Samsung CLP-500N Laser Printer
Waste Toner Error Message For Samsung CLP 550
Dr. P,
Printer will display "Waste Toner Tank Full/Not Installed" error message if the waste tank is full of toner or not installed.
  • Open the waste tank door and check for the waste toner tank.
  • If the tank is full or not intalled, install a new tank.
If you have user guide, it will show you how to install the waste toner tank.
Sometimes you will also get this error message if the Waste Toner sensor is covered with toner powders.
  1. Remove your waste tank and look for the black plastic on the right side after removing the waste tank.
  2. You sould find small openings on each side in the black casing.
  3. Use Q-tips or thin cotton object to clean the inside the small opening.
for user manual just click here:
If this solution works, please don't forget to rate it fixya
For any more question just ask me.
Thanks
Iqbal
Apr 14, 2008 | Samsung CLP-550 Laser Printer
Getting a false error message that the ink/toner is empty and wastebin is full when i print to my phaser 8860 from a macbook on 10.6 (networked printer)
The waste bin full error can occur if the waste bin was not removed from the machine for over 10 seconds when it was emptied. Please remove the waste bin and wait for a full 10 to 20 seconds before replacing the Waste bin.
If the message still displays turn off the machine and leave it off for 1 minute then turn the machine back on.
Then run software update to make sure you have the latest OS updates.
Then delete the printer and re-add the printer.
Aug 04, 2011 | Xerox Phaser 8860MFP Printer
Xerox c2424 has error message "Waste Tray Missing". Have emptied waste tray which was overflowing and placed it back in machine but above error message means it will not work.
The Waste Tray Optical Sensor 119-6487-80 is probably bad, which contributed to the overflowing ink. Look at the diagram #6
Whit
Sep 10, 2010 | Xerox C2424 Copier
Waste tray message will not leave display panel even though tray is empty
You will most likely have to remove ( looking at the machine from the front) left cover and clean out some spilled ink from the waste tray sensor.
You have to remove one screw from the back top of the cover, then the top front of the cover. Lift up and out on the cover to release the tabs and pop the cover off. Then have someone slide the waste tray in and out so you can locate where that tray seats into the sensor.
Most of the time, some ink spills into that area in the back of the waste tray, and blocks it from sliding all the way in.
Jan 05, 2010 | Xerox Phaser 8500/DN Printer
Clear waste ink ctr
TAKE RUBBING ALCOHOL AND A LINT FREE RAG AND GENTLY WIPE THE HEAD ON YOU INK CARTRIGE AND ON YOUR PRINTER, THAT SHOULD CLEAR THAT UP.
Jun 21, 2009 | Epson Stylus Photo R300 InkJet Printer
Waste Toner Light won't go off?
just clean out the transfer belt
Sep 20, 2008 | Office Equipment & Supplies
Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Xerox Phaser  8500/DN Printer Logo
385 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
