Samsung PS-42Q96HD sound no picture
Samsung PS-42Q96HD sound comes on but no picture, had a samsung authorised repairer to have a look and claims its the y drive and buffers which need replacing, but wants a kings ransome to do the job. is it possible to buy these parts direct ?
SOURCE: no sound or picture HL-R5067w samsung
alread change the lamp and fan did not work
Posted on Feb 09, 2008
bluenadas
  • 203 Answers
SOURCE: Another Question Please.
Horizontal lines can be cause by many things. One of which is the convergence module. $130.00 is a little high for something that can be caused by other things as well.
Posted on Jun 18, 2007
zjut
  • 106 Answers
SOURCE: R4252 No picture, sound OK Y-Drive buffers overheating
Try to replace the Logic Board, about 50% chance to fix the problem.
Posted on Jan 04, 2008
Slinteriors
  • 8617 Answers
SOURCE: need new green picture tube
You dont need a new tube. What you need is to repair the seal on your old tube and replace the CRT coolant fluid. There is a coolant chamber attached to the tube with long bolts with springs on them that contains coolant to prevent your tubes from getting hot. Yours may just need tightening, but I would replace the seal just to be safe as thecoolant can and will destroy your circuit board if its allowed to continue to leak on it.
Posted on Jan 22, 2008
  • 208 Answers
SOURCE: PLASMA Y-DRIVE
Most times with this happens you can repair it by replacing the buffer bds. Sometime the ysus bd is bad and unfortunately the panel can cause this problem. I would say 60% of the time the buffers will correct the problem. I usually replace both at the same time.
Posted on Feb 21, 2008
What do you think is wrong with my television, it has sound but no picture. How can I fix the problem?
Hi there
I would go to menu on the remote , from there to picture go down the list, if you do not find anything there to help you. Go to Support and to the E manual .
26053790-x3zeawgeewbvgdzeyuixqaom-4-0.jpeg Kolbrun
Jan 14, 2016 | Samsung LN52C530 52" LCD TV
Ps 42q96hd
The digital part? Do you mean you have sound but no picture/video? Does the power LED on the front of the TV flash? Just about every board in the TV can cause this symptom. You may need a trained TV technician diagnose it further. If you need replacement boards, Tri-State Module is a good vendor for me.
Nov 04, 2013 | Samsung HP-R4262 42 in. Plasma Television
Samsung PS-50C91H 50" plasma no picture
If this set has a cable box, satellite box or even a receiver hooked up to it remove power from them and the set for a while and power back to see if a reboot cures this issue.
short of that someone who is willing and knows how to check things is going to have to look inside and test things, repair if not what I have suggested consists of replacing boards which can either fix the set or not and gets expensive.
Dec 06, 2012 | Samsung Televison & Video
Samsung PS-42Q96HD
Please check whether the inverter is working and giving voltage to the display board. If not, this might require attention of a qualified service technician.
Jul 12, 2012 | Televison & Video
Samsung LN-T4066 comes on with picture and sound. Picture gone in two seconds. Backlite off. 1000uf 10v caps on PS replaced. Is it more PS pblm or lamp?
does your tv have energy saver options Check and see if that is the problem if set for high saving you will get sound but no pic
Apr 08, 2010 | Televison & Video
Having problems getting a full picture on my PS-42Q96HD
i have seen this before and it is the logic board failing
Dec 03, 2009 | Samsung HP-R4262 42 in. Plasma Television
Synchronisation problems
try to change the sound setting of your reciever.. try all options of sound setting..
Dec 27, 2007 | Onkyo TX-DS777
Optical output on tv through dvd home cinema out of sync
I just had the same problem. I returned it to currys and got an exchange because I thought there was somethink wrong with the surround sound itself. I have just tried , and left for ages as it goes out of sync gradually as you said ,the red/white cables (rca , i think it's called)and it works perfectely. You can find the wire for quite cheap just type it in google.
Sep 17, 2007 | Televison & Video
Televison & Video Logo
59 people viewed this question
Top Televison & Video Experts
