Question about Coby DVD-218 DVD Player
"loading" then "no disk"
Whenever a CD is loaded, it says 'loading' then, 'no disk'. DVD player still not working. I tried adjusting the variable resistors on the read head - no success. Just a note, I did this on another DVD player(portable type), but it could only play mp3, but gives the same message as above. Could it be a problem with the circuitry? Just think; 1.The motor that spins the cd seems to be spinning a bit slower. 2.Could it be there is faulty component(s) that just gone bad after prolonged use? If so, which one(s).
  • Anonymous Feb 27, 2008
    Same problem here. I've verified that the disk drive is spinning up, and the head moves slightly, but does not detect the data on the disk.
    Top Expert:
  • Coby Master
  • 83,850 Answers
You might as well just replace the player, the cost to repair is more than a new one.
Posted on May 18, 2017
  • Coby Master
  • 1,830 Answers
How old is your DVD Player?
4 Suggested Answers
  • 10 Answers
SOURCE: wrong disk problem
Then lens may need a damp isopropyl alcohol qtip run over it a few times, use 90%. If that doesnt work then try a cd cleaning disk to put in the player. The cd or dvd may also be too scratched to read.
Posted on Feb 12, 2007
sodeep
  • 3267 Answers
SOURCE: Won't read Dvd/Cd as loaded
It is a problem of the optical head being covered up by foreign particles obscuring the optical lens. Try using a CD/DVD cleaner disc which has double brushes and one add some solvent which comes along with the pack.Simply play it & keep ejecting and inserting the disc makes the disc to spin, till your player starts reading it..............................sodeep
Posted on Oct 06, 2009
bomark2002
  • 160 Answers
SOURCE: DVD Player Not loading Movies
optical sensor is burned out or the spindle is not spinning the disk to read it.
Posted on Nov 06, 2009
Whenever I load a rental dvd, I get "Disk Error",
This unit has had problems playing dual layered dvds and since most newer are Dl try a older rental Movie and see if that works
Mar 28, 2011 | JVC DR-MV1S DVD Recorder/VCR
Jamo, DMR 61 keeps rejecting DVD and CD; player not reading disks
The dvd mech assy is defective and needs to be replaced.
Mar 30, 2009 | Jamo DMR 60 DVD Player/Receiver
Screen comes on, disk turns, loading starts, and doesnt stop
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
Dvd player refuses to read any disc I load into the machine
Hello I was looking to try and help you with your DVD player, we will start by loading a music cd store purchased, no burned cds please, if the cd loads and plays then your dvd player is either out of adjustment or going bad, most dvd players, i have worked on, will load and play a music cd, but will show loading errors when trying DVD's. If the music cd dosen't load then there could be an issue with the drive or tray. If the music cd plays just fine, then your laser is either out of adjustment or going bad. You can call the manufacuter to see if there is a process for resetting the DVD player, not all DVD players have this option, if resetting the DVD player dosen't work, but music cd's do then your laser lens is dirty or going bad. At this point you have three options 1) Take it to a repair shop, 2) Get an new one, 3) Get your hands dirty if your really handy and know what your doing to clean and replace the laser. I hope I can be of further assitance and I look forward to helping in the future, Thank You and have a nice day.
Jan 14, 2009 | Televison & Video
Prism DVD-352P not loading any disks
What you are hearing is the attempt to read the disk. The unti detects that a disc is present and attempts to read it by spinning it first at CD speeds then at DVD speeds. It will attempt this a number of times before giving up and reporting "no disc". If you can get at the optics, try cleaning the lens using a cotton swab and alcohol. Next try to read a CD. If you can read a music CD and not a DVD, it indicates that the optics are starting to fail and need to be replaced.
Dan
Dec 18, 2008 | Televison & Video
D1817PKG DVD. Turn on unit - insert cd movie- audiovox loading - does not recognize cd
My dvd player tries to load dvd, then says Cannot Read Disk. Have tried different disks.
Jun 13, 2008 | Televison & Video
DVD/CD will not load and ejects
junk it and buy a better player...cheap dvd players fail quickly..
Feb 25, 2008 | Durabrand DVD-1002 DVD Player
No Disk
no puedo acceder al menu se me perdio el control y quisiera ver si se le puede cambiar la region a cuatro gracias
Jan 16, 2008 | Insignia IS-PDO40922 Portable DVD Player
Loading ... then no disk
Laser pickup unit fault [weak]. Check and replace it. If you wish to get some details; visit the site linked here. Pull up older posts.
May 19, 2017 | Coby DVD-218 DVD Player
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
Coby DVD-218 DVD Player Logo
46 people viewed this question
Top Coby Televison & Video Experts
Steve Allison
Steve Allison
Are you a Coby Televison and Video Expert? Answer questions, earn points and help others
