Question about Earthquake Sound PH-D3 Car Audio Amplifier
Earthquake phd 1 channel and 2 channel
I have two amps that have the same problem. The light turns on as if everything is normal but it puts out no sound. If the RCAs are hooked up you can hear a hum in the amp that goes with the beat.
  • 113 Answers
Check for broken rca input ground
Posted on Aug 09, 2007
Error code 007 340
Hello!
This issue relates to an error with the PHD (Photoconductive) Unit. To resolve this error please try the following steps:
1. Turn the printer off.
2. Wait 10 seconds.
3. Turn the printer on.
4. Determine if the issue still occurs.
5. If 007-340 or 007-341 Restart Printer Error recurs please remove the PHD Unit and remove any packaging.
To Remove PHD Unit:-> Remove the Paper Tray
-> Open the front cover.
-> Put a piece of paper on the transfer belt to protect it from scratches and from light damage. Do not cover the left and right of the belt guards with the paper.
-> Rotate the four stoppers of the PHD counter-clockwise 90 degrees to release the locks
-> Remove the PHD unit toward you by pulling it by the left and right handles.
-> Lift up the PHD unit from the printer. Be careful to avoid scratching the transfer belt.
-> Remove the packing tape by pulling straight out
Reinsert the PHD.
-> Close the front cover.
6. If error recurs with the PHD Unit re-seated please try another PHD from a working 2130CN Laser Printer (if available).
7. If issue recurs after trying another PHD or no PHD Unit is available, please call Dell Technical Support to advise.
Oct 28, 2013 | Office Equipment & Supplies
DELL 1320 C CLOOR LASER PRINTER PRINTS LIGHT YELLOW STRIPE ON LEFT EDGE OF PAGE WHY ?
I had this problem with my 1320c. Was about to chuck the printer out. The solution I found was: 1. take out PHD unit by undoing 4 twist clips. (read instructions on how to do this without damaging anything) 2. Carefully turn over and tap out all loose toner. (I had large accumulations of yellow toner). 4. Clean up; replace PHD unit and 4. Make sure all 4 toner cartridges are seated snugly in from side door. Good luck
Oct 17, 2010 | Dell 1320c Laser Printer
Problem with Eathquake amp 2000w
the amp dose not have any such internal batery it is probly tosted call me 256-698-9903
Jul 05, 2010 | Earthquake Sound PH-D2 Car Audio Amplifier
Red light is on when i connect input cable earthquake 1000w amp
Cables are either shorted, or deck is putting out too much power for input on amp... many new head-units will put out up to 7v on the output jacks (RCA) the amp may only want to see up to 1v will need to consult head-unit manual for adjustment of outputs.
Jan 22, 2009 | Earthquake Sound PH-D2 Car Audio Amplifier
6 channel power 1000watts earthquake amps red is on
This is normally a grounding problem in the amplifer. If you have a volt meter, check the voltage at the ground of the RCA input on the amplifier. If that voltage is anything more than just a few millivolts then you have a problem in the pre-amp of the amplifier. You should also only connect or disconnect the RCA jacks while the system is off. Otherwise you can get a loud popping noise that can damage the amp or the speakers. Check that voltage on the amplifer RCA jacks with the head unit not connected to the amp with the RCA cables, then if that is OK, check the RCA cables coming from the head unit. You may even have a voltage on those RCA's coming from the head unit, in which case, you have a problem in the head unit. You will be looking for a DC voltage, if you have anything more than just a few millivolts (0.070 +/- DC volts) on either of those then you have found the cause. After that, it will require a technician to be able to troubleshoot the amp or the head unit to determain why you have that DC voltage where it should not be.
Let me know if I can be any more help,
Dave
Jan 22, 2009 | Car Audio & Video
Bass sounds flat when volume is increased
probably your power is too short, increase your gauge wire, and your ground wire of the amplifier has to be shortly as possible, and the positive has to be enough to support peak power, you can also put a big capacitor on the positive wire to give some more power while the bass peak.
Apr 26, 2008 | Earthquake Sound PH-D2 Car Audio Amplifier
Xplod amp
You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
Sep 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Fan on Amp turns off with everything off.
yes , it is normal for the fan on the amp to turn on when the internal tempature reaches 110 degrees the amplifier is not an intellegent device, all it knows is the temp threshold has been reached and its themostat will close the relay and try to exhaust the heat from the amplifier....I have this same amp, and I live in florida...thank goodness it is a very minimal draw,,,btw if it was a 100 outside it was well above 100 inside your car and even hotter inside the amp ,,the heatsink will conduct heat inside the unit when the unit is off....so the unit is behaving normally...Congratulations for buying a high quality piece of electronics
Jul 10, 2007 | Earthquake Sound XTREME 900W.5 Car Audio...
Earthquake Sound PH-D3 Car Audio Amplifier Logo
248 people viewed this question
Top Earthquake Sound Car Audio & Video Experts
hoyzee1
Tom Chichester
Are you an Earthquake Sound Car Audio and Video Expert? Answer questions, earn points and help others
