Keeps freezing up
When we run the air con it freezes up at the front of it. we then need to turn it off and let it defrost before we can start it again.
  • 334 Answers
Two things will cause freezeup.
Lack of airflow.
Low refridgerant.
Lack of air flow could be due to :
dirty filter
Dirty coils
closed vents
Evaporator fan not operatriing properly. (also known as blower in HVAC units)
Posted on Dec 13, 2008
Coils freeze up and fridge runs all the time till I melt coils.
There might be a few causes
Door Seal might be defective causing the door not to shut tightly this causes air from the room to get into the freezer through the opening and as the air comes in contact with the evaporator coils, it freezes. Normally the defrost system removes the ice but if the seal is defective the coils freeze too quickly and the defrost system cant keep up
If the freezer evaporator coils ice over, the defrost thermostat might be defective. Several times a day the defrost heater turns on for a few minutes to melt away any frost that may have accumulated on the freezer evaporator coils. In order for this to work, the defrost thermostat has to sense that the coils are cold enough. If the coils are cold enough the defrost heater will turn on. If the thermostat is defective it may not be able to sense the temperature of the coils and then won't turn on the defrost heater. If the defrost heater doesn't turn on, the evaporator coils ice over and eventually no air will be able to travel through the coils to provide cooling to the freezer. The defrost thermostat can be checked for continuity. It should have continuity when it reaches the low temperature of its operating range.
Jun 03, 2015 | Refrigerators
My air conditioner is freezing up
Hello, the unit will frost from either low airflow ( dirty coil or filter) or a low refrigerant charge due to a leak.
Jul 04, 2012 | Sharp Comfort Touch AF-R120EX Air...
My fridgedaire side by side freezer's condensor is freezing over and warming the fridge side, I defrosted it the fridge side is keep cool enough to keep food but the freezer side will not get cold to...
Hello, This is a type of faulty you can handle yourself, most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
I hope this will help in solving the fault.....
May 12, 2011 | Refrigerators
My lines are freezing and the ac works sometimes and sometimes it doesnt. How do I avoid the lines from freezing
you need to check your filter to start with if thats good make sure all you vents are open and your returns are free from abstruction
Aug 25, 2010 | Honeywell Heating & Cooling
My ge side by side will freeze up the coils in about seven days. service tech came out and replaced a heating coil inside of the unit and we are still expieriencing the same problem. the compressor pulls...
Since the heater has been replaced, you could have a bad thermodisk, but more likely a problem with the defrost timer. The tech should have checked the heater and disk rather than replacing the heater blindly.
You probably know some of this but for me it's a copy-n-paste.
All frost-free refrigerator-freezers with exception for the ones with solid-state control have a thing in the system called a Defrost Timer. The thing is a little clock of sorts that tracks accumulated running time. Every 8 hours of run time the thing cycles through a defrost cycle. The defrost cycle is necessitated by the humidity that forms ice crystals on the freezing coils, if the frost is not eradicated it can build up to the point where no air flows over the coils to chill the inside of the box. (it may keep the freezer cold but no air goes to the fridge part. If completely solid neither cools) Most timers are located on the front of the machine, behind that removable grille under the door. Sometimes it's found in the refrigerator behind a plastic cover. The timer has a round hollow shaft through it, and can be turned with a screwdriver. If the compressor is running, give the shaft a slow twist until a click is heard. The compressor will stop. Give the fridge an hour to defrost the coils, and check it to see if it took off running. If an hour has passed and the fridge hasn't restarted, advance the timer again to start. Sometimes the nudge will make the timer run for a while. If this is the case, the unit will chill, and buy you some time to get it fixed. If the timer does not run, you can repeat the process daily until you get a replacement timer.
Hope this is helpful for you.
Jul 13, 2009 | GE GSL25JFR Brushed Steel Side by Side...
Freezer motor keeps freezing up
Sounds like a defrost timer.Also it can be a defrost thermostat.Try to adcance the defrost timer to a defrost and see if it melts the ice off.If so then i would say you need a defrost timer hope i helped:)
May 10, 2009 | Freezers
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Air Con cuts in and out and so does cooling fan
I have a 2008.5 Mazda 3 GS Sport and when you turn the air flow selector to windows or windows/floor, the air condition will turn on automatically. (Can't turn it off.)
Nov 12, 2008 | 2008 Mazda Mazda3 Hatchback
Kenmore refrigerator freezer not freezing
Yes that is a proplem...when ever that compressor is running that fan motor should be running too.. also you evapurator fan motor should be running also
Aug 20, 2007 | Magic Chef CTB1722 Top Freezer...
Heating & Cooling Logo
98 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
