Question about Dell Inspiron B130 Notebook
Laptop i was using my compture and it was dying and i did not charger right away so it overheated and shut down so i chage it later and it did turn on what can i do i cant afford to fix it help!!!!
    Master:
  • 461 Answers
It does not overheat from needing charged it simply shuts down automatically when the battery is low. Are you still having problems? Please explain.
Posted on Dec 12, 2008
    Master:
  • 474 Answers
Fist, It doesnt overheat when the battery gets low, it just powers off or goes into standby.
Why do you think it over heated?
Try this first. Remove the battery and unplug it for about 2 minutes, re-insert them amnd try to power it on.
What does it do? Any beeps or flashing lights? What color are they?
When laptop start window 10 boot screen come up and during the process after 15-20 seconds since the laptop was powered on the laptop get shut down.
hi there.
Laptop performance slowing down, or the laptop isshutting off completely because the laptop is trying to protect itself from damage caused by an excessive heat build-up. ... There are times when a laptop will turn offbecause of a virus or malware, hardware or software problems/conflicts as well.2 Nov 2013
Don't panic!... Is your "laptop shutting off by itself" or "slowing down ...
https://www.youtube.com/watch?v=74agkgZdzkI
What is the problem if laptop shuts down automatically?If removing air doesn't fix shutdown issue, it is a faulty hardware (can be anything), related to overheating or serious power related failure, such as bad battery or adapter. Overheat issue will result in unit turning on, but shuts down after about the same time (i.e. 15 sec).29 Jun 2015My Laptop automatic shutdown in few seconds - Laptops - Laptop ...
What would cause a computer to keep shutting down?An overheating power supply, due to a malfunctioning fan, can cause a computer toshut off unexpectedly. Continuing to use the faulty power supply can result in damage to the computer and should be replaced immediately. ... Software utilities such as SpeedFan can also be used to help monitor fans in your computer.5 May 2017Computer turns off without warning - Computer Hope
How do I get my computer to stop shutting down?Cancel System Shutdown or Restart. You cannot cancel a restart or shutdown using the Shutdown Event Tracker Windows interface. It is only possible to perform this task from the command line. To cancel or abort system shutdown or restart, open Command Prompt, type shutdown /a within the time-out period and hit Enter.1 Apr 2013Stop, Cancel, Prevent, Abort System Shutdown in Windows 10/8/7www.thewindowsclub.com/abort-system-shutdown-windowsSearch for: How do I get my computer to stop shutting down?
or go to this link to find out more.
Laptop keeps shutting off after few minutes
Nov 19, 2017 | HIS Computers & Internet
I have a Compaq NW9440 Mobile Workstation - it keeps shutting down every 15 minutes or so. At times, it will not restart right away. I thought it may have been the CMOS Battery, so I replaced it. It's...
The most common problem you get with a laptop is overheating, this can cause for it to shut down while operating to prevent more damage.
You will know if your laptop is overheating if it happens one ore more of the following:
-The keyboard and the bottom of your laptop are very hot when the laptop is working.
-The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
-The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
-The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Follow this steps to avoid overheating:
-Don't use your laptop in full sunlight for extended periods
-Don't leave the laptop in a closed car on a sunny day
-Don't place the laptop on or near extreme heat sources, such as radiators, hot air vents
-Turn off your laptop before putting it in your carry bag
-Turn off your laptop when not in use for a long period
-Work on an even surface as much as possible, not on your lap!
-Clean the air vents in your laptop regularly by using a can of compressed air
-Get more space under your computer by propping it up on something when it's on a desk
-Consider purchasing a laptop cooling pad
-Consider purchasing an external fan
To clean your laptop's cooling system:
-Shut down the laptop ie do not leave it suspended, sleeping or hibernating.
-Unplug all cables from the unit and remove the battery pack
-Get a can of compressed air and blow it into all vents around your computer - this should clear out any dust and hair.
-Do Not use a vacuum cleaner.
If it is not overheating, then it is a hardware failure. Could be the RAM memory, or the motherboard. You can only corner the problem by testing with different RAM modules or motherboard.
Dec 01, 2010 | HP Compaq nw9440 Notebook
My Dell 1721 laptop appears to have overheated/will not turn on.
Hi there!
For that problem of yours, you can only try a few things since its shutting down by itself,
First, Try to use just the charger to turn on the computer, if it does the same thing then unplug the charger and then this time just use the battery,
If the same thing happens then double check the charger if there is a light on it or of you have another
charger use it.
But after all of this things and the same thing happen,
You may want to check if you still have a warranty
under DELL because you'll need to replace the Motherboard of the computer.
Hope this helps!
Mar 19, 2010 | Dell Computers & Internet
HI, My Hp DV9000 will turn on but shuts off the
There could be a few possibilities here, first the ac adapter needs to be checked for voltage at the tip, it has to be between 18.5 and 19.5 volts. The battery is most likely dead or has dead cells which will not carry a charge. The third problem could be the motherboard. Try leaving the battery out and just run the laptop off the AC adapter....if the laptop runs fine , then the battery is bad and sending signals to the motherboard causing a shutdown. If the laptop is still shutting down or refusing to start, then there maybe a problem with the voltage resulator in the charger brick. If the battery and charging brick are in good condition, then the laptop may be getting a thermal shut down signal from the processor because of an overheating condition. The processor heats up immediately, if the laptop has been run overheating for some time, the thermal grease on the processor can be cooked off reducing the efficiency of heat bleed off, thus causing a shut down to protect the laptop from a terminal meltdown. Try using compressed air and blow out all the ventilation grills and compartment openings to clear out debris, hair and dust.
Jan 07, 2010 | HP Pavilion dv9000z Notebook
I was using my Acer 4520 laptop, when it just turned off. It didn't shut down, just turned straight off. When I tried to turn it back on, the power button light, caps/num lights flash, the nothing. When...
When there is a sudden drop off like that it may be two reasons....first the charger died and is not putting out the correct voltage to run and charge the laptop, the battery may be wesk and would not last long enough to signal an alarm....or the ventilation grills, ports and van openings are clogged with dirt, dust and debris and you need to get a few cans of compressed air to blow all these openings out to clear up the heatsink fans. If this laptop has been run and has overheated, just realize that there may be irrepairable damage to the processor or mainboard.
Oct 14, 2009 | Acer Aspire 4520-5582 Notebook
Laptop started smoking and now no response
the laptop overheated frying the cpu or mobo probably
Sep 14, 2009 | Computers & Internet
Gateway MT6451 Notebook won't boot.
try adjusting the screen lighting....
Sep 14, 2009 | Gateway MT6451 Notebook
My compaq presario just shuts down. When I go to
Typical reasons could be overheating and or the charger is on it's last legs. Do you have the same problems when you're using the computer with battery alone. Does the laptop feel hot?
The reason the charger is getting hot is because it's probably a 65W charger and not a 90W (that's just a guess though)
Let me know if I'm right or not.
Feb 21, 2009 | HP Pavilion dv6000z Notebook
Dell Inspiron B130 Notebook Logo
53 people viewed this question
Alun Cox
