Where can I purchase a recovery disk Acer B151 Notebook
SOURCE: ACER RECOVERY DVD'S
Well, it would be easier (and cheaper) to download the drivers from Acer's website.
Go to:
http://www.acerpanam.com/flex/acer/bin/acer.html#app=2766&1adb-selectedIndex=0&e590-selectedIndex=1&9875-selectedIndex=1&796e-selectedIndex=1&ae20-selectedIndex=1
and select your exact model. You will find all the drivers there.
As for windows, what version is it upgradable from and to what?
SOURCE: doing a recovery on a Acer Aspire 4315-2490 PC Notebook
Ok,
Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
SOURCE: I have an Acer Aspire 3690. I need to purchase
Ebay might be worth checking out for what you need.
it is not uncommon for these things to turn up on there
SOURCE: i have just purchased an acer notebook and the
Refer to the documentation that came with your computer to make sure it came with a DVD drive. If in fact it came with a drive then look at the sides and front of the notebook for a rectangular button and press it while the computer is on and booted up at that point the drive should open.
SOURCE: need a recovery disk for acer travelmate 290
do u have another laptop or pc.
if u have open google then open isohunt then.
1st download nero iso maker
2nd download recovery disk for ur laptop
then u nid a 4.7 gig blank disk then burn the recovery disk
To restore computer to its original settings without
recovery CDs.
Note: If your system is the multilingual version, the operating
system and language you choose when you first turn on the
system will be the only option for future recovery operations.
This recovery process helps you restore the C: drive with the original software
content that is installed when you purchase your notebook. Follow the steps
below to rebuild your C: drive. (Your C: drive will be reformatted and all data
will be erased.) It is important to back up all data files before using this option.
Before performing a restore operation, please check the BIOS settings.
1 Check to see if Acer disk-to-disk recovery is enabled or not.
2 Make sure the D2D Recovery setting in Main is Enabled.
3 Exit the BIOS utility and save changes. The system will reboot.
Note: To activate the BIOS utility, press <F2> during POST..
To start the recovery process:
1 Restart the system.
2 While the Acer logo is showing, press <Alt> + <F10> at the same time to
enter the recovery process.
3 Refer to the onscreen instructions to perform system recovery.
Important! This feature occupies 15 GB in a hidden partition on
your hard disk
